Hi, I'm a new Linux user, usin
Hi, I'm a new Linux user, using Ubuntu and trying to install openfoam.
I went through steps 1 to 5 of the readme file but then I couldn't run the first tutorial. It seems it cannot find blockMesh: flo@flo-laptop:~/OpenFOAM/flo-1.4.1/run/tutorials/icoFoam$ blockMesh . cavity bash: blockMesh : commande introuvable Any idea what the problem is? Note that when I run foamInstallationCheck there is no message at all and it closes. I supposed that it meant no error. Thanks a lot. |
Do you have add this line
source $HOME/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/bashrc to your .bashrc file? If you don't, add this line to ~/.bashrc and reload the file: # . ~/.bashrc Then try the following command: # foamInstallationTest Michele |
thanks for the reply
the so
the sourcing looks ok. However I have a problem with the Java configuration and the "no remote shell available" Some people on the forum have had the same pb, but I couldn't find how to fix this pb... The installation test gives: Executing /home/flo/OpenFOAM/OpenFOAM-1.4.1/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: flo-laptop OS: Linux version 2.6.17-12-generic User: flo User_config: /home/flo/.bashrc Foam_config: /home/flo/.OpenFOAM-1.4.1/bashrc sourced correctly. ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/flo/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/flo/OpenFOAM/flo-1.4.1 yes no $FOAM_JOB_DIR /home/flo/OpenFOAM/jobControl no yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/flo/OpenFOAM/OpenFOAM-1.4.1 yes yes yes $FOAM_USER_APPBIN ...1.4.1/applications/bin/linuxGccDPOpt yes yes no $FOAM_APPBIN ...1.4.1/applications/bin/linuxGccDPOpt yes yes yes $WM_DIR /home/flo/OpenFOAM/OpenFOAM-1.4.1/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH /home/flo/OpenFOAM/linux/j2sdk1.4.2_05 no no $MICO_ARCH_PATH .../mico-2.3.12/platforms/linuxGccDPOpt no yes $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt yes yes yes $FOAM_USER_LIBBIN ...OpenFOAM/flo-1.4.1/lib/linuxGccDPOpt yes yes no $LAM_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.1.2 WARNING: Conflicting installations: foam settings: /home/flo/OpenFOAM/linux/gcc-4.2.1-64/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR java 1.4.2 libgcj) WARNING: Conflicting installations: foam settings: /home/flo/OpenFOAM/linux/j2sdk1.4.2_05/bin/java current path : /usr/bin/java gzip 1.3.5 /bin/gzip tar 1.3.5 /bin/tar icoFoam *** not installed *** CRITICAL ERROR ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_flo-laptop Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Unsuccessful_connection_refused* yes FATAL ERROR: No remote shell available. Foam1.4.1 enviroment requires either ssh and/or rsh. Contact your system administrator. ------------------------------------------------------------------------------- The system test has evoked 1 fatal error(s). The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. could you give me some hint?? thanks Florent |
one more thing...
concerning
one more thing...
concerning the folder containing Java, Gcc and j2sdk, shall I name it linux, linux64 or this has no influence? note: I put export WM_64=on in the /.bashrc file |
Florent,
from the output me
Florent,
from the output message you are using the java and gcc given by your distribution, maybe to solve the problem related with java, download the OpenFOAM version of java and put in ~/OpenFOAM/linux. Michele |
well I have already extracted
well I have already extracted the java archive in the ~/OpenFOAM/linux folder
but it seems that it is not used by the computer... a pb of path? |
my pb has gone a little furthe
my pb has gone a little further...
when I run blockMesh . cavity it gives flo@flo-laptop:~/OpenFOAM/flo-1.4.1/run/tutorials$ cd icoFoam flo@flo-laptop:~/OpenFOAM/flo-1.4.1/run/tutorials/icoFoam$ blockMesh . cavity blockMesh: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by blockMesh) blockMesh: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/flo/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libmeshTools.so) blockMesh: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/flo/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libdynamicMesh.so) blockMesh: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/flo/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so) blockMesh: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/flo/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libtriSurface.so) blockMesh: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/flo/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/liblagrangian.so) blockMesh: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/flo/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libfiniteVolume.so) blockMesh: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /home/flo/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/openmpi-1.2.3/libPstream.s o) I still may have a problem of path... thx Florent |
Hi Florent,
maybe you have
Hi Florent,
maybe you have to download the libstdc++.so.6 Please check on your computer the version and update them if you need. Francesco |
I had the same problem. You n
I had the same problem. You need to make sure that you are using the gcc installation supplied with OpenFOAM. Try typing "which gcc" - does that point at /usr/bin/gcc or at something like /home/apps/OpenFOAM/linux64/gcc-4.2.1/bin/gcc? If the former, then check that your cshrc/bashrc file (in the .OpenFOAM-1.4.1 directory) is correctly configured.
the gcc points at
/home/flo/
the gcc points at
/home/flo/OpenFOAM/linux64/gcc-4.2.1/bin/gcc I guess the pb was java path: I wrote export JAVA_PATH=/home/flo/OpenFOAM/linux/j2sdk1.4.2_05/bin in the .bashrc file and it seems to work now. The blockMesh . cavity and icoFoam . cavity command are working but FoamX cannot launch... |
