Home > Forums > OpenFOAM Installation
Installing OpenFOAM141patched on Solaris10 MPIProblem
Old   October 24, 2007, 07:50
Default I have problems to tell OpenFO
jfb
Josef F. Buergler
jfb is on a distinguished road
I have problems to tell OpenFOAM-1.4.1-patched to use the Solaris10-Version of OpenMPI which is located in /opt/SUNWhpc/HPC7.0/.
Even if I put lines like the following
EXE_INC = \
...[snip-snap]...
-I$(LIB_SRC)/dynamicMesh/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude
EXE_LIBS = \
...[snip-snap]...
-R/opt/mx/lib -R/opt/SUNWhpc/HPC7.0/lib -R/opt/mx/lib/sparcv9 \
-R/opt/SUNWhpc/HPC7.0/lib/sparcv9 -L/opt/SUNWhpc/HPC7.0/lib \
-lmpi_cxx -lmpi -lopen-rte -lopen-pal -lsocket -lnsl -lrt -lm -ldl
in the appropriate "options"-files, the following error-message is produced by the compiler.
-lfiniteVolume -ldecompositionMethods -lmeshTools -ldynamicMesh -lparMetisDecompositionMethod -R/opt/mx/lib -R/opt/SUNWhpc/HPC7.0/lib -R/opt/mx/lib/sparcv9 -R/opt/SUNWhpc/HPC7.0/lib/sparcv9 -L/opt/SUNWhpc/HPC7.0/lib -lmpi_cxx -lmpi -lopen-rte -lopen-pal -lsocket -lnsl -lrt -lm -ldl -lOpenFOAM -liberty -lnsl -lsocket -L/home/zabuergl/OpenFOAM/OpenFOAM-1.4.1/lib/solarisGcc42DPOpt/dummy -lPstream -lm -o /home/zabuergl/OpenFOAM/OpenFOAM-1.4.1/applications/bin/solarisGcc42DPOpt/redist ributeMeshPar
Undefined first referenced
symbol in file
MPI::Win::Set_errhandler(MPI::Errhandler const&)/home/zabuergl/OpenFOAM/OpenFOAM-1.4.1/lib/solarisGcc42DPOpt/libparMetisD ecompositionMethod.so
- Where could I define the MPI-options (like where to search for include files, libraries, etc.)
- Is it possible to use commands like "mpicc", "mpiCC", etc. to make life easier ... for in that case, system specific options are created automagically and handed over to the compiler/linker/loader?
- What's the difference between EXE_LIBS and LIB_LIBS in the "options"-files?
Thanks very much for any help!
jfb is offline   Reply With Quote
Old   October 24, 2007, 08:05
Default It is probably a lot less work
Mark Olesen
olesen will become famous soon enough
It is probably a lot less work just to recompile the openmpi version distributed with OpenFOAM (or get the newest 1.2.4).
EXE_LIBS are the libs required for executables.
LIB_LIBS are the libs loaded by another library.
olesen is offline   Reply With Quote
Thread Tools
Trackbacks are On
Installing as root in opt bastil OpenFOAM Installation 8 October 22, 2008 02:54
Installing OpenFOAM honcho OpenFOAM Installation 1 April 9, 2008 06:29
installing cfx 5.6 bagi CFX 1 December 27, 2005 16:13
Installing 12 after removing 11 maka OpenFOAM Installation 5 August 26, 2005 17:17
Installing Compiled UDF HARI SARYONO FLUENT 0 November 24, 2001 02:48
