-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   VTK errors in ParaFOAM on OpenFOAM14 (http://www.cfd-online.com/Forums/openfoam-installation/57500-vtk-errors-parafoam-openfoam14.html)
stevemchale August 29, 2007 11:51
Hi All, I've installed all
Hi All,
I've installed all the OpenFOAM-1.4 binaries, but I can't get paraview to load the data files. If someone could translate these errors for me I would appreciate it. Thanks.
ErrorMessage
# Error or warning: ERROR: In /home/amy/ParaViewReleaseRoot/ParaView-2.6.2/Utilities/VTKClientServer/vtkClient ServerInterpreter.cxx, line 882
vtkClientServerInterpreter (0x9345438): Cannot load module "PVFoamReader" from "/home/Steve/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/libPVFoamReader.so".
ERROR: In /home/amy/ParaViewReleaseRoot/ParaView-2.6.2/Utilities/VTKClientServer/vtkClient ServerInterpreter.cxx, line 886
vtkClientServerInterpreter (0x9345438): libvtkGraphics.so.pv2.4: cannot open shared object file: No such file or directory
ERROR: In /home/amy/ParaViewReleaseRoot/ParaView-2.6.2/Servers/Common/vtkProcessModuleConn ectionManager.cxx, line 577
vtkProcessModuleConnectionManager (0x9345498): Failed to load Module on connection 1
ERROR: In /home/amy/ParaViewReleaseRoot/ParaView-2.6.2/GUI/Client/vtkPVXMLPackageParser.cx x, line 705
vtkPVXMLPackageParser (0x9d53ba0): Error loading Library component PVFoamReader
ErrorMessage end
ErrorMessage
# Error or warning: There was a VTK Error in file: /home/amy/ParaViewReleaseRoot/ParaView-2.6.2/GUI/Client/vtkPVWindow.cxx (2572)
vtkPVWindow (0x960cc50): Cannot read file information when no reader is specified. This probably means that the reader for the file with name: ./PipeFlowOsc.foam cannot be found
ErrorMessage end
ErrorMessage
# Error or warning: There was a VTK Error in file: /home/amy/ParaViewReleaseRoot/ParaView-2.6.2/GUI/Widgets/vtkKWApplication.cxx (1701)
vtkPVApplication (0x93eb148):
Script:
paraFoam.pvs
Returned Error on line 11:
invalid command name ""
ErrorMessage end
~Steve
msrinath80 August 29, 2007 12:10
Use the paraview provided with
Use the paraview provided with OpenFOAM.
gschaider August 29, 2007 12:18
Hi Steve! Looks like you're
Hi Steve!
Looks like you're using 2.6.2, but there are still some 2.4 libraries in the Library path (libvtkGraphics.so.pv2.4). You've got an old installation, that is interfering with the other one? (or maybe it is the other way round)
Bernhard
stevemchale August 29, 2007 12:44
Any ideas as to solutions? One
Any ideas as to solutions? One way or the other? I'm relatively new at this, so I appreciate your help guys. Thanks.
~Steve
msrinath80 August 29, 2007 15:31
Really can't help you unless y
Really can't help you unless you exactly tell us what procedure you followed for installation of OpenFOAM.
gschaider August 29, 2007 15:39
Hi Steve! Check with 'which
Hi Steve!
Check with 'which paraview' whether you are actually using the Paraview-version distributed with OpenFOAM (I don't think so). The problem you are seeing usually comes from another paraview-installation that 'shadows' the OpenFOAM-paraview, usually because it is found before that in the PATH or the LD_LIBRARY_PATH
Either change those variables or get rid of the other installation
