August 29, 2007, 11:51 |
Hi All,
I've installed all
Steve McHale
Hi All,
I've installed all the OpenFOAM-1.4 binaries, but I can't get paraview to load the data files. If someone could translate these errors for me I would appreciate it. Thanks. ErrorMessage # Error or warning: ERROR: In /home/amy/ParaViewReleaseRoot/ParaView-2.6.2/Utilities/VTKClientServer/vtkClient ServerInterpreter.cxx, line 882 vtkClientServerInterpreter (0x9345438): Cannot load module "PVFoamReader" from "/home/Steve/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/libPVFoamReader.so". ERROR: In /home/amy/ParaViewReleaseRoot/ParaView-2.6.2/Utilities/VTKClientServer/vtkClient ServerInterpreter.cxx, line 886 vtkClientServerInterpreter (0x9345438): libvtkGraphics.so.pv2.4: cannot open shared object file: No such file or directory ERROR: In /home/amy/ParaViewReleaseRoot/ParaView-2.6.2/Servers/Common/vtkProcessModuleConn ectionManager.cxx, line 577 vtkProcessModuleConnectionManager (0x9345498): Failed to load Module on connection 1 ERROR: In /home/amy/ParaViewReleaseRoot/ParaView-2.6.2/GUI/Client/vtkPVXMLPackageParser.cx x, line 705 vtkPVXMLPackageParser (0x9d53ba0): Error loading Library component PVFoamReader ErrorMessage end ErrorMessage # Error or warning: There was a VTK Error in file: /home/amy/ParaViewReleaseRoot/ParaView-2.6.2/GUI/Client/vtkPVWindow.cxx (2572) vtkPVWindow (0x960cc50): Cannot read file information when no reader is specified. This probably means that the reader for the file with name: ./PipeFlowOsc.foam cannot be found ErrorMessage end ErrorMessage # Error or warning: There was a VTK Error in file: /home/amy/ParaViewReleaseRoot/ParaView-2.6.2/GUI/Widgets/vtkKWApplication.cxx (1701) vtkPVApplication (0x93eb148): Script: paraFoam.pvs Returned Error on line 11: invalid command name "" ErrorMessage end ~Steve |
August 29, 2007, 12:10 |
Use the paraview provided with
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
Use the paraview provided with OpenFOAM.
August 29, 2007, 12:18 |
Hi Steve!
Looks like you're
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Steve!
Looks like you're using 2.6.2, but there are still some 2.4 libraries in the Library path (libvtkGraphics.so.pv2.4). You've got an old installation, that is interfering with the other one? (or maybe it is the other way round) Bernhard
August 29, 2007, 12:44 |
Any ideas as to solutions? One
Steve McHale
Any ideas as to solutions? One way or the other? I'm relatively new at this, so I appreciate your help guys. Thanks.
~Steve |
August 29, 2007, 15:31 |
Really can't help you unless y
Rep Power: 21 |
Really can't help you unless you exactly tell us what procedure you followed for installation of OpenFOAM.
August 29, 2007, 15:39 |
Hi Steve!
Check with 'which
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Steve!
Check with 'which paraview' whether you are actually using the Paraview-version distributed with OpenFOAM (I don't think so). The problem you are seeing usually comes from another paraview-installation that 'shadows' the OpenFOAM-paraview, usually because it is found before that in the PATH or the LD_LIBRARY_PATH Either change those variables or get rid of the other installation
OpenFOAM14 for Mac OSX Darwin 104 | gschaider | OpenFOAM Installation | 118 | July 20, 2008 05:19 |
FindRefCell doesnt work in OpenFoam14 | oscar_j | OpenFOAM Bugs | 1 | August 18, 2007 21:21 |
Installation of OpenFOAM14 on Redhat Enterprise 14 | gtg627e | OpenFOAM Installation | 2 | July 23, 2007 10:37 |
Probes in OpenFOAM14 | otsuki | OpenFOAM Running, Solving & CFD | 2 | May 16, 2007 06:18 |
Port of OpenFOAM14 to FreeBSD | thierry | OpenFOAM Installation | 0 | April 28, 2007 09:36 |
