Cannot find liberty %3cIMG SRC%3d%22httpopenfoamcfdonlinecomforumcliparthappy gif%22 ALT%3d%22%22 BORDER%3d0%3e
Old   September 14, 2006, 04:36
Default Dear all I have installed O
Daniele Panara
panara is on a distinguished road
Dear all
I have installed OF 1.3 on a linux Debian AMD64 machine. Everthing works and I can run icoFoam without problems. When I try to compile my own application (icoFoam), it fails in the linking phase:
Making dependency list for source file icoFoam.C
SOURCE_DIR=.
SOURCE=icoFoam.C ; g++ -m64 -DlinuxAMD64 -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-30 -I/apps/prod/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/apps/prod/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -c $SOURCE -o Make/linuxAMD64Gcc4DPOpt/icoFoam.o
/apps/prod/OpenFOAM/OpenFOAM-1.3/wmake/bashScripts/mkObjectDir /data/home/didomax/OpenFOAM/didomax-1.3/applications/bin/linuxAMD64Gcc4DPOpt/ico Foam
g++ -m64 -DlinuxAMD64 -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-30 -I/apps/prod/OpenFOAM/OpenFOAM-1.3/src/finiteVolume/lnInclude -I/apps/prod/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC Make/linuxAMD64Gcc4DPOpt/icoFoam.o -L/apps/prod/OpenFOAM/OpenFOAM-1.3/lib/linuxAMD64Gcc4DPOpt \
-lfiniteVolume -lOpenFOAM -liberty -o /data/home/didomax/OpenFOAM/didomax-1.3/applications/bin/linuxAMD64Gcc4DPOpt/ico Foam
/usr/bin/ld: cannot find -liberty
collect2: ld returned 1 exit status
make: *** [/data/home/didomax/OpenFOAM/didomax-1.3/applications/bin/linuxAMD64Gcc4DPOpt/ic oFoam] Error 1
When I change in /apps/prod/OpenFOAM/OpenFOAM-1.3/wmake/rules/linuxAMD64Gcc4/general
the following line
GLIBS = -liberty
in
GLIBS = /apps/prod/OpenFOAM/linuxAMD64/gcc-4.1.0/lib/libiberty.a
the compilation has no problem at all.
Any idea?
panara is offline   Reply With Quote
Old   September 14, 2006, 05:24
Default That is fine. The supplied gcc
Mattijs Janssens
mattijs is on a distinguished road
That is fine. The supplied gcc installation contains that library.
You can make it a bit more general by specifying $(WM_COMPILER_DIR)/lib/libiberty.a
mattijs is offline   Reply With Quote
Old   September 14, 2006, 05:35
Default Ok, but gcc-4.1.0 has been i
Daniele Panara
Ok,
but gcc-4.1.0 has been installed and also the correct path has been setted correctly..
why it doesn't work with the old setting?
is that a bug?
I mean, in order to compile OF applications the option must be changed in
GLIBS = $(WM_COMPILER_DIR)/lib/libiberty.a
or there is something wrong just in my installation?
Daniele
Old   October 31, 2006, 05:05
Default Hi, On a different machine
Frank Bos
lr103476 is on a distinguished road
On a different machine than my working one, I ran into the same problem.
Did you solve this liberty problem, and ifso how?
Thanks and regards, Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   November 2, 2006, 05:18
Default Hi, I do not know if this t
Pascal Häußler
pascalhaeussler is on a distinguished road
I do not know if this topic is still of interest. I just want to post here how I fixed this problem:
The libiberty is part of the gnu binutils. I just had to install the binutils development files package in addition to the binutils and then everything worked fine.
Regards
Pascal
pascalhaeussler is offline   Reply With Quote
Old   August 10, 2007, 15:39
Default Thank you Pascal. I faced the
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Thank you Pascal. I faced the same problem:
I solved it by installing binutils-devel. My system runs 64 bit Scientific Linux 5.x (RHEL clone).
Once again, thanks very much!
msrinath80 is offline   Reply With Quote
FoamerrorprintStackFoam%3cIMG SRC%3d%22httpopenfoamcfdonlinecomforumclipartproudgif%22 ALT%3d%22O%22 BORDER%3d0%3estreamamp rengu OpenFOAM Running, Solving & CFD 5 March 3, 2009 11:19
Problem in generating too many pointsFoamerrorprintStackFoam%3cIMG SRC%3d%22httpopenfoamcfdonlinecomforumclipartproudgif%22 ALT%3d%22O%22 BORDER%3d0%3estreamamp marhamat OpenFOAM 0 August 6, 2008 04:49
Compiling liftDrag crashed with initc%3cIMG SRC%3d%22httpopenfoamcfdonlinecomforumclipartsadgif%22 ALT%3d%22%22 BORDER%3d0%3etext0x20 undefined reference to %60mainb sponiar OpenFOAM Running, Solving & CFD 2 January 17, 2008 05:00
%230 FoamerrorprintStackFoam%3cIMG SRC%3d%22httpopenfoamcfdonlinecomforumclipartproudgif%22 ALT%3d%22O%22 BORDER%3d0%3estreamamp nishant_hull OpenFOAM Running, Solving & CFD 18 October 30, 2007 14:52
%230 FoamerrorprintStackFoam%3cIMG SRC%3d%22httpopenfoamcfdonlinecomforumclipartproudgif%22 ALT%3d%22O%22 BORDER%3d0%3estreamamp guimch OpenFOAM Running, Solving & CFD 6 October 25, 2007 18:52
