Libstdcso6 ABI problem
Old   November 8, 2005, 11:08
Default I get the following message wh
Maka Mohu
maka is on a distinguished road
I get the following message when trying to run OpenFOAM in 32 bit mode on 64 bit machine. when I run "which gcc" it give me a location that is different than OpenFOAM/linux directory. It seems that it does not see /OpenFOAM/linux/gcc-4.0.1 as an installation directory that should be used instead of /usr/lib32/lib. Please, can any one tell what I should do?
icoFoam: /usr/lib32/libstdc++.so.6: version `CXXABI_1.3.1' not found (required by icoFoam)
icoFoam: /usr/lib32/libstdc++.so.6: version `CXXABI_1.3.1' not found (required by /home/maka/OpenFOAM/OpenFOAM-1.2/lib/linuxGcc4Opt/libcfdTools.so)
icoFoam: /usr/lib32/libstdc++.so.6: version `CXXABI_1.3.1' not found (required by /home/maka/OpenFOAM/OpenFOAM-1.2/lib/linuxGcc4Opt/libOpenFOAM.so)
icoFoam: /usr/lib32/libstdc++.so.6: version `CXXABI_1.3.1' not found (required by /home/maka/OpenFOAM/OpenFOAM-1.2/lib/linuxGcc4Opt/libmeshTools.so)
icoFoam: /usr/lib32/libstdc++.so.6: version `CXXABI_1.3.1' not found (required by /home/maka/OpenFOAM/OpenFOAM-1.2/lib/linuxGcc4Opt/libsampling.so)
icoFoam: /usr/lib32/libstdc++.so.6: version `CXXABI_1.3.1' not found (required by /home/maka/OpenFOAM/OpenFOAM-1.2/lib/linuxGcc4Opt/libtriSurface.so)
Thanks,
Maka
maka is offline   Reply With Quote
Old   November 9, 2005, 02:25
Default I noticed that WM_COMPILER_DIR
Maka Mohu
I noticed that WM_COMPILER_DIR is set wrong:
WM_COMPILER_DIR=/home/mhussin/OpenFOAM/linux/gcc-4.0.1-64
So, I corrected it to /linux/gcc-4.0.1/ but also this did not solve the problem.
/Maka
Old   November 9, 2005, 04:40
Default You probably don't have a gcc-
Mattijs Janssens
You probably don't have a gcc-4.0.1 in the correct position. Make sure WM_64 is not set and install everything as for a 32 bit machine.
Put some print statements in the .../OpenFOAM-1.2/.bashrc file if you want to find out exactly.
Old   November 10, 2005, 05:16
Default In the light of your suggestio
Maka Mohu
In the light of your suggestions. I found two ways to solve the problem. The cluster that we have has both 32 bit and 64 bit machines that "share the same file system". So the gcc 32 bit is installed in OpenFOAM/linux while the 64 bit version in OpenFOAM/linuxAMD64.
I noticed that when running in 32 bit mode on the 64 bit machine OpenFOAM expects the gcc files in OpenFOAM/linux$WM_COMPILER_ARCH. $WM_COMPILER_ARCH=-64 in that case. This is because in OpenFOAM-1.2/.bashrc, there exist the line:
if [ "$WM_COMPILER" = "Gcc4" ]; then
export WM_COMPILER_DIR=$WM_PROJECT_INST_DIR/$WM_ARCH/gcc-4.0.1$WM_COMPILER_ARCH
Since unpacking the gcc-4.0.1.linux.tgz in linux folder according the installation procedure, only create a folder named gcc-4.0.1 but NOT gcc-4.0.1-64 as expected by the above line in OpenFOAM-1.2/.bashrc. As a result there are two ways to solve the problem:
(1)- modify OpenFOAM-1.2/.bashrc to be:
in this way running 32 bit mode (either on 32 bit machine or 64 bit one) will use the same gcc folder;
(2) make two copies of the 32 bit gcc vesion inside OpenFOAM/linux directory:
gcc-4.0.1 (used when running in 32 bit mode on 32 bit machine)
gcc-4.0.1-64 (used when running in 32 bit mode on 64 bit machine)
Both solution worked for me. Solution (1) is better since one can run (in 32 bit mode) a parallel simulation on a combination of 32 bit and 64 bit machines if he can adjust some load factor to keep up with difference in the speed between different machines.
Many thanks for your suggestions,
Maka
Old   November 10, 2005, 09:51
Default I tried both solutions: Act
Maka Mohu
Actually both work fine when run (in 32 bit mode) a parallel simulation on a combination of 32 bit and 64 bit machines. The last statement that favors solution (1) is wrong.
Regards,
Maka.
Old   July 17, 2007, 20:40
Default Also the wmake compiler works
Oscar G
oscar_j is on a distinguished road
Also the wmake compiler works to you??
Try in $FOAM_APP/solvers/laplacianfoam directory,
Type> wmake
Thanks!
Oscar
oscar_j is offline   Reply With Quote
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 09:37
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Libstdcso6 cannot handle TLS data barryw OpenFOAM Installation 2 September 7, 2006 02:02
Error while loading shared libraries libstdcso6 maka OpenFOAM Installation 2 August 11, 2006 04:24
problem in solving "wave generation" problem san FLUENT 2 April 3, 2006 23:37
