I downloaded the OpenFOAM 1.4.
I downloaded the OpenFOAM 1.4. The build-in openmpi package is openmpi-1.2b3. Anyone know what b3 stands for? Is it a beta? Is it a early version than openmpi-1.2 ?
I need to use Openmpi-1.2 to test sth. What I did is copy openmpi-1.2 to the src/ in parallel with openmpi-1.2b3 and modified $WM_PROJECT_INST_DIR/.bashrc: -export OPENMPI_VERSION=1.2 instead of 1.2b3. rebuild the whole package with gnu4.1.0 on SLES10 using: wcleanAll Allmake The building was successful. However, I got run time error when running the icoFoam case: [huiyu@iqa-01 icoFoam]$ mpirun -n 2 -hostfile hosts icoFoam . cavity -parallel /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ icoFoam:601 terminated with signal 11 at PC=2aaaac243406 SP=7fffb1839a60. Backtrace: icoFoam:602 terminated with signal 11 at PC=2aaaac243406 SP=7fff1e5cc800. Backtrace: /home/huiyu/openfoam2/OpenFOAM/OpenFOAM-1.4/src/openmpi-1.2/platforms/linux64DPO pt/lib/libmpi.so.0(MPI_Comm_size+0x46)[0x2aaaac243406] /home/huiyu/openfoam2/OpenFOAM/OpenFOAM-1.4/lib/linux64DPOpt/openmpi-1.2/libPstr eam.so(_ZN4Foam7Pstream4initERiRPPc+0x24)[0x2aaaabad99c4] /home/huiyu/openfoam2/OpenFOAM/OpenFOAM-1.4/lib/linux64DPOpt/libOpenFOAM.so(_ZN4 Foam7argListC1ERiRPPcbb+0x317)[0x2aaaab71cce7] icoFoam(__gxx_personality_v0+0x29b)[0x41157b] /lib64/libc.so.6(__libc_start_main+0xf4)[0x3f2511c784] icoFoam(__gxx_personality_v0+0x119)[0x4113f9] /home/huiyu/openfoam2/OpenFOAM/OpenFOAM-1.4/src/openmpi-1.2/platforms/linux64DPO pt/lib/libmpi.so.0(MPI_Comm_size+0x46)[0x2aaaac243406] /home/huiyu/openfoam2/OpenFOAM/OpenFOAM-1.4/lib/linux64DPOpt/openmpi-1.2/libPstr eam.so(_ZN4Foam7Pstream4initERiRPPc+0x24)[0x2aaaabad99c4] /home/huiyu/openfoam2/OpenFOAM/OpenFOAM-1.4/lib/linux64DPOpt/libOpenFOAM.so(_ZN4 Foam7argListC1ERiRPPcbb+0x317)[0x2aaaab71cce7] icoFoam(__gxx_personality_v0+0x29b)[0x41157b] /lib64/libc.so.6(__libc_start_main+0xf4)[0x3f2511c784] icoFoam(__gxx_personality_v0+0x119)[0x4113f9] A seg fault in MPI_Comm_size which is a pretty trivial routine -something is very broken. Have anyone tested with openfoam 1.4 with openmpi-1.2? Any suggestions? Thanks, Huiyu |
