Home > Forums > OpenFOAM Installation
MPI question
Old   July 11, 2007, 09:20
Default Hello, I have installed Ope
Alessandro Spadoni
gtg627e is on a distinguished road
I have installed OpenFOAM-1.4 on a linux machine running on Redhat enterprise 4. I was able to complete the installation, and I'm now trying to setup the mpi capability.
I generated keys with ssh-keygen and I can connect to a second computer without passwords. The error I get after launching lamboot -v <myfile> is:
LAM 7.1.2 - Indiana University
n-1<6232> ssi:boot:base:linear: booting n0 (128.61.185.163)
The lamboot agent failed to read a message over a socket from the
newly-booted process. This should not happen (especially since TCP is
a guaranteed protocol).
*** PLEASE READ THIS ENTIRE MESSAGE, FOLLOW ITS SUGGESTIONS, AND
*** CONSULT THE "BOOTING LAM" SECTION OF THE LAM/MPI FAQ
*** (http://www.lam-mpi.org/faq/) BEFORE POSTING TO THE LAM/MPI USER'S
*** MAILING LIST.
You should probably check the following:
- Network connectivity: Ensure that messages can be passed reliably
over TCP using random ports.
- Environment / PATH settings: Ensure that you are running the same
version of LAM/MPI on all nodes. Sometimes premature disconnects
(and therefore this error message) may be caused if mismatched
versions of LAM are used on different nodes.
- Node health: Ensure that the host where the newly-booted process was
launched is healthy and still available on the network.
n-1<6232> ssi:boot:base:linear: aborted!
lamboot did NOT complete successfully
Do I need to install the lam verision that comes with OpenFOAM on all the machines that I will be running via OpenFOAM?
Thank you in advance
gtg627e is offline   Reply With Quote
Old   July 11, 2007, 09:40
Default If I'm not wrong, lamboot try
Francesco Del Citto
fra76 is on a distinguished road
If I'm not wrong, lamboot try to check if it can open a ssh connection with the other specified machines.
Basicly, it execute a command through ssh and check the standard error. Execute "lamboot -v" to have some more verbose output.
In my case, the error was due to the X11 forwarding.
I remeber I resolved it by using "ssh -x" as remote connection client. Check in the lamport documentation how to do this... I really don't remember what I did, and I'm not using that system anymore...
Hope this can be a starting point...
Francesco
fra76 is offline   Reply With Quote
Thread Tools
Trackbacks are On
C question kar OpenFOAM Running, Solving & CFD 26 May 20, 2008 06:05
Question concerning VOF Flora FLUENT 2 July 9, 2007 09:50
question about LES gino briganti FLUENT 3 June 27, 2005 06:05
The question about Y+ rambol CFX 2 November 7, 2002 10:40
Another UDF question Christian FLUENT 7 July 23, 2002 04:19
