Library problem on a 64bit machine wrong ELF class ELFCLASS32
Old   June 11, 2007, 07:29
Default Hello, I compiled and insta
Jan Goebel
jango is on a distinguished road
I compiled and installed OpenFoam 1.4 on a Fedora Core 6 X86_64 bit machine. running foamInstallationTest everything seems to work fine, but when I want to start FoamX I still have problems...
Output:
Checking basic setup...
Shell: bash
Host: Goebel
OS: Linux version 2.6.20-1.2952.fc6
User: GoebelJ
User_config: /home/GoebelJ/.bashrc
Foam_config: /home/GoebelJ/.OpenFOAM-1.4/bashrc sourced correctly.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/GoebelJ/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/GoebelJ/OpenFOAM/GoebelJ-1.4 yes no
$FOAM_JOB_DIR /home/GoebelJ/OpenFOAM/jobControl no yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/GoebelJ/OpenFOAM/OpenFOAM-1.4 yes yes yes
$FOAM_USER_APPBIN ....4/applications/bin/linux64Gcc4DPOpt yes yes no
$FOAM_APPBIN ....4/applications/bin/linux64Gcc4DPOpt yes yes yes
$WM_DIR .../GoebelJ/OpenFOAM/OpenFOAM-1.4/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH ...ebelJ/OpenFOAM/linux64/j2sdk1.4.2_05 yes yes no
$MICO_ARCH_PATH ...co-2.3.12/platforms/linux64Gcc4DPOpt yes yes yes
$LAM_ARCH_PATH ...lam-7.1.2/platforms/linux64Gcc4DPOpt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...AM/OpenFOAM-1.4/lib/linux64Gcc4DPOpt yes yes yes
$FOAM_USER_LIBBIN ...OAM/GoebelJ-1.4/lib/linux64Gcc4DPOpt yes yes no
Software versions
Software Version Location
gcc /home/GoebelJ/OpenFOAM/linux64/gcc-4.1.1/bin/gcc
java 1.4.2_05 /home/GoebelJ/OpenFOAM/linux64/j2sdk1.4.2_05/bin/java
gzip 1.3.5 /home/GoebelJ/OpenFOAM/linux64/gcc-4.1.1/bin/gzip
tar 1.3.5 /bin/tar
icoFoam ...OpenFOAM-1.4/applications/bin/linux64Gcc4DPOpt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_Goebel Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
Base configuration ok.
Critical systems ok.
[GoebelJ@Goebel bin]$ FoamX
Starting NameServer with inet:Goebel:1234 ...
nsd: error while loading shared libraries: libssl.so.0.9.7: wrong ELF class: ELFCLASS32
thank you for your help,
Jan
jango is offline   Reply With Quote
Wrong elfclass32 F.P. FLUENT 0 January 8, 2009 06:33
FoamX libXpso6 wrong ELF class error abanerj3 OpenFOAM Pre-Processing 2 May 18, 2008 15:32
64bit machine for CFX Ahlo CFX 1 February 7, 2008 16:30
Problems installing OpenFoam on a 64bit machine jango OpenFOAM Installation 1 June 4, 2007 14:53
runing Fluent with a 64bit machine Rucy FLUENT 1 November 17, 2005 08:51
