Installation problems Canbt open OpenFOAM13bashrc
Old   March 7, 2007, 11:03
Default Hello, I am a new user of l
dim
Dimitri
dim is on a distinguished road
I am a new user of linux and I have to work on OpenFOAM for my studies. But I cannot install it. I have allready unzip all files in proper directories. but when I start the installation, this is what I get :
dim@dim-laptop:~$ echo $SHELL
/bin/bash
dim@dim-laptop:~$ cd OpenFOAM/OpenFOAM-1.3/
dim@dim-laptop:~/OpenFOAM/OpenFOAM-1.3$ .OpenFOAM-1.3/bashrc
bash: .OpenFOAM-1.3/bashrc: Permission non accordée %% (which means that I do not have the permission)
dim@dim-laptop:~/OpenFOAM/OpenFOAM-1.3$ sh OpenFOAM-1.3/bashrc
sh: Can't open OpenFOAM-1.3/bashrc
So I do not know how to open OpenFOAM-1.3/bashrc and I cannot go on the setup.
Thank you for your help
PS : I am French, sorry for my English.
dim is offline   Reply With Quote
Old   March 7, 2007, 11:05
Default something more, I work on Ubun
dim
Dimitri
something more, I work on Ubuntu, I do not know if it is important for you.
Old   March 7, 2007, 11:13
Default you're missing a dot: .~/Op
Hrvoje Jasak
.~/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc
See it: at the beginning it says: dot space "name of file"
Hrv
Hrvoje Jasak
Old   March 7, 2007, 11:26
Default Thank you for your help. But w
dim
Dimitri
Thank you for your help. But when I type this, I have the result : Permission non accordée, so I am not allowed to access to it.
Or maybe I do not understand what you say. Is it the command you want me to type? if not, could you please tell me what I have to type.
Old   March 7, 2007, 11:33
Default Ok sorry I have just understoo
dim
Dimitri
Ok sorry I have just understood what you wanted to say.
Thank you very much, it works.
Old   March 7, 2007, 11:52
Default I need help again.. I tested
dim
Dimitri
I need help again..
I tested the installation with foamInstallationTest, and it returns it :
Executing bash:
Checking basic setup...
Shell: bash
Host: dim-laptop
OS: Linux version 2.6.17-10-generic
User: dim
User_config: /home/dim/.bashrc
FATAL ERROR: /home/dim/.OpenFOAM-1.3/bashrc does not appear to be sourced from:
/home/dim/.bashrc
You need the following at the end of your /home/dim/.bashrc file:
. /home/dim/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc
or equivalent depending on the location of the OpenFOAM installation.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/dim/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/dim/OpenFOAM/dim-1.3 yes no
$FOAM_JOB_DIR /home/dim/OpenFOAM/jobControl no yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/dim/OpenFOAM/OpenFOAM-1.3 yes yes yes
$FOAM_USER_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes no
$FOAM_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes yes
$WM_DIR /home/dim/OpenFOAM/OpenFOAM-1.3/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH /home/dim/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no
$MICO_ARCH_PATH ...mico-2.3.11/platforms/linuxGcc4DPOpt yes yes yes
$LAM_ARCH_PATH ...c/lam-7.1.1/platforms/linuxGcc4DPOpt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...FOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt yes yes yes
$FOAM_USER_LIBBIN .../OpenFOAM/dim-1.3/lib/linuxGcc4DPOpt yes yes no
Software versions
Software Version Location
gcc 4.1.0 /home/dim/OpenFOAM/linux/gcc-4.1.0/bin/gcc
java 1.4.2_05 /home/dim/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
gzip 1.3.5 /bin/gzip
tar 1.3.5 /bin/tar
icoFoam ...M/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_dim-laptop Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Unsuccessful_connection_refused* yes
FATAL ERROR: No remote shell available.
Foam1.3 enviroment requires either ssh and/or rsh.
Contact your system administrator.
The system test has evoked 2 fatal error(s).
Critical systems ok.
Review the output for warning messages and consult
the installation guide for trouble shooting.
Could you please tell me how to solve these fatal errors ? Sorry I do not understand lots of things whith linux...
Dim
Old   March 8, 2007, 03:15
Default Hi Dimitri, As it is right no
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Dimitri,
As it is right now, you may use OpenFOAM in serial, but first you have to type:
source ~/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc
Then you can use all the top level solvers available... probably you will try the tutorials.
To automate a little bit more, just do what foamTestInstallation says:
For parallel computations, you will need an rshd or sshd server running on your machine.
Dragos
dmoroian is offline   Reply With Quote
Old   March 9, 2007, 02:59
Default hi first y should show all f
hamdi
hamcer is on a distinguished road
hi
first y should show all files typing 'ls -a' command and type 'gedit bashrc' and the line recommanded in the readme and allwmake and test installation.
you will resol your pb
hamcer is offline   Reply With Quote
Old   March 9, 2007, 17:27
Default Hi, sorry for being so slow to
dim
Dimitri
Hi, sorry for being so slow to answer I was too busy.
Thank you, I have tested what you said, and it works.
Installation problems indy OpenFOAM Installation 7 April 3, 2009 09:40
Installation problems ianz8802 OpenFOAM Installation 37 January 30, 2009 13:20
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
Installation Problems honcho OpenFOAM Installation 0 January 14, 2008 10:48
Installation of Open foam 12 ds2taieb OpenFOAM Installation 1 January 15, 2006 23:46
