Getting OpenFOAM to coexist with an existing JAVA VM |
February 22, 2007, 04:06 |
Hi all,
Firstly, may I say
Nik Trevallyn-Jones
Hi all,
Firstly, may I say I am very impressed with what I've seen of OpenFOAM. I have a query regarding the installation - I hope it doesn't appear that I'm complaining. OpenFOAM runs fine for me (as far as I have tested), but the installation of OpenFOAM has broken my existing JAVA installation. I develop and use a lot of JAVA on my machine, and cannot afford to have JAVA broken by another application. Is there something I've done wrong, or can do differently to get OpenFOAM to coexist with my java installation? The problem is that the OpenFOAM .basrc unconditionally sets JAVA_HOME, JAVA_PATH and JAVA_ROOT to the OpenFOAM java installation dir. It also sets CLASSPATH to '.'. This breaks my other java applications which I wish to run using the VM (JDK 1.6) I have already installed in /usr/java/jdk, and with a CLASSPATH which includees various extensions including JMF and JOGL. One 'simple' solution which seems apparent is to have the various OpenFOAM tools source the .bashrc file, rather than relying on it being sourced *before* those tools are run. In this way, the OpenFOAM environment settings would be per-process, rather than for every shell I ever run. However, there is quite probably a better solution already provided, and if so I would be very thankful if someone could point me in the right direction. Thanks again for such a powerful took. Cheers! Nik. |
February 22, 2007, 04:34 |
There is no specific reason to
Mattijs Janssens
Rep Power: 26 |
There is no specific reason to use the OpenFOAM java version. Does it work out of the box with your java version? If not you can rebuild FoamX with your java. (Allwmake in $FOAM_UTILITIES/preProcessing/FoamX)
February 22, 2007, 04:52 |
Hi Mattijs,
Thank you for y
Nik Trevallyn-Jones
Hi Mattijs,
Thank you for your quick response. > Does it work out of the box with your java version? Yes, OpenFOAM works with the 1.6 VM that I already have (once I've fixed the environment variables). My problem isn't that OpenFOAM doesn't work; my problem is that if I source the OpenFOAM .bashrc from my regular .bashrc, then none of my other JAVA apps run. Does the 'make' you are suggesting rebuild the .bashrc file with different contents? If so, how do I get it to contain the values I need? As importantly, how do I get it to leave the CLASSPATH variable alone? Just to be clear: my problem is that ~/OpenFOAM/OpenFOAM-1.3/.bashrc changes the values of the following JAVA environment variables: JAVA_HOME, JAVA_PATH, JAVA_ROOT, CLASSPATH. The values that are set stop many other JAVA applications on my machine from running. Therefore, I am looking for a solution in which OpenFOAM has the values it needs for these variables, and my other JAVA applications have the values that they need, which I have previously configured. Thanks again for your time and help. Cheers! Nik |
February 22, 2007, 05:56 |
A simple work around would be
Dragos
Rep Power: 20 |
A simple work around would be to not source ~/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc in your ~/.bashrc file.
Whenever you want to run OpenFOAM, open an xterm and source ~/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc. This way you will restrict the environment variables to only one bash session which belongs to the xterm. The rest of the system will still use the old values. Dragos |
February 22, 2007, 07:13 |
The following snippet might gi
Mark Olesen
Rep Power: 40 |
The following snippet might give you want you need. NB: the indenting gets lost by the mailer.
# Java # ~~~~ # avoid altering exising configurations # compatability issues remain with the user if [ ! -d "$JAVA_HOME" ]; then case `uname -s` in Linux) export JAVA_HOME=$WM_PROJECT_INST_DIR/$WM_ARCH/j2sdk1.4.2_05 [ `uname -m` = ia64 ] && JAVA_HOME=/usr/java/j2sdk1.4.2 ;; SunOS) export JAVA_HOME=$WM_PROJECT_INST_DIR/$WM_ARCH/j2re1.4.2_05 ;; IRIX|IRIX64*) export JAVA_HOME=$WM_PROJECT_INST_DIR/$WM_ARCH/j2re1.4.1 ;; esac export JAVA_ROOT=$JAVA_HOME export JAVA_PATH=$JAVA_HOME export PATH=$JAVA_PATH/bin:$PATH export CLASSPATH=. fi |
February 22, 2007, 07:21 |
I do basically the sam
Takuya OSHIMA
Rep Power: 20 |
I do basically the same as Dragos. I have a line in my ~/.bashrc: alias foamSetup='if test "x$WM_PROJECT" != "xOpenFOAM"; then source ~/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc; fi' and run "foamSetup" in the terminal where I want to run OpenFOAM applications. Takuya |
Running Existing Code: Commands Grayed Out | Michael Rasche | FLUENT | 1 | July 25, 2012 07:11 |
How can i use an existing surface mesh? | Sebastian | CFX | 1 | February 29, 2008 09:51 |
return a value for not existing volume in .cse | Richard | CFX | 1 | March 19, 2007 11:51 |
creating spline along existing line cell? | guang ai | Siemens | 3 | September 4, 2006 02:33 |
Initializing using existing data | Ray | FLUENT | 2 | September 16, 2002 16:14 |
