FoamX does not start
Old   February 15, 2007, 02:14
Default I have installed openfoam on o
Andreas
lucian is on a distinguished road
I have installed openfoam on openSuse 10.2. 32-bit, console tools run fine too, but if I try to start FoamX I get the following error messages:
Starting NameServer with inet:linux-onb5:1234 ...
nsd: error while loading shared libraries: libelf.so.0: cannot open shared object file: No such file or directory
lucian is offline   Reply With Quote
Old   February 15, 2007, 03:53
Default nsd is under the Mico tree. Tr
Mattijs Janssens
mattijs is on a distinguished road
nsd is under the Mico tree. Try to reconfigure and recompile Mico (see the Mico section in $FOAM_SRC/Allwmake)
mattijs is offline   Reply With Quote
Old   February 15, 2007, 11:10
Default Hi, Andreas, Go to YaST in SU
JZ
jack2000 is on a distinguished road
Hi, Andreas,
Go to YaST in SUSE, search and insatll libelf. It works.
YaST -> Software -> Software Management
I use SUSE 10.1 and have simialr problem, This method can successfully solve the probelm.
Good luck!
Jack
jack2000 is offline   Reply With Quote
How to start FoamX in OF15 hsieh OpenFOAM Pre-Processing 7 December 29, 2008 01:27
CFX Pre don't Start Pascal CFX 1 February 22, 2007 06:41
A new RunFoamXHB problem canbt start FoamX alondono OpenFOAM Pre-Processing 0 January 26, 2007 22:14
Where do I start Akin Siemens 1 June 16, 2005 17:15
Cannot start using CFX-5.7.1 Atit CFX 8 February 16, 2005 06:40
