-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   Compilation error on IA64 g411 (http://www.cfd-online.com/Forums/openfoam-installation/57574-compilation-error-ia64-g411.html)
begou February 13, 2007 05:32
I'm still trying to compile Op
I'm still trying to compile OpenFOAM on an Altix server (IA64, SLES9, g++-4.1.1) after installing this new g++ version (4.1.1) as suggested on this forum.
Now, the compilation fails after several hours with these messages that I do not understand:
/scratch/begou/OpenFOAM-1.3/src/mico-2.3.11/platforms/linuxIA64Gcc4DPOpt/lib/lib micocoss2.3.11.a(CosNaming.o)(.text+0x22e1): In function `_Marshaller__seq_CosNaming_Binding::free(void*) const':
: undefined reference to `std::__default_alloc_template<true,>::_S_force_ne w'
/scratch/begou/OpenFOAM-1.3/src/mico-2.3.11/platforms/linuxIA64Gcc4DPOpt/lib/lib micocoss2.3.11.a(CosNaming.o)(.text+0x2321): In function `_Marshaller__seq_CosNaming_Binding::free(void*) const':
etc...
The command executed by Allwmake which produce these messages is:
/opt/gcc/bin/g++-4.1.1 -L/opt/gcc/lib -DlinuxIA64 -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-30 -I/scratch/begou/OpenFOAM-1.3/src/mico-2.3.11/platforms/linuxIA64Gcc4DPOpt/inclu de -I../FoamXServer -I/scratch/begou/OpenFOAM-1.3/src/triSurface/lnInclude -I/scratch/begou/OpenFOAM-1.3/src/meshTools/lnInclude -I/scratch/begou/OpenFOAM-1.3/src/dynamicMesh/lnInclude -I/scratch/begou/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC Make/linuxIA64Gcc4DPOpt/PatchToolServer.o Make/linuxIA64Gcc4DPOpt/IPatchToolServerImpl.o Make/linuxIA64Gcc4DPOpt/FoamXErrors.o Make/linuxIA64Gcc4DPOpt/LogEntry.o Make/linuxIA64Gcc4DPOpt/LogManager.o Make/linuxIA64Gcc4DPOpt/NameServer.o Make/linuxIA64Gcc4DPOpt/Orb.o Make/linuxIA64Gcc4DPOpt/Paths.o -L/scratch/begou/OpenFOAM-1.3/lib/linuxIA64Gcc4DPOpt \
-L/scratch/begou/OpenFOAM-1.3/src/mico-2.3.11/platforms/linuxIA64Gcc4DPOpt/lib -lmicocoss2.3.11 -lmico2.3.11 -ldl -lPatchToolServer -ltriSurface -ldynamicMesh -lmeshTools -lOpenFOAM -L/opt/gcc/lib -liberty -o /scratch/begou/OpenFOAM-1.3/applications/bin/linuxIA64Gcc4DPOpt/PatchToolServer
Any suggestions ?
Thanks for your help.
Patrick
hjasak February 13, 2007 05:41
You are having probles with th
You are having probles with the compiler or the standard C++ libraries that come with it. This usually happens when your environment mixes 32- and 64-bit stuff. Try compiling something trivial that uses STL and see what happens:
#include <iostream>
using namespace std;
int main()
cout << "Hello, world!" << endl;
return 0;
Hrv
begou February 13, 2007 06:23
My C++ compiler seems to work:
begou@kolmo: /opt/gcc/bin/g++-4.1.1 toto.C
begou@kolmo: ./a.out
Hello, world!
begou@kolmo: cat toto.C
#include <iostream>
int main()
return 0;
I also try he compiler with a generic class (string) successfuly.
string cc;
cin>>cc ;
cout<<cc<<endl;
I'm using the absolute PATH because g++-4.1.1 is not supported by SLES9 and I have compiled it from sources and installed ins /opt/gcc.
With OpenFoam wmake, I've tried to add -L/opt/gcc/lib at first place but it do not help anymore.
Patrick
