January 10, 2005, 10:02 |
Hello everybody,
I have a
Hello everybody,
I have a problem with installation of openFOAM, when i check my system by executing the script foamSystemcheck, I have an error message: cheking Networking: --------------------------------------- ping_localhost: Successuful ping_localhost: Successuful Test_rsh: Unsuccessuful, Connection refused* Test_ssh: Unsuccessuful, Connection refused* FATALERROR: No remote Shell available foam 2.3 environment requires passwordless ' ssh' and/or ' rsh' to current host Contact your system adminstrator I would to precise that i have only one pc, i'm not connected to a network and i have only 'ssh ' command help me, please Thanks in advance Noureddine |
January 10, 2005, 11:14 |
As far as I can remember the
As far as I can remember the 'passwordless' ssh/rsh is only required if you are want to run parallel or FoamX remotely.
Does your installation work? Mattijs |
January 10, 2005, 11:28 |
I had a similar problem - see
I had a similar problem - seemed that i needed to add the machine to the 'etc/hosts' file (SUSE v9.2). I.e. underneath where localhost is defined, i added the machine IP address and machine name.
January 13, 2005, 09:54 |
Hello missinjs
I installe
Hello missinjs
I installed foam but by checking the installation, I have this message: [root@localhost bin] #./foamInstallationTest Executing ./foamInstallationTest. Cheking basic setup… Shell : bash Host : localhost OS : linux version 2.6.3-4mdk User : nour User_Config : /root/.bashrc Foam_Config : /root/.OpenFOAM-1.0/bashrc sourced correctly Cheking main FOAM environment variables… Environment_variable Set_to_file_or_directory Valid Crit $WM_PROJECT_INST_DIR /root/OpenFOAM yes yes $WM_PROJECT_USER_DIR /root/OpenFOAM/nour-1.0 yes no $FOAM_JOB_DIR root/OpenFOAM/JobControl no yes Cheking the FOAM environment variables set on the PATH… Environment_variable Set_to_file_or_directory Valid Path Crit $WM_PROJECT_DIR /root/OpenFOAM-1.0 yes yes yes $FOAM_USER_APPBIN …M/nour-1.0/applications/bin/linuxOpt no no $FOAM _APPBIN ...enFOAM-1.0/applications/bin/linuxOpt yes yes yes $WM_DIR /root/OpenFOAM/OpenFOAM-1.0/wmake yes yes yes $FOAM_PATH ...actions/utilites/pre Processing/FoamX yes yes yes $DXROOT /root/OpenFOAM/linux/dx-4.3.2/dx no no $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH /root/OpenFOAM/linux/j2dsk1.4.2-05 yes yes no $MICRO_ARCH_PATH …o/src/micro-2.3.11/platforms/linuxOpt no yes $LAM_ARCH_PATH …1.0/src/lam-7.1.1/platforms/linuxOpt no yes $MPICH_ARCH_PATH --------- env variable not set--------------- no Cheking the FOAM environment variables set on the LD_LIBRARY_PATH… Environment_variable Set_to_file_or_directory Valid Path Crit $FOAM_LIBBIN /root/OpenFOAM/OpenFOAM-1.0/lib/linuxOpt yes yes yes $FOAM_USER_LIBBIN /root/OpenFOAM/nour-1.0/lib/linuxOpt no no $LAM_ARCH_PATH …1.0/src/lam-7.1.1/platforms/linuxOpt no yes Software versions Software Version location gcc 3.4.3 /root/OpenFOAM/linux/gcc-3.4.3/bin/gcc java 1.4.2-05 /root/OpenFOAM/linux/j2sdk1.4.2-05/bin/java dx *** not installed *** gzip 1.2.4 (18 Aug 93) compilation options DIRENT UTIME STDC_HEADERS HAVE_UNISTD_H gzip /bin/gzip tar /bin/tar icoFoam *** not installed *** CRITICAL ERROR Cheking file/directory permissions... Files/directory Set Reqd Crit Cheking networking… Action Result Crit Pinging_localhost Successful yes Pinging_localhost Successful yes Test_rsh Unsuccessful “ connection refused*” yes Test_ssh Unsuccessful “ connection refused*” yes FATAL ERROR : No remote shell available Foam -1.0 environment requires either ssh and/or rsh Contact your System administration The System test has evoke 1 fatal error(s) The foam installation contains 1 critical error(s) Review the output for warnings messages and consult the installation guide for trouble shooting. it seems that the dx is not installed, and the ssh always persists what is this dx? please help me thank you in advence Djeghri |
January 13, 2005, 10:14 |
Hello mattijs
sorry
Dje
Hello mattijs
sorry Djeghri Noureddine |
January 17, 2007, 18:44 |
I have a message very s
Richard Jones
Rep Power: 17 |
I have a message very similar to the first post.. I am running Ubuntu 6.10, and trying to get OpenFoam 1.3 to be friendly here is the message i recieved after trying to execute foamInstallationTest.. Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: Richard OS: Linux version 2.6.17-10-generic User: richard User_config: /home/richard/.bashrc Foam_config: /home/richard/.OpenFOAM-1.3/bashrc sourced correctly. ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/richard/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/richard/OpenFOAM/richard-1.3 yes no $FOAM_JOB_DIR /home/richard/OpenFOAM/jobControl no yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/richard/OpenFOAM/OpenFOAM-1.3 yes yes yes $FOAM_USER_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes no $FOAM_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes yes $WM_DIR .../richard/OpenFOAM/OpenFOAM-1.3/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH ...richard/OpenFOAM/linux/j2sdk1.4.2_05 no no $MICO_ARCH_PATH ...mico-2.3.11/platforms/linuxGcc4DPOpt yes yes yes $LAM_ARCH_PATH ...c/lam-7.1.1/platforms/linuxGcc4DPOpt yes yes yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...FOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt yes yes yes $FOAM_USER_LIBBIN ...nFOAM/richard-1.3/lib/linuxGcc4DPOpt yes yes no $LAM_ARCH_PATH ...c/lam-7.1.1/platforms/linuxGcc4DPOpt yes yes yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.1.2 WARNING: Conflicting installations: foam settings: /home/richard/OpenFOAM/linux/gcc-4.1.0/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR java 1.4.2 libgcj) WARNING: Conflicting installations: foam settings: /home/richard/OpenFOAM/linux/j2sdk1.4.2_05/bin/java current path : /usr/bin/java gzip 1.3.5 /bin/gzip tar 1.3.5 /bin/tar icoFoam ...M/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/icoFoam ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_Richard Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Unsuccessful_connection_refused* yes FATAL ERROR: No remote shell available. Foam1.3 enviroment requires either ssh and/or rsh. Contact your system administrator. ------------------------------------------------------------------------------- The system test has evoked 1 fatal error(s). The foam installation contains 1 critical error(s). Thanks in advance for your help! |
January 18, 2007, 03:08 |
Hi Richard,
just install ss
Jens Klostermann
Rep Power: 17 |
Hi Richard,
just install ssh or rsh client+server, e.g. openssh. Regards Jens |
January 18, 2007, 11:18 |
Also, (your main problem) it l
Eugene de Villiers
Rep Power: 21 |
Also, (your main problem) it looks like you did not install the linux components that are distributed with foam.
gcc 4.1.2 WARNING: Conflicting installations: foam settings: /home/richard/OpenFOAM/linux/gcc-4.1.0/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR Check the Foam installation instructions again. You need to download and install the linux/linuxAMD64 - subdirectory of third-party binary packs. |
