-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   Network_problem (http://www.cfd-online.com/Forums/openfoam-installation/57581-network_problem.html)
Djeghri Noureddine (Noureddine) January 10, 2005 11:02
Hello everybody, I have a
Hello everybody,
I have a problem with installation of openFOAM, when i check my system by executing the script foamSystemcheck, I have an error message:
cheking Networking:
ping_localhost: Successuful
Test_rsh: Unsuccessuful, Connection refused*
Test_ssh: Unsuccessuful, Connection refused*
FATALERROR: No remote Shell available
foam 2.3 environment requires
passwordless ' ssh' and/or ' rsh' to
current host
Contact your system adminstrator
I would to precise that i have only one pc, i'm not connected to a network and i have only 'ssh ' command
help me, please
Thanks in advance
Noureddine
Mattijs Janssens (Mattijs) January 10, 2005 12:14
As far as I can remember the
As far as I can remember the 'passwordless' ssh/rsh is only required if you are want to run parallel or FoamX remotely.
Does your installation work?
Mattijs
Andrew Heather (Heather) January 10, 2005 12:28
I had a similar problem - see
I had a similar problem - seemed that i needed to add the machine to the 'etc/hosts' file (SUSE v9.2). I.e. underneath where localhost is defined, i added the machine IP address and machine name.
Djeghri Noureddine (Noureddine) January 13, 2005 10:54
Hello missinjs I installe
Hello missinjs
I installed foam but by checking the installation, I have this message:
[root@localhost bin] #./foamInstallationTest
Executing ./foamInstallationTest.
Cheking basic setup…
Shell : bash
Host : localhost
OS : linux version 2.6.3-4mdk
User : nour
User_Config : /root/.bashrc
Foam_Config : /root/.OpenFOAM-1.0/bashrc sourced correctly
Cheking main FOAM environment variables…
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /root/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /root/OpenFOAM/nour-1.0 yes no
$FOAM_JOB_DIR root/OpenFOAM/JobControl no yes
Cheking the FOAM environment variables set on the PATH…
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /root/OpenFOAM-1.0 yes yes yes
$FOAM_USER_APPBIN …M/nour-1.0/applications/bin/linuxOpt no no
$FOAM _APPBIN ...enFOAM-1.0/applications/bin/linuxOpt yes yes yes
$WM_DIR /root/OpenFOAM/OpenFOAM-1.0/wmake yes yes yes
$FOAM_PATH ...actions/utilites/pre Processing/FoamX yes yes yes
$DXROOT /root/OpenFOAM/linux/dx-4.3.2/dx no no
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH /root/OpenFOAM/linux/j2dsk1.4.2-05 yes yes no
$MICRO_ARCH_PATH …o/src/micro-2.3.11/platforms/linuxOpt no yes
$LAM_ARCH_PATH …1.0/src/lam-7.1.1/platforms/linuxOpt no yes
$MPICH_ARCH_PATH --------- env variable not set--------------- no
Cheking the FOAM environment variables set on the LD_LIBRARY_PATH…
$FOAM_LIBBIN /root/OpenFOAM/OpenFOAM-1.0/lib/linuxOpt yes yes yes
$FOAM_USER_LIBBIN /root/OpenFOAM/nour-1.0/lib/linuxOpt no no
Software versions
Software Version location
gcc 3.4.3 /root/OpenFOAM/linux/gcc-3.4.3/bin/gcc
java 1.4.2-05 /root/OpenFOAM/linux/j2sdk1.4.2-05/bin/java
dx *** not installed ***
gzip 1.2.4 (18 Aug 93)
compilation options
DIRENT UTIME STDC_HEADERS HAVE_UNISTD_H
gzip /bin/gzip
tar /bin/tar
icoFoam *** not installed ***
CRITICAL ERROR
Cheking file/directory permissions...
Files/directory Set Reqd Crit
Cheking networking…
Action Result Crit
Pinging_localhost Successful yes
Test_rsh Unsuccessful “ connection refused*” yes
Test_ssh Unsuccessful “ connection refused*” yes
FATAL ERROR : No remote shell available
Foam -1.0 environment requires either ssh and/or rsh
Contact your System administration
The System test has evoke 1 fatal error(s)
The foam installation contains 1 critical error(s)
Review the output for warnings messages and consult
the installation guide for trouble shooting.
it seems that the dx is not installed, and the ssh always persists
what is this dx?
please help me
thank you in advence
Djeghri
Djeghri Noureddine (Noureddine) January 13, 2005 11:14
Hello mattijs sorry Dje
Hello mattijs
sorry
Djeghri Noureddine
richard January 17, 2007 19:44
Hi, I have a message very s
I have a message very similar to the first post..
I am running Ubuntu 6.10, and trying to get OpenFoam 1.3 to be friendly http://www.cfd-online.com/OpenFOAM_D...part/happy.gif
here is the message i recieved after trying to execute foamInstallationTest..
Checking basic setup...
Shell: bash
Host: Richard
OS: Linux version 2.6.17-10-generic
User: richard
User_config: /home/richard/.bashrc
Foam_config: /home/richard/.OpenFOAM-1.3/bashrc sourced correctly.
Checking main FOAM env variables...
$WM_PROJECT_INST_DIR /home/richard/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/richard/OpenFOAM/richard-1.3 yes no
$FOAM_JOB_DIR /home/richard/OpenFOAM/jobControl no yes
Checking the FOAM env variables set on the PATH...
$WM_PROJECT_DIR /home/richard/OpenFOAM/OpenFOAM-1.3 yes yes yes
$FOAM_USER_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes no
$FOAM_APPBIN ...-1.3/applications/bin/linuxGcc4DPOpt yes yes yes
$WM_DIR .../richard/OpenFOAM/OpenFOAM-1.3/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$JAVA_PATH ...richard/OpenFOAM/linux/j2sdk1.4.2_05 no no
$MICO_ARCH_PATH ...mico-2.3.11/platforms/linuxGcc4DPOpt yes yes yes
$LAM_ARCH_PATH ...c/lam-7.1.1/platforms/linuxGcc4DPOpt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...FOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt yes yes yes
$FOAM_USER_LIBBIN ...nFOAM/richard-1.3/lib/linuxGcc4DPOpt yes yes no
Software versions
Software Version Location
gcc 4.1.2
WARNING: Conflicting installations:
foam settings: /home/richard/OpenFOAM/linux/gcc-4.1.0/bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
java 1.4.2
libgcj)
foam settings: /home/richard/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
current path : /usr/bin/java
gzip 1.3.5 /bin/gzip
tar 1.3.5 /bin/tar
icoFoam ...M/OpenFOAM-1.3/applications/bin/linuxGcc4DPOpt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_Richard Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Unsuccessful_connection_refused* yes
FATAL ERROR: No remote shell available.
Foam1.3 enviroment requires either ssh and/or rsh.
Contact your system administrator.
The system test has evoked 1 fatal error(s).
The foam installation contains 1 critical error(s).
Thanks in advance for your help!
jens_klostermann January 18, 2007 04:08
Hi Richard, just install ss
Hi Richard,
just install ssh or rsh client+server, e.g. openssh.
Regards Jens
eugene January 18, 2007 12:18
Also, (your main problem) it l
Also, (your main problem) it looks like you did not install the linux components that are distributed with foam.
gcc 4.1.2
CRITICAL ERROR
Check the Foam installation instructions again. You need to download and install the linux/linuxAMD64 - subdirectory of third-party binary packs.
