January 9, 2007, 11:42 |
Hello I can't really go throug
clo
Rep Power: 17 |
Hello I can't really go through FoamX to work: here there is the error:
nsd: error while loading shared libraries: libelf.so.0: cannot open shared object file: No such file or directory I know it is a known error but after trying to fix it with other posts solutions I quit beacuse nothing worked I'm using suse 10 with OFoam 1.3; P4 1G ram Anybody has fixed it on Suse? thany ciao |
January 9, 2007, 12:43 |
Hi clo,
although I am debia
Holger Blasum
Hi clo,
although I am debian myself I'd guess http://www.rpmfind.net//linux/RPM/op...5-45.i586.html does the job for you. Download ftp://fr2.rpmfind.net/linux/opensuse/distribution/SL-10.1/inst-source/suse/i586/ libelf-0.8.5-45.i586.rpm then run (as root) rpm -i libelf-0.8.5-45.i586.rpm I have checked that it contains a /usr/lib/libelf.so.0. In case you already have that file and the problem persists, run "ldconfig" (as root). If the problem still persists, please post the error message and the output of "ls -la /usr/lib/libelf.so.*". HTH, Holger |
January 9, 2007, 13:05 |
Hi Holger, thank you for the h
clo
Rep Power: 17 |
Hi Holger, thank you for the hints! unfortunatly I can't try now but I will as soon as I can!I will post the results!
thanx ciao |
January 10, 2007, 04:17 |
Hi Holger, actually a simple i
clo
Rep Power: 17 |
Hi Holger, actually a simple installation of lielf via yast solved the problem...mhm...i feel stupid but I remember that I looked inside /usr/lib and libelf.so.0 was there! That's way I tried to do links and other stuff to make it work! I any case the problem is solved and what can I say...thanx!
ciao |
Boundary condition setting for water hammer proble | yizhou | FLUENT | 1 | October 12, 2007 12:16 |
FoamX libelfso0 | nunoinlux | OpenFOAM Bugs | 6 | September 11, 2007 20:13 |
Ubuntu and finding libelfso0 | shaun | OpenFOAM Installation | 3 | April 30, 2007 18:40 |
FoamX libelfso0 | mockealm | OpenFOAM Installation | 6 | June 29, 2006 15:37 |
Can I use LES to simulate steady combustion proble | Ai Yuanfang | FLUENT | 2 | September 20, 2004 20:54 |
