Compiling with Intel icc
Old   March 8, 2005, 08:47
Default Hi all, has already someone
gellert
Hi all,
has already someone tried to compile OpenFoam with Intels C++ compiler?
If yes, are there known problems? What do I need to change/adapt?
-marcus
Old   March 8, 2005, 10:22
Default Yes the Intel C++ compiler is
henry is on a distinguished road
Yes the Intel C++ compiler is supported and OpenFOAM should compile with it. However we did not get much if any speed improvement even for the Itanium 2 chip and so encourage people to use the latest gcc compiler instead.
henry is offline   Reply With Quote
Old   November 28, 2006, 12:31
Default Hi, I tried to compile OpenFO
Rolando Maier
rolando is on a distinguished road
I tried to compile OpenFOAM on an Intel Itanium machine with the icc 9.1. I set -gcc-version=410 to be compatible with the gcc version 4.1 I used before. Compiling "triSurface.C" following error occured:
SOURCE=triSurface/triSurface.C ; foamMpiCC -gcc-version=410 -DlinuxIA64 -DDP -wd654,819,1125,1476,1505,1572 -O3 -ftz -DNoRepository -I/home/cluster/t7861aa/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -KPIC -c $SOURCE -o Make/linuxIA64I64DPOpt/triSurface.o
triSurface/triSurface.C(733): error: type "Foam::List<t>::List [with T=Foam::labelledTri]" is not a class template
PrimitivePatch<labelledtri,>
triSurface/triSurface.C(733): error: "PrimitivePatch" is not a nonstatic data member or base class of class "Foam::triSurface"
triSurface/triSurface.C(735): error: expected a ")"
List<labelledtri>(0),
triSurface/triSurface.C(741): error: no default constructor exists for class "Foam::PrimitivePatch<foam::labelledtri,>"
Can anyone help me?
Thanks in advance
Rolando
rolando is offline   Reply With Quote
Old   November 28, 2006, 13:26
Default Well, mine compiles and runs f
Hrvoje Jasak
Well, mine compiles and runs fine - this is what I've got around line 733:
// Construct null
triSurface::triSurface()
triSurfacePatch
pointField(0)
patches_(0),
sortedEdgeFacesPtr_(NULL),
edgeOwnerPtr_(NULL)
What does your code say?
Hrv
Hrvoje Jasak
Old   November 28, 2006, 14:07
Default Hi Hrvoje, it needs a few hou
Rolando Maier
Hi Hrvoje,
it needs a few hours until I can access the Itanium machine again. IŽll tell you, if it will work.
By the way. Do I have to define triSurfacePatch or is it a member of OpenFOAM?
Rolando
Old   November 28, 2006, 14:13
Default Oh, I remmeberfixing a whole l
Hrvoje Jasak
Oh, I remmeberfixing a whole lot of those. In:
/home/hjasak/OpenFOAM/OpenFOAM-1.3/src/triSurface/triSurface/triSurfacePatch.H
there should be a typedef:
namespace Foam
typedef PrimitivePatch AB labelledTri, List, pointField AB triSurfacePatch;
(the stupid forum software does not like angled brackets so I've replaced them by AB - I'm sure you can follow).
From there onwards, you need to replace all explicit statements like:
with triSurfacePatch.
The compiler gets confused, but in any case it looks nicer like this.
Hrv
Hrvoje Jasak
Old   November 28, 2006, 14:16
Default Thaks Hrvoje, IŽll try it and
Rolando Maier
Thaks Hrvoje,
IŽll try it and tell you what happens.
Rolando
Old   November 29, 2006, 06:19
Default Hi, I tried using triSurfaceP
Rolando Maier
I tried using triSurfacePatch and everything works fine. Thanks for that Hrvoje.
IŽve one more fundamental question:
I set the path to the gcc 4.1.0 libraries into LD_LIBRARY_PATH. (Because the Intel compiler should perform compatible to gcc 4.1.0)
Otherwise I get an error like this:
SOURCE_DIR=OSspecific/Unix/signals
SOURCE=OSspecific/Unix/signals/sigFpe.C ; icpc -gcc-version=410 -DlinuxIA64 -DDP -wd654,819,1125,1476,1505,1572 -O3 -ftz -DNoRepository -DWM_PROJECT_VERSION='"'1.3'"' -I/home/cluster/t7861aa/OpenFOAM/OpenFOAM-1.3/src/zlib-1.2.1 -I/home/cluster/t7861aa/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude -IlnInclude -I. -KPIC -c $SOURCE -o Make/linuxIA64I64DPOpt/sigFpe.o
/usr/include/g++/sstream(181): error: identifier "_M_buf_size" is undefined
_M_buf_size = _M_string.size();
detected during:
instantiation of "std::basic_stringbuf<_chart,>::basic_stringbuf(co nst std::basic_stringbuf<_chart,>::__string_type &, std::ios_base::openmode={std::_Ios_Openmode}) [with _CharT=char, _Traits=std::char_traits<char>, _Alloc=std::allocator<char>]" at line 355
instantiation of "std::basic_istringstream<_chart,>::basic_istrings tream(const std::basic_istringstream<_chart,>::__string_type &, std::ios_base::openmode={std::_Ios_Openmode}) [with _CharT=char, _Traits=std::char_traits<char>, _Alloc=std::allocator<char>]"
/usr/include/g++/sstream(187): error: identifier "_M_buf_size_opt" is undefined
_M_buf_size_opt = 512;
detected during:
Is it legal what IŽm doing, to set the gcc lib-path in addition to the intel compiler path in order to avoid these errors?
Thanks in advance.
Rolando
Old   November 29, 2006, 06:38
Default Try using -cxxlib-icc as a com
Hrvoje Jasak
Try using -cxxlib-icc as a compiler option.
Hrv
Hrvoje Jasak
Old   November 29, 2006, 07:07
Default Thanks a lot Hrvoje, it seems
Rolando Maier
it seems to work.
Rolando
Intel compiling problem cosimobianchini OpenFOAM Installation 1 March 6, 2008 16:59
Compiling with Intel compiler icc90 hjasak OpenFOAM Installation 19 October 27, 2007 11:35
CPU:Intel 3.0E or 3.0C Andrew CFX 2 May 24, 2004 13:00
AMD MP vs INTEL Xeon Albert Siemens 6 February 19, 2003 09:50
INTEL vs. AMD Michael Bo Hansen CFX 9 June 19, 2001 16:54
