-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   Cygwin port computer crashed (http://www.cfd-online.com/Forums/openfoam-installation/57642-cygwin-port-computer-crashed.html)
hsieh May 31, 2006 06:53
Hi, Thanks a lot for doing
Thanks a lot for doing the cygwin port! This saves me the trouble of installing Linux on my laptop.
I installed the cygwin port last night by following the instruction - very clear instructions. Although, the cygwin does not support paraFoam, but, you can use foamToVTK then, use the windows version of paraview. The only thing not supported is FoamX. I think that it might be able to re-write FoamX by Visual Basics.
I ran the interFoam tutorial case (damBreak) three times. The first two times, my computer crashed at different time step. However, the run completed without any problem the third time. I disabled Screen Saver during the third run. Could this be the problem?
Pei
gschaider May 31, 2006 09:22
Might well be, but I havn't go
Might well be, but I havn't got a Cygwin-Foam-installation, so I can't reproduce that.
Try if the problem is reproducable (set the screen-saver-activation time to a low value; 1 min or so).
Anyway: if it's the screensaver-cygwin-interaction I'd think that it's more a problem of cygwin than of OpenFOAM (and that's really hard to track).
BTW: which version of windows
gschaider May 31, 2006 09:28
Just as I sent the last reply
Just as I sent the last reply it occured to me: You said laptop, right? Does the screen-saver send the machine into some kind of lowFrequency/PowerSaving-mode? I could imagine that Cygwin doesn't like that.
