Some problems with FoamX and libelf
Old   May 23, 2006, 23:02
Default Hi, Please help me. i use
Manuel Felipe Mejia De Alba
manuel is on a distinguished road
Please help me.
i use the foamInstalltest and i didn't have problems, but i can't use the FoamX because the libelf* no found.
somthing more, when i try to run runFoamX, command no found
before anything, thanks you
manuel is offline   Reply With Quote
Old   May 24, 2006, 01:56
Default It depends on the linux distri
Francesco Del Citto
fra76 is on a distinguished road
It depends on the linux distribution you are using (if you're using linux, of course).
On Fedora Core 4 and 5, the file /usr/lib/libelf-0.108.so and /usr/lib/libelf.so.1 are owned by the package elfutils-libelf, so you should install it with "yum install elfutils-libelf", if you don't have that library installed.
Moreover, FoamX looks for libelf.so.0. The solution is making a symbolic link to libelf.so.1, i.e. "ln -s /usr/lib/libelf.so.1 /usr/lib/libelf.so.0"
This works with FC4 and FC5 32bit. And with 64bit too.
If you are using another distribution, the solution could be different.
Francesco
fra76 is offline   Reply With Quote
Old   May 25, 2006, 23:01
Default Hi Francesco Thanks for you
Hi Francesco
Thanks for your help, everything without problems.
Now, i need only learn the program.
jajaj
Problems when starting FoamX OpenFOAM14 Suse102 weiste01 OpenFOAM Pre-Processing 2 July 5, 2007 15:08
FoamX ianz8802 OpenFOAM Installation 2 March 8, 2007 23:45
Run FoamX ghazi OpenFOAM Pre-Processing 7 July 9, 2006 14:48
FoamX problems with Java and Locale setting AMD64 geimerma OpenFOAM Installation 5 July 7, 2006 16:21
Problems wtih FoamX alexander OpenFOAM Installation 2 March 14, 2006 06:13
