Help I canbt run FoamX report Unable to contact name server error |
May 3, 2006, 01:14 |
hi, i compile the openfoam 1.3
shi lei
hi, i compile the openfoam 1.3 amd64 successful on suse 10 64bit. but when i run FoamX i got the following error message, i search the discussion site and can't find the solution! Somebody help me out, thanks !
below is the error message when i run FoamX ////////////////////////////////////////////////// cornerstone@mu:~> runFoamXHB Starting NameServer with inet:mu:1234 ... Starting FoamX Host Browser with inet:mu:1234 ... /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : FoamXHostBrowser Date : Apr 29 2006 Time : 11:32:36 Host : mu PID : 18986 Root : Case : Nprocs : 1 Caught FoamXError exception in FoamXHostBrowser::main(int argc, char **argv) : FoamXError "Caught CORBA::COMM_FAILURE exception in connect : Unable to contact name server." In function "FoamX::NameServer::connect(CORBA:RB_ptr pOrb)" in file "NameServer.C" at line 188 Finishing FoamXHostBrowser::main(int argc, char **argv) runFoamXHB : cleanup runFoamXHB: Killing name server nsd(pid 18983). /home/cornerstone/OpenFOAM/OpenFOAM-1.3/bin/runFoamXHB: line 66: 18983 Killed nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref </dev/null ////////////////////////////////////////////////// |
OpenFOAM141 FoamX and paraView problem on cluster server | seigi | OpenFOAM Installation | 1 | January 28, 2008 15:44 |
A new RunFoamXHB problem canbt start FoamX | alondono | OpenFOAM Pre-Processing | 0 | January 26, 2007 22:14 |
FoamX canbt find applications | ingaerme | OpenFOAM Pre-Processing | 8 | December 12, 2006 14:56 |
FoamX is unable to contact name server | chris1980 | OpenFOAM Pre-Processing | 1 | May 3, 2006 04:54 |
Gambit error : Unable to find Exceed X Server | Jarod | FLUENT | 2 | November 4, 2004 06:41 |
