Ssh problem for LAMMPI
Old   April 11, 2006, 13:13
Default Hi, I have run the damBreakFi
auvi
parallelauvi is on a distinguished road
I have run the damBreakFine case of the supplied tutorials but when i try to run it parallelly i get ERRORs ..
i have setup the other machine(for a 2 pc LAN) for ssh (using ssh-keygen and stuff) which requires no passwords when i login using the ssh client. i can run regular programs like "ls" like this:
"ssh foam19 ls" normally
and can't run like this:
"ssh foam19 tkill"
but when i login using ssh to foam19 i can invoke "tkill" and related LAM-MPI commands. the path for LAM-MPI is in the .bashrc file.
foam19 is the other machine.
Any help?
please.
Auvi
parallelauvi is offline   Reply With Quote
Old   April 11, 2006, 13:46
Default Not familiar with .bashrc but
Mattijs Janssens
mattijs is on a distinguished road
Not familiar with .bashrc but maybe just 'ssh' executes different different start-up files ( ~/.bash.login etc.)
ssh starts up 'login shell' according to the man page.
If you're really stuck add a 'set -x' to your dot files and work through the mass of output.
mattijs is offline   Reply With Quote
Old   April 12, 2006, 01:14
Default okay i solved the problem by e
auvi
okay i solved the problem by editing the global
/etc/bash.bashrc file adding the
. ($HOME ... ) line to the top
now the "ssh foam19 tkill" works
and lamboot -v <machines> runs without any errors
thanks Mattijis Jenssens
Auvi
Old   April 12, 2006, 01:28
Default sorry for the typo Thanks Ma
auvi
sorry for the typo
Thanks Mattijs Janssens
i was in a hurry.
auvi
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 09:37
Problem in Tutorial problem of fluent Phanindra FLUENT 5 April 17, 2007 09:57
problem in solving "wave generation" problem san FLUENT 2 April 3, 2006 23:37
LAMMPI troubles mer OpenFOAM Installation 4 September 13, 2005 05:41
Lammpi library hsing OpenFOAM Installation 1 September 1, 2005 22:53
