-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   RunFoamX error (http://www.cfd-online.com/Forums/openfoam-installation/57664-runfoamx-error.html)
chnrdu May 25, 2005 23:19
$ runFoamX ls: /home/ndt/Open
$ runFoamX
ls: /home/ndt/OpenFOAM/jobControl/runningJobs: No such file or directory
ls: /home/ndt/OpenFOAM/jobControl/finishedJobs: No such file or directory
Starting NameServer with inet:ndt09:1234 ...
/home/ndt/OpenFOAM/OpenFOAM-1.1/bin/runFoamXHB: line 122: nsd: command not found
Jobs overview (from $FOAM_JOB_DIR):
Running : 0
Finished : 0
Some of the jobs reported as running might actually no longer be running.
You can these remove old jobInfo using the FoamX ProcessEditor or with the
foamCheckJobs script.
(then nothing happens.)
mattijs May 26, 2005 13:48
It cannot find 'nsd' which is
It cannot find 'nsd' which is one of the mico executables and should be in the distribution.
If I do 'which nsd' I get
.../OpenFOAM/OpenFOAM-1.1.1/src/mico-2.3.11/platforms/linuxGcc4Opt/bin/nsd
(this is for a slightly different version though to the one you are running)
chrischiasson May 27, 2005 18:14
_I have the same problem_ unde
_I have the same problem_ under Fedora Core 3 (no updates). OpenFOAM is in /usr/local/OpenFOAM
which nsd
/usr/local/OpenFOAM/OpenFOAM-1.1/src/mico-2.3.11/platforms/linuxOpt/bin/nsd
I symlinked:
/usr/local/OpenFOAM/linux/gcc-3.4.3/bin to /usr/bin
and
/usr/local/OpenFOAM/linux/j2sdk1.4.2_05/bin to /usr/bin
What is the solution?
chnrdu June 2, 2005 03:26
Restart your computer, then tr
Restart your computer, then try it. I do nothing excpet restarting make it work well.
idefix3010 July 8, 2005 14:26
I had the same problem with th
I had the same problem with the nsd. I changed the directory but now I have '/home/birmes/OpenFOAM/OpenFOAM-1.1/bin/runFoamXHB: line 122: /home/birmes/OpenFOAM/OpenFOAM-1.1/src/mico-2.3.11/platforms/linuxOpt/bin/nsd: cannot execute binary file'
what can I do?
hamen July 14, 2005 01:38
I have the problem that shows
I have the problem that shows "Default name service could not be contacted".
Could anyone give me some suggestion, many thanks in advance.
$ runFoamX
Starting NameServer with inet:Emma:1234 ...
ls: /home/duxju/OpenFOAM/jobControl/runningJobs: No such file or directory
ls: /home/duxju/OpenFOAM/jobControl/finishedJobs: No such file or directory
Running : 0
Finished : 0
Starting FoamX Host Browser with inet:Emma:1234 ...
Exec : FoamXHostBrowser
Date : Jul 14 2005
Time : 06:36:54
Host : Emma
PID : 7481
Root :
Case :
Nprocs : 1
HostBrowser running.....
Using jar /home/duxju/OpenFOAM/OpenFOAM-1.1/applications/utilities/preProcessing/FoamX/lib /FoamX.jar
Using jar /home/duxju/OpenFOAM/OpenFOAM-1.1/applications/utilities/preProcessing/FoamX/lib /jlfgr-1_0.jar
FoamX.Exceptions.FoamXException: Default name service could not be contacted.
at FoamX.App.initialiseHostBrowser(App.java:512)
at FoamX.App.initialise(App.java:343)
at FoamX.App.main(App.java:186)
Checking basic setup...
Shell: bash
Host: Emma
OS: Linux version 2.6.11-1.1369_FC4
User: duxju
User_config: /home/duxju/.bashrc
Foam_config: /home/duxju/.OpenFOAM-1.1/bashrc sourced correctly.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/duxju/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/duxju/OpenFOAM/duxju-1.1 yes no
$FOAM_JOB_DIR /home/duxju/OpenFOAM/jobControl no yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/duxju/OpenFOAM/OpenFOAM-1.1 yes yes yes
$FOAM_USER_APPBIN .../duxju-1.1/applications/bin/linuxOpt yes yes no
$FOAM_APPBIN ...enFOAM-1.1/applications/bin/linuxOpt yes yes yes
$WM_DIR /home/duxju/OpenFOAM/OpenFOAM-1.1/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH /home/duxju/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no
$MICO_ARCH_PATH ...1/src/mico-2.3.11/platforms/linuxOpt yes yes yes
$LAM_ARCH_PATH ...1.1/src/lam-7.1.1/platforms/linuxOpt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...u/OpenFOAM/OpenFOAM-1.1/lib/linuxOpt yes yes yes
$FOAM_USER_LIBBIN ...uxju/OpenFOAM/duxju-1.1/lib/linuxOpt yes yes no
Software versions
Software Version Location
gcc 3.4.3 /home/duxju/OpenFOAM/linux/gcc-3.4.3/bin/gcc
java 1.4.2_05 /home/duxju/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
gzip 1.3.5 /usr/bin/gzip
tar 1.3.5 /bin/tar
icoFoam ...penFOAM/OpenFOAM-1.1/applications/bin/linuxOpt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_Emma Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
Base configuration ok.
Critical systems ok.
hamen July 18, 2005 14:58
none response? http://www.cfd-
none response? http://www.cfd-online.com/OpenFOAM_D...lipart/sad.gif
mattijs July 19, 2005 05:06
Try and change the port number
Try and change the port number. Run runFoamXHB by itself, check for any errors and if nsd is still running.
Then run runFoamX (which should detect a running runFoamXHB/nsd)
hamen July 19, 2005 10:50
Hi Mattijs, Thanks for your
Hi Mattijs,
Thanks for your guidence, but i didn't catch what you mean. What is the 'port number' and how to change it? Could you explain a little bit more detail?
I input 'runFoamXHB', which came out as follows:
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Date : Jul 19 2005
Time : 15:44:02
Host : Emma
PID : 6031
Root :
Case :
Nprocs : 1
And then it hangs there :S
mattijs July 19, 2005 15:05
port number: in your $FOAMX_US
port number: in your $FOAMX_USER_CONFIG/FoamXClient.cfg file uncomment and change the
org.omg.CORBA.ORBInitialPort=1234
setting.
Now open a second shell and runFoamX in that. It should find the ns.ref file which runFoamXHB has written (check for that one as well) and ask whether you want to use that one.
You can put some print statements in both scripts to find out exactly what it does.
hamen July 20, 2005 08:04
Hi Mattijs, Thanks again.
Hi Mattijs,
Thanks again.
I uncommented and changed the port, and i runFoamXHB in one terminal, the result was same as before that it hung there.
I opened another terminal tab and runFoamX, it was what you said, it detected a running nsd as follows:
Warning: a server already seems to be running.
(Detected server reference /home/duxju/OpenFOAM/OpenFOAM-1.1/.OpenFOAM-1.1/apps/FoamX/ns.ref)
Do you want to kill this server ? (n)
Then, either i chose yes or no, the results were same as the situation i post firstly,
Running : 0
Finished : 0
$ cat ns.ref
IOR:010000002b00000049444c3a6f6d672e6f72672f436f73 4e616d696e672f4e616d696e67436f 6e746578744578743a312e30000002000000000000002f0000 0001010000160000006c6f63616c68 6f73742e6c6f63616c646f6d61696e00b0040b0000004e616d 655365727669636500010000002400 00000100000001000000010000001400000001000000010001 00000000000901010000000000
what are these codes?
rmorgans April 11, 2006 21:40
Hi all, I have the same pro
Hi all,
I have the same problem as Georg Birmes (http://www.cfd-online.com/cgi-bin/Op...=3070#POST3070) when trying to run FoamX on knoppix.
I installed the openfoam1.3 from the website. When I run FoamX it somes up with an error that ends with...
I've moved the the appropriate directory in mico and run it by hand (i.e. typed nsd) and I get the same error as above. Does anyone have any ideas as to what this could be?
I thought it might not be compiled correctly and did a Allwmake or whatever to recompile openfoam... didn't help.
I did a ./configure and make in the mico subdirectory.
I have ssh running.
I can ping my machine (knoppix) and localhost by hand - for some reason it doesn't work in the installation check script.
Not sure where to go from here... any ideas?
Cheers and best regards
Rick Morgans
