Build OpenFOAM on Tru64
Old   March 17, 2005, 11:55
Default Hi all, I want to install O
Francois Beaubert
francois is on a distinguished road
Hi all,
I want to install OpenFoam on Compaq Tru64 UNIX V5.1B (alpha proc).
Perhaps someone as done it before ?
Any help will be welcome.
I will send a post if it works !
Thank's
Francois
francois is offline   Reply With Quote
Old   April 7, 2005, 07:02
Default Hi Francois, I will start t
Nils Ellendt
nils is on a distinguished road
Hi Francois,
I will start to do the same next week. I will also post here, if it works, or when I get to problems, what they are.
I hope it works, this would save me a lot of time...
nils is offline   Reply With Quote
Old   April 7, 2005, 10:25
Default Hi, Actoally, there is a po
Hrvoje Jasak
Actoally, there is a port being done on lemieux at the moment, which is one of the big Dec machines. I have revived the dec build setup, but there are minor problems with handling a local optimized version of MPI. If you're building on a "normal" Dec, please let me know and I can pass over the setup files.
Some direct communication will be necessary and I assume you know about how to set up the build system in foam for a new architecture.
Hrv
Hrvoje Jasak
Old   April 8, 2005, 05:37
Default Hi, I'm sorry but I'm very
Francois Beaubert
I'm sorry but I'm very busy at work for the moment and don't have the time to do anything despite courses for the student. Last weeks I only try to build gcc 3.4.3 on tru64 but it fails to compil ... so you see where I'm at the moment ...
Old   April 27, 2005, 08:59
Default Hi Hrvoje, Since we also ha
Steffen Jahnke
steja is on a distinguished road
Hi Hrvoje,
Since we also have some "normal" DEC-Alpha workstations available we would like to install and run OpenFOAM on these machines. What steps need to be done for running on Compaq Tru64 UNIX V5.1A. Could you also pass the setup-files please. Are there any problems with "normal"-mpi or any other difficulties we should know about?
Thank you, Steffen
steja is offline   Reply With Quote
Old   April 28, 2005, 06:23
Default Hi, I don't really want to
Hrvoje Jasak
I don't really want to get involved in porting onto a machine I haven't got access to (and there is a lot of other things I should be doing anyway) :-), but here's some help.
1) You will need to know how to set up a new machine. Entries are required in:
~/.OpenFOAM-1.1/cshrc
and
~/OpenFOAM/OpenFOAM-1.1/.cshrc
Have a look at the stuff for other machines
2) I can send you a decAlphaGcc pack for wmake - this goes into:
~/OpenFOAM/OpenFOAM-1.1/wmake/rules
(again, see other machines for examples).
Make sure you've got gnu flex, bison, gmake, gzip and gtar - Decs are very bad for standard tools.
As for the pack, send me and E-mail on h dot jasak at dial dot pipex dot com and I'll E-mail it back to you.
Good luck,
Hrv
Hrvoje Jasak
Old   June 3, 2005, 10:34
Default Hi, we managed to compile g
Steffen Jahnke
we managed to compile gcc-3.4.3 and OpenFOAM on our Tru64-system. We used MPICH-1.2.6 instead of
LAM-7.1.1, because LAM did not work (the
dynamic linker reported errors)
The tutorials run fine on a single CPU. We then wanted to run a parallel case on 16 CPUs. Therefore we modified the channel395-example and raised the resolution up to 1.9 million cells.
After starting with mpirun we get the following message. We do not understand this (each node has 2GB of RAM) and perhaps it is not really related to too few memory.
Is there a way to get more debugging information, e.g. from which node the message is coming? We compiled OpenFOAM with the Debug-option (binaries are in decAlphaGccDebug directory)
Create time
Create mesh for time = 0
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library
Reading transportProperties
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Creating field Umean
Creating field R
Creating field Bmean
p6_64149: p4_error: net_recv read: probable EOF on socket: 1
p3_38962: p4_error: net_recv read: probable EOF on socket: 1
Abort process (core dumped)
p4_65343: p4_error: net_recv read: probable EOF on socket: 1
p2_69004: p4_error: net_recv read: probable EOF on socket: 1
p5_66369: p4_error: net_recv read: probable EOF on socket: 1
p15_61113: p4_error: Found a dead connection while looking for messages: 14
p9_76100: p4_error: Found a dead connection while looking for messages: 0
p10_51041: p4_error: Found a dead connection while looking for messages: 14
p8_67906: p4_error: Found a dead connection while looking for messages: 0
rm_l_14_69388: (363.472656) wakeup_slave: unable to interrupt slave 0 pid 69387
Old   June 3, 2005, 10:46
Default For easier parallel debugging
Mattijs Janssens
mattijs is on a distinguished road
For easier parallel debugging have a look at the lamrun script which I posted some time ago. It will run every process in its own window inside gdb.
- are you sure you use the -parallel command line argument? How big are the processor* directory meshes? (just run checkMesh on them)
mattijs is offline   Reply With Quote
Old   September 13, 2005, 06:00
Default Steffen, In your previous p
Francois Beaubert
Steffen,
In your previous post you have said that you "managed to compile gcc-3.4.3 and OpenFOAM on our Tru64-system".
I have gcc-3.4.3 up and running, but try to compile OpenFOAM on Tru64. Assuming you are using the bash shell, please could you explain us what you have done with those files:
- ~/.OpenFOAM-1.1/bashrc to add a check for True64-system and set WM_ARCH and WM_MPLIB
- ~/OpenFOAM/OpenFOAM-1.1/.bashrc
- $WM_DIR/rules/$WM_ARCH
Thank's four your help.
Francois
Old   September 14, 2005, 10:21
Default Some news ... Thank's to H
Francois Beaubert
Some news ...
Thank's to Hrvoje Jasak I'm trying to build OpenFOAM1.2 on tru64 with the wmake/rule he send to me. For the moment it's compiling and everything seems to be ok ...
So, if someone is interested the folowing procedures may be helpfull:
Assuming you are using the bash shell you must test your system type and modify some variables in
* ~/OpenFOAM/OpenFOAM-1.2/.OpenFOAM-1.2/bashrc add the lines before "# An unsupported operating system"
# Tru64 workstation
elif [ "$machineTest" = "OSF1" ]; then
export WM_ARCH=tru64
#export WM_MPLIB=LAM
export WM_MPLIB=MPI
* ~/OpenFOAM/OpenFOAM-1.2/.bashrc add the PATH for JAVA before "# An unsupported operating system"
# Tru64 workstation
export JAVA_HOME=/usr/opt/java14
* create the directory ~/OpenFOAM/OpenFOAM-1.2/wmake/rules/tru64Gcc
and put the wmake/rules from the attached to this post in this directory. I hope I'm not wrong but I think that the name of this directory depends on the WM_ARCH variable you have set previously in
* be sure you have gcc, gnu flex, bison, gmake, gzip and gtar in your PATH.
* Then go to ~/OpenFOAM/OpenFOAM-1.2/ and try ./Allwmake
Good luck.
Francois
Old   September 14, 2005, 10:30
Default oup's the attachment didn't wo
  #11
Francois Beaubert
oup's the attachment didn't work
Next try
tru64Gcc.tar.gz
Old   September 21, 2005, 11:10
Default Hi all, Last night I try to
  #12
Francois Beaubert
Hi all,
Last night I try to build OpenFOAM-1.2 with gcc-4.0.1. But I got errors during the building process. I'm an old Fortran developper so the messages aren't very helpfull to me ... if there is any c++ guru here, they are welcome !
* The first error come with makeInterpolationCellPoint.C:
SOURCE=interpolations/interpolation/interpolationCellPoint/makeInterpolationCell Point.C ; g++ -DFOAM_EXCEPTION -Dtru64 -Dtru64GccOpt -DscalarMachine -DoptSolvers -Wall -O2 -fno-schedule-insns -DNoRepository -ftemplate-depth-17 -DWM_PROJECT_VERSION='"'1.2'"' -I/data2/beaubert/OpenFOAM/OpenFOAM-1.2/src/zlib-1.2.1 -I/data2/beaubert/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -c $SOURCE -o Make/tru64GccOpt/makeInterpolationCellPoint.o
/data2/beaubert/usr/local/lib/gcc/alphaev7-dec-osf5.1b/4.0.1/../../../../include /c++/4.0.1/bits/cpp_type_traits.h:352: error: template instantiation depth exceeds maximum of 17 (use -ftemplate-depth-NN to increase the maximum) instantiating 'struct std::__traitor<std::__is_arithmetic<foam::label>, std::__is_pointer<foam::label> >'
/data2/beaubert/usr/local/lib/gcc/alphaev7-dec-osf5.1b/4.0.1/../../../../include /c++/4.0.1/bits/cpp_type_traits.h:352: instantiated from 'std::__is_scalar<foam::label>'
Foam::interpolationCellPoint<foam::scalar>, Type = Foam::scalar]'
interpolations/interpolation/interpolationCellPoint/makeInterpolationCellPoint.C :38: instantiated from here
/data2/beaubert/usr/local/lib/gcc/alphaev7-dec-osf5.1b/4.0.1/../../../../include /c++/4.0.1/bits/cpp_type_traits.h:352: error: invalid use of undefined type 'struct std::__traitor<std::__is_arithmetic<foam::label>, std::__is_pointer<foam::label> >'
/data2/beaubert/usr/local/lib/gcc/alphaev7-dec-osf5.1b/4.0.1/../../../../include /c++/4.0.1/bits/cpp_type_traits.h:110: error: declaration of 'struct std::__traitor<std::__is_arithmetic<foam::label>, std::__is_pointer<foam::label> >'
/data2/beaubert/usr/local/lib/gcc/alphaev7-dec-osf5.1b/4.0.1/../../../../include /c++/4.0.1/bits/stl_algobase.h:443: error: '__simple' is not a valid template argument for type 'bool' because it is a non-constant expression
/data2/beaubert/usr/local/lib/gcc/alphaev7-dec-osf5.1b/4.0.1/../../../../include /c++/4.0.1/bits/stl_algobase.h:443: error: 'copy_b' is not a member of '<declaration>'
make: *** [Make/tru64GccOpt/makeInterpolationCellPoint.o] Error 1
* There is lot of errors like the previous one, but I also got errors with lib that are not found (maybe becasue of the previous errors), like this one:
cd Make/tru64GccOpt ; \
gcc -DFOAM_EXCEPTION -Dtru64 -Dtru64GccOpt -DscalarMachine -DoptSolvers -Wall -O2 -fno-schedule-insns -DNoRepository -ftemplate-depth-17 -I/data2/beaubert/OpenFOAM/OpenFOAM-1.2/src/meshTools/lnInclude -I/data2/beaubert/OpenFOAM/OpenFOAM-1.2/src/lagrangian/basic/lnInclude -I/data2/beaubert/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -Xlinker -expect_unresolved -Xlinker '*' -shared pointAddressing.o samplingLine.o cuttingPlane.o curve.o graph.o rawGraph.o gnuplotGraph.o xmgrGraph.o jplotGraph.o writePatchGraph.o writeCellGraph.o makeGraph.o meshToMesh.o calculateMeshToMeshAddressing.o calculateMeshToMeshWeights.o -L/data2/beaubert/OpenFOAM/OpenFOAM-1.2/lib/tru64GccOpt -lmeshTools -llagrangian -o /data2/beaubert/OpenFOAM/OpenFOAM-1.2/lib/tru64GccOpt/libsampling.so
/usr/bin/ld:
Can't locate file for: -lmeshTools
collect2: ld returned 1 exit status
make: *** [/data2/beaubert/OpenFOAM/OpenFOAM-1.2/lib/tru64GccOpt/libsampling.so] Error 1
* And this one :
gcc -DFOAM_EXCEPTION -Dtru64 -Dtru64GccOpt -DscalarMachine -DoptSolvers -Wall -O2 -fno-schedule-insns -DNoRepository -ftemplate-depth-17 -I/data2/beaubert/OpenFOAM/OpenFOAM-1.2/src/meshTools/lnInclude -I/data2/beaubert/OpenFOAM/OpenFOAM-1.2/src/sampling/lnInclude -I/data2/beaubert/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -Xlinker -expect_unresolved -Xlinker '*' -shared findRefCell.o adjustPhi.o wallPointYPlus.o nearWallDistNoSearch.o nearWallDist.o wallDist.o reflectionVectors.o wallDistReflection.o bound.o totalPressureFvPatchScalarField.o wallBuoyantPressureFvPatchScalarField.o pressureTransmissiveFvPatchScalarField.o supersonicFreestreamFvPatchVectorField.o turbulentInletFvPatchFields.o timeVaryingUniformFixedValueFvPatchFields.o oscillatingFixedValueFvPatchFields.o -L/data2/beaubert/OpenFOAM/OpenFOAM-1.2/lib/tru64GccOpt -lmeshTools -lsampling -o /data2/beaubert/OpenFOAM/OpenFOAM-1.2/lib/tru64GccOpt/libcfdTools.so
/usr/bin/ld:
make: *** [/data2/beaubert/OpenFOAM/OpenFOAM-1.2/lib/tru64GccOpt/libcfdTools.so] Error 1
What's wrong here ?
The gcc-4.0.1 version I use was build with gcc-3.4.3:
gcc -v
Using built-in specs.
Target: alphaev7-dec-osf5.1b
Configured with: ../gcc-4.0.1/configure --prefix=/data2/beaubert/usr/local --enable-languages=c,c++
Thread model: posix
gcc version 4.0.1
Old   September 21, 2005, 11:15
Default Change the template-depth opti
  #13
Mattijs Janssens
Change the template-depth option to say 30 like for the other ports.
The meshTools library was probably not built as a consequence of this so linking of other libraries failed.
Old   September 21, 2005, 11:24
Default Tank's Mattijs ! That's I w
  #14
Francois Beaubert
Tank's Mattijs !
That's I was trying at the moment but I only increase the template-depth option to 20 !
I will try a value of 30 ...
Old   September 21, 2005, 12:23
Default Thank's for your help Mattijs,
  #15
Francois Beaubert
Thank's for your help Mattijs, it works with a template-depth option to 30. But I'm now experiencing other problems when building OpenFOAM applications like potentialFoam below:
/data2/beaubert/OpenFOAM/OpenFOAM-1.2/wmake/kshScripts/mkObjectDir /data2/beaubert/OpenFOAM/OpenFOAM-1.2/applications/bin/t
ru64GccOpt/potentialFoam
mplate-depth-30 -I/data2/beaubert/OpenFOAM/OpenFOAM-1.2/src/cfdTools/incompressible -I/data2/beaubert/OpenFOAM/OpenFOAM-1.2
/src/cfdTools/general/lnInclude -I/data2/beaubert/OpenFOAM/OpenFOAM-1.2/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC Mak
e/tru64GccOpt/potentialFoam.o -L/data2/beaubert/OpenFOAM/OpenFOAM-1.2/lib/tru64GccOpt \
-lcfdTools -lOpenFOAM -lm -o /data2/beaubert/OpenFOAM/OpenFOAM-1.2/applications/bin/tru64GccOpt/potentialFoam
Foam::reduce(double&, Foam::sumOp<double> const&)
Foam:: OPstream::~OPstream()
Foam::IPstream::IPstream(int, int, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)
make: *** [/data2/beaubert/OpenFOAM/OpenFOAM-1.2/applications/bin/tru64GccOpt/potentialFoa m] Error 1
As anybody see this before ?
Old   September 22, 2005, 04:45
Default These routines are all in the
  #16
Mattijs Janssens
These routines are all in the Pstream library (which I assume you have compiled already). See if it links if you add a -lPstream to your link line.
If this solves the problem add it to all your link lines by adding it to your $WM_DIR/rules/ files. (see e.g. the solaris entry)
Old   September 22, 2005, 06:37
Default Thanks Mattijs for your help !
  #17
Francois Beaubert
Indeed the Pstream library was not in the path.
I add the following line to OpenFOAM/OpenFOAM-1.2/wmake/rules/tru64Gcc/general file:
GLIBS = -L$(FOAM_LIBBIN)/dummy -lPstream -lm
The next error was that gmake was not in my PATH. OpenFOAM need it in the OpenFOAM/OpenFOAM-1.2/src/Allwmake script. The make version I use is the gnu one but the executable is "make" not "gmake". So I rename it gmake and put it in my PATH.
and now it works expect some problems with FoamX:
FoamX
Starting NameServer with inet:fortune.univ-valenciennes.fr:1234 ...
Starting FoamX Host Browser with inet:fortune.univ-valenciennes.fr:1234 ...
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.2 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : FoamXHostBrowser
Date : Sep 22 2005
Time : 12:29:26
Host : fortune.univ-valenciennes.fr
PID : 311529
Root :
Case :
Nprocs : 1
HostBrowser running.....
Using jar /data2/beaubert/OpenFOAM/OpenFOAM-1.2/applications/utilities/preProcessing/FoamX /lib/FoamX.jar
Using jar /data2/beaubert/OpenFOAM/OpenFOAM-1.2/applications/utilities/preProcessing/FoamX /lib/jlfgr-1_0.jar
java.lang.NoClassDefFoundError: FoamX/App
/data2/beaubert/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: 311529 Killed
runFoamXHB : cleanup
runFoamXHB: Killing name server nsd(pid 317631).
/data2/beaubert/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: 317631 Killed
I use jre142 which is in my PATH defined in OpenFOAM/OpenFOAM-1.2/.bashrc as:
export JAVA_HOME=~/usr/local/jre142
I will see what can be done for this.
Next challange for me will be the lam or pmich support for OpenFOAM.
Thanks again for your very helpfull messages Mattijs, without you I could not be able to build OpenFOAM.
Old   September 22, 2005, 08:16
Default The problem "runFoamXHB: 31763
  #18
Francois Beaubert
The problem "runFoamXHB: 317631 Killed" is fixed now.
I only have to relog again ...
the next problem I had to deal with was this error when FoamX startup:
FoamX
Date : Sep 22 2005
Time : 13:43:19
PID : 347712
Root :
Case :
Nprocs : 1
/data2/beaubert/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: 347712 Killed
runFoamXHB: Killing name server nsd(pid 358130).
/data2/beaubert/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: 358130 Killed
As mentioned for the solaris port, the OpenFOAM/OpenFOAM-1.2/applications/utilities/preProcessing/FoamX/lib/FoamX.jar
doesn't contains the necessary stuf to start OpenFOAM. So I download FoamX.jar from the OpenFOAM-1.2.General.tgz archive for linux and replace it.
It works ...
Old   April 4, 2006, 05:45
Default I manage to install OpenFOAM1.
  #19
Francois Beaubert
I manage to install OpenFOAM1.2 on a dec-alpha cluster (Tru64 OS) of a friend.
I use my own build of OpenFOAM on Tru64 and make a tar of it and untar it on my friend's cluster.
But something is wrong with this new installation.
For example when I try to build foamToTecplot in foamToTecplot dir with wmake I've got the following error:
~/OpenFOAM/openf-1.2/applications/foamToTecplot]
openf@.....$ wmake
Make: Cannot open /home/sngetj/openf/OpenFOAM/OpenFOAM-1.2/wmake/Make/tru64GccOpt/options. Stop.
Well I dont know why wmake try to find Make/tru64GccOpt/options file in $WM_DIR because this file is the current dir.
The login shell is tcsh but I use bash as a working shell and configuration for OpenFOAM:
echo $WM_SHELL
tcsh
When I do . ~/.bashrc I've got an error:
Executing: /home/sngetj/openf/OpenFOAM/OpenFOAM-1.2/.bashrc
Executing: /home/sngetj/openf/OpenFOAM/OpenFOAM-1.2/.OpenFOAM-1.2/apps/ensightFoam/bashrc
Executing: /home/sngetj/openf/OpenFOAM/OpenFOAM-1.2/.OpenFOAM-1.2/apps/paraview/bashrc
bash: setenv: command not found
I dont know why this setenv is there for bash scripts ?!
I've tried to configure OpenFOAM for tcsh and modify those files to set the correct $WM_ARCH and $JAVA_HOME:
~/OpenFOAM/OpenFOAM-1.2/.cshrc
~/OpenFOAM/OpenFOAM-1.2/.OpenFOAM-1.2/cshrc
But the same error message occur when I try a wmake.
Any ideas?
Thank's
François
OpenFOAM 15 icc build mschoenberg OpenFOAM Installation 4 October 2, 2008 00:09
How can I build OpenFOAM in cygwin joywe OpenFOAM Installation 10 September 12, 2008 09:39
Build OpenFOAM on MacOSX Mauro Augelli (Augelli) OpenFOAM Installation 101 July 21, 2008 06:42
OpenFOAM 14 Parallel build mplongjr OpenFOAM Installation 3 May 15, 2007 03:32
OpenFOAM on OSF1 V51 tru64 andras OpenFOAM Installation 0 April 26, 2006 06:45
