1 fetal error in OpenFOAM12 installation
Old   February 25, 2006, 20:36
Default I have installed OpenFOAM1.2 i
Andy Cong
andycong is on a distinguished road
I have installed OpenFOAM1.2 in a P4 2.6,512M computer which is running a SUSE 9.3 operating system.
I did not unzip the OpenFOAM-1.2.linuxGcc4Opt file before installation, I only unzip the OpenFOAM-1.2.General file, and I built it by what the README file says.
When I test the installation by command "foamInstallationTest", I get the following report,in which there is 1 fatal error(s).
Please give me some advice,thank you!
Checking basic setup...
Shell: bash
Host: linux
OS: Linux version 2.6.11.4-20a-default
User: andycong
User_config: /home/andycong/.bashrc
FATAL ERROR: /home/andycong/.OpenFOAM-1.1/bashrc does not appear to be sourced from:
You need the following at the end of your /home/andycong/.bashrc file:
. /home/andycong/OpenFOAM/OpenFOAM-1.1/.OpenFOAM-1.1/bashrc
or equivalent depending on the location of the OpenFOAM installation.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/andycong/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/andycong/OpenFOAM/andycong-1.2 yes no
$FOAM_JOB_DIR /home/andycong/OpenFOAM/jobControl no yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/andycong/OpenFOAM/OpenFOAM-1.2 yes yes yes
$FOAM_USER_APPBIN ...ng-1.2/applications/bin/linuxGcc4Opt yes yes no
$FOAM_APPBIN ...AM-1.2/applications/bin/linuxGcc4Opt yes yes yes
$WM_DIR ...andycong/OpenFOAM/OpenFOAM-1.2/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH ...ndycong/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no
$MICO_ARCH_PATH ...c/mico-2.3.11/platforms/linuxGcc4Opt yes no yes
$LAM_ARCH_PATH ...src/lam-7.1.1/platforms/linuxGcc4Opt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...enFOAM/OpenFOAM-1.2/lib/linuxGcc4Opt yes yes yes
$FOAM_USER_LIBBIN ...enFOAM/andycong-1.2/lib/linuxGcc4Opt yes yes no
Software versions
Software Version Location
gcc 4.0.1 /home/andycong/OpenFOAM/linux/gcc-4.0.1/bin/gcc
java 1.4.2_05 /home/andycong/OpenFOAM/linux/j2sdk1.4.2_05/bin/java
gzip 1.3.5 /usr/bin/gzip
tar 1.3.5 /bin/tar
icoFoam ...OAM/OpenFOAM-1.2/applications/bin/linuxGcc4Opt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_linux Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
The system test has evoked 1 fatal error(s).
Critical systems ok.
Review the output for warning messages and consult
the installation guide for trouble shooting.
__________________________________________________ _
andycong is offline   Reply With Quote
Old   February 25, 2006, 20:46
Default That's a bug in the foamInstal
brooksmoses
That's a bug in the foamInstallationTest program; the "OpenFOAM-1.1" in that part of the test script should have been updated to "OpenFOAM-1.2", and it wasn't.
In any case, everything else looks fine, so I'd say that this looks like a successful installation.
Old   February 25, 2006, 20:50
Default See also this thread in the "O
brooksmoses
See also this thread in the "OpenFOAM bugs" section of the forum, where this is discussed. Apparently the entire foamInstallationTest script is the OpenFOAM-1.1 version:
http://www.cfd-online.com/cgi-bin/Op...how.cgi?1/1868
Old   February 26, 2006, 03:09
Default Thank you for your kindly help
Andy Cong
Thank you for your kindly help.
One more question:
I didn't unzip the OpenFOAM-1.2.linuxGcc4Opt file, so was there any influence about it?
Differences OpenFOAM12 and OpenFOAM13 lr103476 OpenFOAM Running, Solving & CFD 43 July 22, 2008 16:46
Installation error sukratu OpenFOAM Installation 6 September 16, 2007 22:46
Error after installation.. Nari Siemens 5 June 28, 2007 14:02
Installation Error rafal OpenFOAM Installation 3 February 2, 2006 11:43
OpenFoam12 on a linux cluster tsjb00 OpenFOAM Installation 5 September 10, 2005 19:44
