missing lnInclude files on gentoo ebuild installation |
June 19, 2009, 17:35 |
Rep Power: 16 |
I have installed openfoam on gentoo using the openfoam-1.5 ebuild. When I try to compile openfoam user libraries such as groovyBC the compile fails (see here ).
Im guessing this is because the compiler is looking for, and not finding, lnInclude files in the source tree, is this correct? If the lnInclude files are the missing link what is the easiest way to get them on a gentoo system? |
June 22, 2009, 03:59 |
#2 | |
Mark Olesen
Rep Power: 40 |
# default is pwd if [ "$#" -eq 0 ] then set -- . elif [ "$1" = "-h" -o "$1" = "-help" ] then echo "Usage: ${0##*/} [dir1] .. [dirN]" echo echo " Find directories containing a Make/ directory and" echo " execute 'wmakeLnInclude -f' for each one" echo exit 1 fi for checkDir do if [ -d $checkDir ] then echo "searching: $checkDir for 'Make' directories" else echo "skipping non-dir: $checkDir" continue fi find $checkDir -depth -type d -name Make -print | while read dir do dir=${dir%/Make} # trim /Make directory from the end if [ -d "$dir" ] then wmakeLnInclude -f $dir fi done done Something similar should be in a future release as 'wmakeLnIncludeAll'. |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
Monitor Files Missing | Forrest | FLUENT | 3 | March 24, 2009 16:11 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
