Hello and sorry about this lon
Hello and sorry about this long message!
I'm totally new in using OpenFoam. :-) I installed Openfoam 1.2 and the installation test passes without any faults, the icoFoam tutorial also runs without any problems: sleur@Wb:~/OpenFOAM/frank/run/tutorials/icoFoam> ./Allrun Running blockMesh on cavity Running icoFoam on cavity Cloning cavityFine case from cavity Running blockMesh on cavityFine Running mapFields from cavity to cavityFine Running icoFoam on cavityFine Running blockMesh on cavityGrade Running mapFields from cavityFine to cavityGrade Running icoFoam on cavityGrade Cloning cavityHighRe case from cavity Setting cavityHighRe to generate a secondary vortex Copying cavity/0* directory to cavityHighRe Running blockMesh on cavityHighRe Running icoFoam on cavityHighRe Running blockMesh on cavityClipped Running mapFields from cavity to cavityClipped Running icoFoam on cavityClipped fluentMeshToFoam: converting mesh elbow/elbow.msh Running icoFoam on elbow Running foamMeshToFluent on elbow Running foamDataToFluent on elbow But when I want to start FoamX: sleur@Wb:~/OpenFOAM/OpenFOAM-1.2/bin> FoamX Starting NameServer with inet:Wb:1234 ... /home/sleur/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: line 122: nsd: command not found By searching the board, I allready found the hint to change e.g. my port number in $FOAMX_USER_CONFIG/FoamXClient.cfg but this files and even the directory don't exist. Can you please help me or give me an hint!! :-) Thanks! PS: When I run icoFoam I get following message. sleur@Wb:~/OpenFOAM/OpenFOAM-1.2/bin> icoFoam /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.2 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : icoFoam Date : Sep 27 2005 Time : 11:26:40 Host : Wb PID : 16872 Usage: icoFoam <root> <case> [-parallel] --> FOAM FATAL ERROR : Wrong number of arguments, expected 2 found 0 FOAM exiting My foamInstallationTest: Executing /home/sleur/OpenFOAM/OpenFOAM-1.2/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: Wb OS: Linux version 2.6.13-9-smp User: sleur User_config: /home/sleur/.bashrc Foam_config: /home/sleur/.OpenFOAM-1.2/bashrc sourced correctly. ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/sleur/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/sleur/OpenFOAM/sleur-1.2 yes no $FOAM_JOB_DIR /home/sleur/OpenFOAM/jobControl yes yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/sleur/OpenFOAM/OpenFOAM-1.2 yes yes yes $FOAM_USER_APPBIN ...ur-1.2/applications/bin/linuxGcc4Opt yes yes no $FOAM_APPBIN ...AM-1.2/applications/bin/linuxGcc4Opt yes yes yes $WM_DIR /home/sleur/OpenFOAM/OpenFOAM-1.2/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH /home/sleur/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no $MICO_ARCH_PATH ...c/mico-2.3.11/platforms/linuxGcc4Opt yes yes yes $LAM_ARCH_PATH ...src/lam-7.1.1/platforms/linuxGcc4Opt yes yes yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...enFOAM/OpenFOAM-1.2/lib/linuxGcc4Opt yes yes yes $FOAM_USER_LIBBIN .../OpenFOAM/sleur-1.2/lib/linuxGcc4Opt yes yes no $LAM_ARCH_PATH ...src/lam-7.1.1/platforms/linuxGcc4Opt yes yes yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.0.1 /home/sleur/OpenFOAM/linux/gcc-4.0.1-64/bin/gcc java 1.4.2_05 /home/sleur/OpenFOAM/linux/j2sdk1.4.2_05/bin/java gzip 1.3.5 /usr/bin/gzip tar 1.3.5 /bin/tar icoFoam ...OAM/OpenFOAM-1.2/applications/bin/linuxGcc4Opt/icoFoam ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_Wb Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- Base configuration ok. Critical systems ok. |
C
Check whether you have nsd and whether you can execute it. (should be inside $FOAM_SRC/mico-xxx) Check all arguments to nsd in runFoamXHB script that they are set correctly. |
Hi, I have this nsd-problem on
Hi, I have this nsd-problem on my new AMD6 machine.
Installation went OK. In the mico-xxx I don't have nsd :-( How is this possible? and more important: What to do next? thanks in advance for any help, Joeri |
FoamX works here on my Suse 10
FoamX works here on my Suse 10. I suspect your problem is that mico did not build properly.
do: src cd $MICO_PATH rm -rf platforms make distclean ./configure --prefix=$MICO_ARCH_PATH --disable-shared --without-x make and see what the problem is. If it build correctly, do: make install and you're in business. Hrv |
Thanks for your response!
M
Meanwhile, I discovered that I did have nsd, but that the paths were incorrectly set. I removed 'AMD64' from several directory names, and now I can start FoamX without problems. It's probably better to add 'AMD64' in the variable-names that are used to generate the directory-names in the .bashrc-files. It seems to work now. I don't have time to run a test today, but I'll soon find out wheter or not this was the only problem. If not, I'll follow your procedure and eventually I'll rebuild mico. kind regards, Joeri |
Any paths that need to be adap
Any paths that need to be adapted in OpenFOAM setup scripts?
Cavityfine
I have another problem, and not to me mapFields cavity in the case of the tutorial. I think the error is that targe mesh size is 1600 and not 1681 as it should. I did everything that I commanded the tutorial, copy the folder in cavityFine cavity blockMeshDict put measures in (40 40 1). Then I put startTime endTime 0.5 and put 1, also did testing with 0.5. In the case of cavity does not change anything. Agadezco to help me as quickly as possible, thanks. GREETINGS |
