December 8, 2005, 04:48 |
I am still getting erro
henk witte
Rep Power: 17 |
I am still getting errors with the foamInstallationTest: gcc 3.4.3 WARNING: Conflicting installations: foam settings: /home/OpenFOAM/OpenFOAM//gcc-4.0.1/bin/gcc current path : /usr/local/bin/gcc CRITICAL ERROR java *** not installed *** gzip 1.3.3 /bin/gzip tar 1.3.3 /bin/tar icoFoam *** not installed *** CRITICAL ERROR Searching the forum I believe gcc 3.4.3 should be the correct version. I tried several gcc releases, including 4.0.1, but all generate the critical error. With respect to the paths, should it be: /home/OpenFOAM/OpenFOAM/gcc-4.0.1/bin/gcc or /home/OpenFOAM/OpenFOAM/linux/gcc-4.0.1/bin/gcc I tried both, and both versions give the error but I am not sure what the correct installation tree is (on the download page it states that gcc and java need to be put in a linux subdirectory of the OpenFoam tree, but given the errors above and the fact that java is not picked up either I am confused). Also, icoFoam is not picked up. Help please? Henk Witte |
December 8, 2005, 14:35 |
I have:
/home/pinky2/mattij
Mattijs Janssens
Rep Power: 26 |
I have:
/home/pinky2/mattijs/OpenFOAM/linux/gcc-4.0.1/bin/gcc where /home/pinky2/mattijs is my home directory. Check what the `uname -s` (and `uname -m`) in .OpenFOAM-1.2/bashrc returns - it is quite strange that your path does not include 'linux' I have: uname -s: Linux uname -m i686 |
December 8, 2005, 15:53 |
Ok,
I decided to start over
henk witte
Rep Power: 17 |
Ok,
I decided to start over, and to make sure that all was well I started with a fresh linux (RH 9) installation. It Works! (why it didn't first??) Henk |
Critical errors gcc and icoFoam during installation of 15 | quartzian | OpenFOAM Installation | 3 | December 12, 2008 12:42 |
UDF errors | JSM | FLUENT | 2 | August 28, 2007 23:37 |
pro-am errors | azmir | Siemens | 8 | January 24, 2006 04:08 |
errors? | varshavian | FLUENT | 2 | December 20, 2002 09:00 |
What do these errors mean? | Jeff | FLUENT | 0 | July 19, 2002 17:07 |
