December 1, 2005, 07:32 |
Having installed ver
henk witte
Having installed version 1.2 of OpenFoam I get the following error when running foamInstallationTest: FATAL ERROR: /home/OpenFOAM/.OpenFOAM-1.1/cshrc does not appear to be sourced from: /home/OpenFOAM/.cshrc I made the changes to the bashrc file, and also tried csh. Especially the .OpenFOAM-1.1 seems strange to me. How can I solve this? Thanks, Henk Witte |
December 1, 2005, 07:39 |
Henk
I had the same problem
Henk
I had the same problem, apparently it's a bug. The tutorials run and it appears to work ok. Have a look in the bugs section of the discussion. allan |
December 2, 2005, 09:40 |
Ok, I will ignore this message
henk witte
Ok, I will ignore this message. However, I do have some other problems related to the installation (but I hoped they were due to a problem with the path specification):
gcc 3.4.2 WARNING: Conflicting installations: foam settings: /home/OpenFOAM/OpenFOAM//gcc-4.0.1/bin/gcc current path : /usr/local/bin/gcc CRITICAL ERROR java *** not installed *** gzip 1.3.3 /bin/gzip tar 1.3.3 /bin/tar icoFoam *** not installed *** CRITICAL ERROR Help would be appreciated! Henk |
December 2, 2005, 10:25 |
You want to make sure you pick
Mattijs Janssens
Rep Power: 26 |
You want to make sure you pick up the OpenFOAM//gcc-4.0.1/bin/gcc instead of the system one. Did you download and install it from the download site? Also you need to install the java from the download site.
If it still does not work add a 'set -x' at the beginning of .../OpenFOAM-1.2/.bashrc and see what is happening. |
December 2, 2005, 11:01 |
Well, I get a lot more output
henk witte
Well, I get a lot more output in general but not during the installation test. I did install the gcc-4.0.1 and java from the installation site into the linux subdirectory. The installation is:
/home/OpenFOAM/OpenFOAM/OpenFOAM-1.2/ /home/OpenFOAM/OpenFOAM/linux/gcc-4.0.1 /home/OpenFOAM/OpenFOAM/linux/j2sdk1.4.2_05 /home/OpenFOAM/OpenFOAM/linux/paraview-2.2.0 this is the output of the test: Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/OpenFOAM/OpenFOAM/OpenFOAM-1.2 yes yes yes $FOAM_USER_APPBIN ...penFOAM-1.2/applications/bin/Gcc4Opt yes yes no $FOAM_APPBIN ...penFOAM-1.2/applications/bin/Gcc4Opt yes yes yes $WM_DIR ...OpenFOAM/OpenFOAM/OpenFOAM-1.2/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH /home/OpenFOAM/OpenFOAM//j2sdk1.4.2_05 no no $MICO_ARCH_PATH ....2/src/mico-2.3.11/platforms/Gcc4Opt no yes $LAM_ARCH_PATH ...-1.2/src/lam-7.1.1/platforms/Gcc4Opt yes yes yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...AM/OpenFOAM/OpenFOAM-1.2/lib/Gcc4Opt yes yes yes $FOAM_USER_LIBBIN ...AM/OpenFOAM/OpenFOAM-1.2/lib/Gcc4Opt yes yes no $LAM_ARCH_PATH ...-1.2/src/lam-7.1.1/platforms/Gcc4Opt yes yes yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 3.4.2 WARNING: Conflicting installations: foam settings: /home/OpenFOAM/OpenFOAM//gcc-4.0.1/bin/gcc current path : /usr/local/bin/gcc CRITICAL ERROR java *** not installed *** gzip 1.3.3 /bin/gzip tar 1.3.3 /bin/tar icoFoam *** not installed *** CRITICAL ERROR Henk |
Serial run OK parallel one fails | r2d2 | OpenFOAM Running, Solving & CFD | 2 | November 16, 2005 12:44 |
RunFoamX fails | jvn | OpenFOAM Installation | 12 | August 11, 2005 11:12 |
Critical error in the installation test | fabi | OpenFOAM Installation | 1 | March 8, 2005 06:07 |
SOR Fails Near Walls | Chih-Wei Chiu | Main CFD Forum | 0 | May 9, 2002 01:05 |
A conference in air load /flight simulation/flight test/wind tunnel test/aero modeling for high AOA | cimsi | Main CFD Forum | 0 | September 17, 1998 06:26 |
