Help with new installation on AMD linux 64 bit |
September 28, 2005, 11:07 |
- do
export WM_64=1
Mattijs Janssens
Rep Power: 26 |
- do
export WM_64=1 before '. .bashrc' if you want the 64bit version. - check that you have the 64bit gcc and java and paraview etc. in the linuxAMD64 directory - check that your PATH include these directories. |
September 28, 2005, 11:28 |
Hello Nikos,
1. "FATAL ERRO
Frank Steinbacher
Rep Power: 17 |
Hello Nikos,
1. "FATAL ERROR: /home/guest/.OpenFOAM-1.1/bashrc does not appear to be sourced from: /home/guest/.bashrc" -> change in the foamInstallationTest skript the directory path to .OpenFOAM-1.2 2. the other errors - i had to compile from source but take care to use the same java and gcc version |
September 28, 2005, 12:17 |
hi again and thank you for you
Nikos Parafestas
Rep Power: 17 |
hi again and thank you for your quick reply
dear Mattijs {- check that you have the 64bit gcc and java and paraview etc. in the linuxAMD64 directory} do you mean that i have to put this directories in a folder called /home/guest/OpenFOAM/linuxAMD64 and not in the /home/rapaneli/OpenFOAM/platform/ folder i have them now? {- check that your PATH include these directories.} i am sorry but i do not understand the meaning of PATH.do you mean adding the path of this directory in /home/guest/.bashrc ? dear Frank 1.did it it now finds only the errors 2.i have gcc-4.0.1-4.fc4.rpm installed is it the same as compiling gcc? i did not understand what you mean by use the same version of gcc and java .... |
September 28, 2005, 13:48 |
? /home/rapaneli/OpenFOAM/plat
Mattijs Janssens
Rep Power: 26 |
? /home/rapaneli/OpenFOAM/platform
You mentioned /home/guest before so I used that. Forget what I said. Do exactly what the installation instructions say so get all the software in the correct place. Get someone with Unix experience to give you a hand. |
September 28, 2005, 15:25 |
Hi Nikos,
what is meant by
Maka Mohu
Rep Power: 18 |
Hi Nikos,
what is meant by plateform directory is: "linux" for 32 bit "linuxAMD64" for 64 bit so: - make a directory named OpenFOAM in your user folder. - make another directory inside the later and name it, in 64 bit case, linuxAMD64, - copy the following to OpenFOAM: Source pack OpenFOAM-1.2.General.gtgz binary pack OpenFOAM-1.2.linuxAMD64Gcc4Opt.gtgz - unpack with tar xzf - copy the rest of the files to linuxAMD64 - unpack with tar xzf - modify .bashrc - use the following command: export WM_64="on" - you may check you environment vars by: printenv|sort - source from a 64 bit processor since processor type is automatically detected. Good luck! feel free to tell if you had more problems. best regards, Maka |
September 29, 2005, 12:59 |
thank you all for helping me w
Nikos Parafestas
Rep Power: 17 |
thank you all for helping me with the installation
I did the FOAMInstalllationTEst with no eror i did the tutorial example from the README file but i wonder ... where is the gui? i do not know where to start...so if somemody can give me a good starting point for learning CFD it would be a great help. What i want to do is to make an exersise about the aerodynamic analysis of the front windshield of a car. My teacher told me to use other commercial products like tecplot and gridgen but i want my paper to be open-source so i wonder if OpenFOAM is the right tool for the job. Thanks |
September 29, 2005, 15:39 |
ok i figured that i need FoamX
Nikos Parafestas
Rep Power: 17 |
ok i figured that i need FoamX coomand in order to have the GUI running but i have an error
[rapaneli@localhost ~]$ export WM_64="on" [rapaneli@localhost ~]$ FoamX Starting NameServer with inet:localhost.localdomain:1234 ... Starting FoamX Host Browser with inet:localhost.localdomain:1234 ... /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.2 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : FoamXHostBrowser Date : Sep 29 2005 Time : 22:32:12 Host : localhost.localdomain PID : 25624 Root : Case : Nprocs : 1 HostBrowser running..... Using jar /home/rapaneli/OpenFOAM/OpenFOAM-1.2/applications/utilities/preProcessing/FoamX/ lib/FoamX.jar Using jar /home/rapaneli/OpenFOAM/OpenFOAM-1.2/applications/utilities/preProcessing/FoamX/ lib/jlfgr-1_0.jar Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/rapaneli/OpenFOAM/linuxAMD64/j2sdk1.4.2_05/jre/lib/i386/libawt.so: libXp.so.6: cannot open shared object file: No such file or directory at java.lang.ClassLoader$NativeLibrary.load(Native Method) at java.lang.ClassLoader.loadLibrary0(ClassLoader.jav a:1586) at java.lang.ClassLoader.loadLibrary(ClassLoader.java :1503) at java.lang.Runtime.loadLibrary0(Runtime.java:788) at java.lang.System.loadLibrary(System.java:834) at sun.security.action.LoadLibraryAction.run(LoadLibr aryAction.java:50) at java.security.AccessController.doPrivileged(Native Method) at sun.awt.NativeLibLoader.loadLibraries(NativeLibLoa der.java:38) at sun.awt.DebugHelper.<clinit>(DebugHelper.java:29) at java.awt.Component.<clinit>(Component.java:506) /home/rapaneli/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: line 131: 25624 died FoamXHostBrowser -ORBNamingAddr $myIOP runFoamXHB : cleanup runFoamXHB: Killing name server nsd(pid 25622). /home/rapaneli/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: line 66: 25622 died nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref </dev/null |
September 29, 2005, 15:53 |
OK solved sorry for the flood
Nikos Parafestas
Rep Power: 17 |
OK solved sorry for the flood ppl
for fedora core 4 users you need to install xorg-deprecated-libs, just do yum install libXp.so.6 i now have GUI... |
Gambit installation under linux | Alex | Main CFD Forum | 1 | December 4, 2008 01:32 |
star-ccm+ linux installation.. | NaMe | Siemens | 2 | September 30, 2008 09:50 |
Linux installation | sunnysun | OpenFOAM Installation | 5 | May 22, 2008 13:24 |
Installation in a 24 linux kernel | sampaio | OpenFOAM Installation | 0 | July 20, 2005 17:37 |
Who have 3.24 linux help file about installation? | Kevin | Siemens | 1 | July 8, 2005 08:42 |
