Warning use of oldstyle cast
Old   September 7, 2005, 07:05
Default Hi. I've just installed 1.2 an
Gavin Tabor
grtabor is on a distinguished road
Hi. I've just installed 1.2 and am trying to make some code work. The code is a GUI for blockMesh using FOX; and it keeps spitting out 'Warning: use of old-style cast' warning messages (principally from the FOX code sections, not OpenFOAM). How can I switch the compiler to ignore these warnings? (They are making it rather difficult to sort out what is _actually_ going wrong).
Gavin
grtabor is offline   Reply With Quote
Old   September 7, 2005, 07:11
Default All the compiler switches are
henry is on a distinguished road
All the compiler switches are in the files in the wmake/rules/* directories, the ones corresponding to the c++ compiler warnings are in the c++ file and the one you want to remove is -Wold-style-cast as you might guess.
henry is offline   Reply With Quote
warning #064 ema Siemens 1 August 25, 2005 05:45
warning # 90 vishal Siemens 1 August 11, 2005 09:19
*** WARNING #052 *** Cirilo Siemens 1 July 27, 2005 08:34
Warning Paco Siemens 0 June 23, 2005 02:33
Warning #007 Shazlan Siemens 3 March 24, 2005 04:49
