Are there any links on se
Are there any links on setting up OpenFOAM in a Linux cluster? If not please tell me some initial guidelines to setup one with these: 1 x 16 Port 100 Mbps Switch 16 x 2.8 Ghz P4 Fedora 3 Linux machines with 100MBps NIC I've downloaded and ran FOAM in a single PC. Many thanks in Advance Ashfaque |
Install it using the same step
Install it using the same steps you did on a single PC but this time in your account folder on the cluster.
if the cluster is working fine once you log on to the main node, you can ssh to any processor on the cluster. To run in parallel: You may read the user guide 2.3.10. Regards, Maka |
