according the openfoam readme
according the openfoam readme ,i will add a line at the end of $HOME/.bashrc file,but i can not find the $HOME/.bashrc file file .!
please help me regards |
What operating system are you
What operating system are you using?
P.S. Please don't split the same discussion in a lot of threads, just use the same :-) Alberto |
check with
echo $SHELL
i
check with
echo $SHELL if you are using a bash-like shell. If the output is something like /bin/bash /usr/bin/bash .... then it means you are working with a bash shell but you don't have any personal setting (no ~/.bashrc). In this case create the file touch ~/.bashrc and go further.... |
thank you very much
thank you very much
Hello !
Trying to install Ope
Hello !
Trying to install OpenFoam on my PC with Suse 9.3 I have similar problems, the output of echo $SHELL is /bin/bash . Meanwhile I have .bashrc on /home/my_name . It seems that it is not taking into account. When I run /home/my_name/.bashrc (w/ $HOME/OpenFOAM ... /bashrc) I get no error message but environmental variables are not updated. For exemple : >$WM_PROJECT_INST_DIR/ [TAB] makes >// Also foamInstallationtest tells me that no Environment Variables are set. Why ? Any idea ? Thanks Reginaldo |
Try to source the OpenFoam-1.1
Try to source the OpenFoam-1.1/.OpenFoam-1.1/bashrc manually and post the output of foamInstallationTest.
Hi !
Thanks a lot,
Manual so
Hi !
Thanks a lot, Manual source has worked OK, also put "source" instead of "." in .bashrc. After that I have hade some others problems that were mentioned here summarizing: a)I've up-dated my etc/hosts to contain the last host name attributed (dynamic IP)' b) I've changed FoamXClient.cfg variable to point to "localhost" c) Because I already have paraview on my PC I changed paraFoam paraview line to /usr/local/paraview... foamInstallationtest feedback was OK ! no critical or fatal error. I've follwed-up: blockmesh cavity has worked ok but not paraFoam... ... and that is my new problem : regi@8R0090J:~/OpenFOAM/regi-1.1/run/tutorials/icoFoam> paraFoam . cavity ErrorMessage # Error or warning: There was a VTK Error in file: /home/amy/ParaViewReleaseRoot/paraview-2.2.1/GUI/Widgets/vtkKWApplication.cxx (1300) Script: paraFoam.pvs Returned Error on line 5: Object named: vtkTemp2, could not find requested method: GetAnimationInterface or the method was called with incorrect arguments. ErrorMessage end Didn't work with paraview I have tried OpenDX (also installed at usr/local version 4.36) regi@8R0090J:~/OpenFOAM/regi-1.1/run/tutorials/icoFoam> dxFoam . cavity Checking path to dx ... Can't find OpenDX Foam network: /home/regi/OpenFOAM/OpenFOAM-1.1/.OpenFOAM-1.1/apps/dxFoam/networks/..net Well I don't know if there are any incompatibilities between paraview 2.2 and 1.85, probably not, probably there are still some variables missing or not well configurated... also for dx because I cheked and /home/regi/OpenFOAM/OpenFOAM-1.1/.OpenFOAM-1.1/apps/dxFoam/networks/ directory exists. |
