Which FOAM package should be downloaded for a SGI machine |
July 16, 2005, 05:08 |
help
help
July 16, 2005, 05:31 |
You will need to compiler from
Hrvoje Jasak
Rep Power: 33 |
You will need to compiler from the sources.
Use only the .General package, build your gcc compiler and download the other bits and bobs (this can be done later). For starters: - get OpenFOAM-1.1.General.gtgz - get gcc-3.4.3 from the gcc site. - build gcc and put in into the right directory (something like OpenFoam/sgi) and then build FOAM using: foam ; Allwmake Have fun, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
July 20, 2005, 12:25 |
Has anybody had any luc
Has anybody had any luck building OpenFOAM for an SGI Itanium (Linux) system? We have recently acquired an Altix system here, and I intend to have a go at building OpenFOAM on it, so just wanted to check what problems, if any, people have had. Jason |
July 20, 2005, 12:33 |
I have done it and had no prob
Rep Power: 22 |
I have done it and had no problems, in fact it was the easiest port so far. All the wmake rules files are supplied for you to build on Altix using the Intel compiler: linuxIA64I64, not that the Intel compiler is any better than gcc. If you would rather stick with gcc then you can start with the standard linux rules and adjust as necessary.
July 20, 2005, 12:53 |
Henry,
I guess you would ha
Kenneth Tan
Henry,
I guess you would have the numbers to back up the claim about Intel compilers vs GCC? Ken |
July 20, 2005, 13:03 |
Yes I have numbers. Basically
Rep Power: 22 |
Yes I have numbers. Basically the difference in the performance of OpenFOAM compiled with the latest gcc and icc were very similar, for some cases the gcc-compiled version was slightly faster and vice-versa. The difference in performance was not larger than 15% for any of the tests I have done so far but they were not very extensive concentrating mainly on LES.
Need help importing downloaded stl files | Louis | Phoenics | 4 | October 5, 2008 06:06 |
Not able to copy the text file from one machine to another machine drive using Cgi script | gtselvam | OpenFOAM Bugs | 2 | October 22, 2007 06:44 |
Which FOAM package should be downloaded for a Dell Xeon intel 64 bit processor | preetham | OpenFOAM Installation | 2 | February 1, 2006 10:08 |
64 Bit machine | P | FLUENT | 7 | June 24, 2005 13:17 |
Run FOAM on a remote machine | luckyluke | OpenFOAM Installation | 1 | June 21, 2005 05:19 |
