Which FOAM package should be downloaded for a SGI machine
Old   July 16, 2005, 05:08
Default help
zoujianfeng
zou_mo is on a distinguished road
Send a message via MSN to zou_mo
help
zou_mo is offline   Reply With Quote
Old   July 16, 2005, 05:31
Default You will need to compiler from
Hrvoje Jasak
You will need to compiler from the sources.
Use only the .General package, build your gcc compiler and download the other bits and bobs (this can be done later).
For starters:
- get OpenFOAM-1.1.General.gtgz
- get gcc-3.4.3 from the gcc site.
- build gcc and put in into the right directory (something like OpenFoam/sgi)
and then build FOAM using:
foam ; Allwmake
Have fun,
Hrv
Hrvoje Jasak
Old   July 20, 2005, 12:25
Default Hi, Has anybody had any luc
jasonb
Has anybody had any luck building OpenFOAM for an SGI Itanium (Linux) system? We have recently acquired an Altix system here, and I intend to have a go at building OpenFOAM on it, so just wanted to check what problems, if any, people have had.
Jason
Old   July 20, 2005, 12:33
Default I have done it and had no prob
henry is on a distinguished road
I have done it and had no problems, in fact it was the easiest port so far. All the wmake rules files are supplied for you to build on Altix using the Intel compiler: linuxIA64I64, not that the Intel compiler is any better than gcc. If you would rather stick with gcc then you can start with the standard linux rules and adjust as necessary.
henry is offline   Reply With Quote
Old   July 20, 2005, 12:53
Default Henry, I guess you would ha
tan
Kenneth Tan
tan is on a distinguished road
Henry,
I guess you would have the numbers to back up the claim about Intel compilers vs GCC?
Ken
tan is offline   Reply With Quote
Old   July 20, 2005, 13:03
Default Yes I have numbers. Basically
Yes I have numbers. Basically the difference in the performance of OpenFOAM compiled with the latest gcc and icc were very similar, for some cases the gcc-compiled version was slightly faster and vice-versa. The difference in performance was not larger than 15% for any of the tests I have done so far but they were not very extensive concentrating mainly on LES.
Need help importing downloaded stl files Louis Phoenics 4 October 5, 2008 06:06
Not able to copy the text file from one machine to another machine drive using Cgi script gtselvam OpenFOAM Bugs 2 October 22, 2007 06:44
Which FOAM package should be downloaded for a Dell Xeon intel 64 bit processor preetham OpenFOAM Installation 2 February 1, 2006 10:08
64 Bit machine P FLUENT 7 June 24, 2005 13:17
Run FOAM on a remote machine luckyluke OpenFOAM Installation 1 June 21, 2005 05:19
