this step is not necessary ,ri
this step is not necessary ,right! i can skip it .
i can not understank " $WM_PROJECT_INST_DIR ",what it mean . regards |
Yes, you don't need to compile
Yes, you don't need to compile OpenFOAM from source.
If you type in a terminal cd $WM_PROJECT_INST_DIR and press enter, you will enter the $HOME/OpenFOAM directory. $WM_PROJECT_INST_DIR is an environment variable whose value is "/home/username/OpenFOAM". I think you need to learn some more about Linux or UNIX operating systems. You can find many guides online (for example: http://www.linux.org/lessons/beginner/toc.html). Google is a good starting point to find many information. Alberto |
