I am not familiar with UNIX. A
I am not familiar with UNIX. And I am running an SGI workstation with IRIX. I have download the source code but I can not find the directory #HOME
In UNIX or IRIX, is "#HOME" directory means the "/ "directory? Thanks in advanced! |
I recommend you learn the basi
I recommend you learn the basics of UNIX before installing OpenFOAM.
I haven't played with UNIX. I'
I haven't played with UNIX. I'm using linux instead. But, I think they are almost the same. So, in my experience, if UNIX system has
the directory named root, you can regard this directory as #HOME. If there is no root directory, I guess you can create a directory and named as root and then download the source files into the directory. Good luck! BTW, from your registered name, I guess you come from China. Right?? I'm a student of ZheJiang University and also a freshman in OpenFOAM. If you are interested in it, we can play with it together。Keep in touching! |
the directory named root, you can regard this directory as #HOME. If there is no root directory, I guess you can create a directory and named as root and then download the source files into the directory. Good luck! BTW, from your registered name, I guess you come from China. Right?? I'm a student of ZheJiang University and also a freshman in OpenFOAM. If you are interested in it, we can play with it together.Keep in touching! |
If you have problem figuring o
If you have problem figuring out what $HOME is you
will most likely have some even bigger problems ahead of you that are related to unix/linux and not to OpenFOAM, please keep these kind of questions to a minimun, the answers to these questions can be found all over the web. This is a forum for OpenFOAM and not for unix/linux. google this 'HOME environment variable linux'- should give you a place to start. but if you want to find out what $HOME is i suggest you use echo, i.e. 'echo $HOME' good luck, Niklas |
Thanks everyone! Thank you for
Thanks everyone! Thank you for your help. Now I know what does "$home" mean. hehe......to me it is great progress.
to Majianfeng: I graduated from Zhejiang University one year ago, and now I am working in Shanghai. I love CFD. Joywe@126.com This is my email address.And 0086-21-50804949-205 is the phone number in my office. Keep in touching. |
Here comes a new stupid questi
Here comes a new stupid question. Don't laugh at me. Any reply will be appreciated.
How to decompress the source code: OpenFOAM-1.1.General.gtgz, Thaks a lot! Joey |
http://www.opencfd.co.uk/openf
http://www.opencfd.co.uk/openfoam/linux.html
read the instructions on how to unpack it below the downloadable files |
Hi,did you solve your new prob
Hi,did you solve your new problem. If not, try the following command:
tar zxvf OpenFOAM-1.1.General.gtgz In my opinion, if you want to go further with OpenFOAM, you should learn some elementary knowledge of UNIX system, such as how to unpack a file and how to compile and install a software. Comparing with Windows, the UNIX system is distinct. So in the first stage, it maybe painful. But just spending a little time, everything will be OK. |
