March 27, 2008, 14:46 |
when I start FoamX the Case Br
Theo
Rep Power: 17 |
when I start FoamX the Case Browser window is completely empty and I cannot start the tutorials.
As suggested in the documentation, I have copied the tutorials to $FOAM_RUN and the OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/controlDict are all set to $FOAM_RUN/tutorials/... what could be the problem ? Thank you, Holger |
April 1, 2008, 03:13 |
Hi Holger,
Iam have the sam
Mark Couwenberg
Rep Power: 17 |
Hi Holger,
Iam have the same, but more strangely: I used to run FoamX perfectly. But now, after running some calculation, I can not contact the case browser anymore. Any help? Brgds, Mark |
April 1, 2008, 04:20 |
I found the problems:
1. I pu
Mark Couwenberg
Rep Power: 17 |
1. I put some small document with project information in the $FOAM_RUN directory, which causes the casebrowser to not connect. 2. In the controldict file (/home/.../OF/OF-version) the marks <> were entered. Do not ask me who put them there... Mark |
March 24, 2009, 13:02 |
error opening casebrowser
leo paul
Rep Power: 17 |
hi,
i had done some calculation like mark has said above and later when i tried opening the casebrowser it showed an error message sayin "casebrowser not found".i tried searching for the controldict file tht mark has mentioned but didnt find it..can someone tell me where to find it?its not in of/of-1.4/..or how to solve this prob..and also what causes this kind of thing? thanks. Leo |
March 30, 2009, 04:19 |
Mark Olesen
Rep Power: 40 |
The short answer is to stop using FoamX and start using the command-line and your favourite editor. FoamX has been the source of numerous irritations in the past and as of OpenFOAM-1.5 has been dropped completely.
FoamX Create new case | jam | OpenFOAM Running, Solving & CFD | 1 | January 17, 2008 12:10 |
Problem seeing new case in case browser | alan_fergus | OpenFOAM Pre-Processing | 9 | June 22, 2006 03:46 |
FoamX Host Browser problem | trevors | OpenFOAM Pre-Processing | 2 | June 13, 2006 07:42 |
[Commercial meshers] How to modify a fluent case on FoamX | joegi | OpenFOAM Meshing & Mesh Conversion | 2 | June 7, 2006 08:28 |
FoamX error aachenBomb case | Ervin Adorean (Adorean) | OpenFOAM Pre-Processing | 13 | March 7, 2005 03:50 |
