July 5, 2011, 12:20 |
#61 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
If you downloaded it with the SVN-command then it is under SVN control and I realized that this breaks the inclusion of SFO via SVN. I added a external reference to that lib in the svn tree (don't worry what that means). Try "svn update" iin the swak-Sources. This should pull the simpleFunctionObjects into the source tree and everything should be fine. If that doesn't work try downloading the swak-Stuff completely anew with the command you used originally Bernhard |
July 5, 2011, 12:35 |
#62 |
Naveen
Rep Power: 16 |
Hi Bernhard,
I uninstalled Ubuntu from my computer and installed fedora. I installed the OpenFOAM source pack. Swak4foam also installed without many troubles. Thank you |
October 2, 2015, 08:22 |
Error during installation of FunkySetFields
#63 |
as
Rep Power: 10 |
I am facing lot of error for the intsallation of funkysetfields. For now the error looks like below: Code:
This script is rather crude. If it doesn't work try the steps by hand. And be sure to run it from the root of the swak-inst allation (as ./maintainanceScripts/compileRequirements.sh). Otherwise it probably won't work bison-2.7.1.tar.gz already downloaded Untarring bison-sources checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /usr/bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether make supports nested variables... yes checking whether make supports nested variables... (cached) yes checking for style of include used by make... GNU checking for gcc... no checking for cc... no checking for cl.exe... no configure: error: in `/opt/OpenFOAM/OpenFOAM-1.6/openfoam-extend-Breeder1.7-libraries-swak4Foam-master/privateRequirements/ compilation/bison-2.7.1': configure: error: no acceptable C compiler found in $PATH See `config.log' for more details There seems to be no Makefile in this directory. You must run ./configure before running 'make'. GNUmakefile:106: die Regel für Ziel „abort-due-to-no-makefile“ scheiterte make: *** [abort-due-to-no-makefile] Fehler 1 There seems to be no Makefile in this directory. You must run ./configure before running 'make'. GNUmakefile:106: die Regel für Ziel „abort-due-to-no-makefile“ scheiterte make: *** [abort-due-to-no-makefile] Fehler 1 Bison not compiled. Check output Add /opt/OpenFOAM/OpenFOAM-1.6/openfoam-extend-Breeder1.7-libraries-swak4Foam-master/privateRequirements/bin to PATH-variab le. The ./Allwmake-script will use this directory automatically Regards, Anuja Last edited by wyldckat; October 3, 2015 at 13:18. Reason: Added [CODE][/CODE] markers |
October 3, 2015, 13:19 |
#64 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick questions:
October 6, 2015, 04:50 |
#65 |
as
Rep Power: 10 |
I have installed openfoam on windows 7. I am using it for my master thesis work. I am taking help from the openwiki site for the installation.
funkysetfields, installation, valueexpressionparser, wmake |
Display Modes | |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
Install OF 1.6.ext on Arch based distribution | miro2000 | OpenFOAM Installation | 4 | October 9, 2013 15:39 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 21:16 |
[swak4Foam] installing funkySetFields utility for OpenFOAM 1.4.1 | ozie | OpenFOAM Community Contributions | 8 | September 8, 2011 12:16 |
