Problem installing OpenFOAM 1.5 installation on RHEL 4. |
April 20, 2009, 05:09 |
Hi Guys,
First and foremost, I would like to state that I am a first time user of a LINUX O/S and thus have very limited knowledge on how does it work and how to use commands to operate on it. I have been a windows user for as long as I remember and therefore am used to only the windows GUI. I have posted a task to install OpenFOAM 1.5 on a RHEL 4 system at work with no connection to the internet due to security issues ( defence related work ). I am taking over from a previous staff member who has left the organisation so I do not know what has been done thus far. From what I know all packages have been installed on the system as per openFOAM 1.5 installation instructions on a home/openfoam user directory. When running foamInstalltionTest, I get 1 critical error stating that I have a GCC compatibility issue. Details are as follows OpenFOAM 1.5 installed in home/openfoam/OpenFOAM/ . All packages that are required as per www.opencfd.co.uk installation instructions have been installed. Running openFOAM installation test with foamInstallationTest command yields one critical error. Error details are as follows. """""""""""""""""""""""""""""""""""""""""""""""""" """"""""""""""""""""""""""""""""""" Third party software --------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.1 User version: 3.4.6 Minimum required: 4.2.0 gcc 3.4.6 WARNING: Conflicting installations: OpenFOAM settings: /home/openfoam/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux-64/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR """""""""""""""""""""""""""""""""""""""""""""""""" """""""""""""""""""""""""""""""""""" However I can't seem to find a suitable RPM to update RHEL 4 to gcc 4.3.1. When i try to complile gcc 4.3.1 on the system, i am faced with numerous dependancy issues. Is there any quick and easy way to install openFOAM 1.5 or gcc 4.3.1 on RHEL 4 bearing in mind that I am a LINUX newbie? Thank you ! Regards, Victor |
April 21, 2009, 02:18 |
Gijsbert Wierink
Rep Power: 18 |
Hi Victor,
Have you tried the following in the terminal (as root)? Code:
yum install gcc gcc-c++ Regards, Gijsbert |
April 22, 2009, 22:14 |
#3 | |
Does this require an internet connection? because the pc which i am installing in does not have an internet connection because of security issues. Thanks Regards, Victor |
April 23, 2009, 01:01 |
Gijsbert Wierink
Rep Power: 18 |
Hi Victor,
Ai, yes yum does need an internet connection. The nice thing about yum is that it will find the dependencies by itselfe, so you don't need to hunt for those. Without internet connection you need to go to GCC's website and download the appropriate version. Regards, Gijsbert |
April 23, 2009, 04:48 |
#5 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
yum install gcc4 gcc4-c++ Bernhard |
Trouble with installing OpenFOAM on Ubuntu | Milos | OpenFOAM Installation | 16 | November 16, 2009 02:44 |
Installing OpenFOAM 1.5 on OpenSUSE 11.1 | StructureITA | OpenFOAM Installation | 31 | April 30, 2009 19:45 |
Installation 1.5 as a user of server (New bird) | chiven | OpenFOAM Installation | 15 | April 26, 2009 22:33 |
New openfoam installation | fivos | OpenFOAM Installation | 5 | April 1, 2009 03:58 |
OpenFOAM Version 1.5 Released | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 14, 2008 18:22 |
