Installation OF1.5-dev
Old   April 22, 2009, 08:24
Default Installation OF1.5-dev
Hy Yu
ttdtud is on a distinguished road
I have downloaded OF1.5-dev from svn repository and Thirdparty from OpenFOAM homepage.
I have adjusted my ".bashrc" file and added "WM_32=on" because my OS is 32bit.
If i go to "OpenFOAM-1.5-dev/src and excute the "./Allmake" i willhave the following messages:
+ cd OpenFOAM
+ wmakeLnInclude .
+ cd Pstream
+ ./Allwmake
+ wmake libso dummy
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/wmake/wmake: line 214: make: command not found
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/wmake/wmake: line 215: make: command not found
wmake error: file 'Make/linuxGccDPOpt/objectFiles' could not be created
+ wmake libso mpi
wmake error: file 'Make/linuxGccDPOptOPENMPI/objectFiles' could not be created
+ wmake libo OSspecific/Unix
+ wmake libso topoChangerFvMesh
+ wmake libso engine
+ wmake libso edgeMesh
+ wmake libso meshTools
+ wmake libso finiteVolume
+ wmake libso finiteArea
+ wmake libso dynamicMesh
+ cd tetDecompositionFiniteElement
+ ./Allwmake
wmake error: file 'Make.cellDecomp/linuxGccDPOpt/objectFiles' could not be created
wmake error: file 'Make.faceDecomp/linuxGccDPOpt/objectFiles' could not be created
+ wmake libso intermediate
+ wmake libso dieselSpray
+ cd molecularDynamics
+ wmake libso potential
+ wmake libso molecule
+ cd postProcessing
+ ./Allwmake
+ wmake libo postCalc
+ wmake libso forces
+ wmake libso fieldAverage
+ wmake libso foamCalcFunctions
+ cd conversion
+ ./Allwmake
+ wmake libso
+ wmake libso autoMesh
+ wmake libso errorEstimation
Any helps would be appreciated gratefully.
ttdtud is offline   Reply With Quote
Old   April 22, 2009, 09:22
Sandeep Menon
deepsterblue will become famous soon enough
The script can't find make. Install binutils for your distribution.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   April 22, 2009, 11:07
Hy Yu
Hi Sandeep, thank you very much.
yes, i have installed binutils, binutils-dev and cmake. At least the compilation does work. However, i have the following errors again:
+ cd OpenFOAM
+ wmakeLnInclude .
+ cd Pstream
+ ./Allwmake
+ wmake libso dummy
Making dependency list for source file Pstream.C
Making dependency list for source file IPread.C
Making dependency list for source file OPwrite.C
+ case "$WM_MPLIB" in
+ export WM_OPTIONS=linuxGccDPOptOPENMPI
+ WM_OPTIONS=linuxGccDPOptOPENMPI
+ set +x
+ wmake libso mpi
could not open file mpi.h for source file OPwrite.C
could not open file mpi.h for source file IPread.C
could not open file mpi.h for source file Pstream.C
OPwrite.C:30:17: error: mpi.h: Datei oder Verzeichnis nicht gefunden
IPread.C:30:17: error: mpi.h: Datei oder Verzeichnis nicht gefunden
OPwrite.C:38: error: ‘MPI_Request’ was not declared in this scope
OPwrite.C:38: error: template argument 1 is invalid
OPwrite.C:38: error: invalid type in declaration before ‘;’ token
OPwrite.C: In static member function ‘static bool Foam::OPstream::write(Foam::Pstream::commsTypes, int, const char*, std::streamsize)’:
OPwrite.C:81: error: ‘MPI_PACKED’ was not declared in this scope
OPwrite.C:84: error: ‘MPI_COMM_WORLD’ was not declared in this scope
OPwrite.C:85: error: ‘MPI_Bsend’ was not declared in this scope
OPwrite.C:93: error: ‘MPI_PACKED’ was not declared in this scope
OPwrite.C:96: error: ‘MPI_COMM_WORLD’ was not declared in this scope
OPwrite.C:97: error: ‘MPI_Send’ was not declared in this scope
OPwrite.C:101: error: ‘MPI_Request’ was not declared in this scope
OPwrite.C:101: error: expected `;' before ‘request’
OPwrite.C:107: error: ‘MPI_PACKED’ was not declared in this scope
OPwrite.C:110: error: ‘MPI_COMM_WORLD’ was not declared in this scope
OPwrite.C:111: error: ‘request’ was not declared in this scope
OPwrite.C:112: error: ‘MPI_Isend’ was not declared in this scope
OPwrite.C:114: error: request for member ‘append’ in ‘OPstream_outstandingRequests_’, which is of non-class type ‘int’
OPwrite.C: In static member function ‘static void Foam::OPstream::waitRequests()’:
OPwrite.C:132: error: request for member ‘size’ in ‘OPstream_outstandingRequests_’, which is of non-class type ‘int’
OPwrite.C:134: error: ‘MPI_Status’ was not declared in this scope
OPwrite.C:134: error: template argument 1 is invalid
OPwrite.C:134: error: invalid type in declaration before ‘(’ token
OPwrite.C:134: error: request for member ‘size’ in ‘OPstream_outstandingRequests_’, which is of non-class type ‘int’
OPwrite.C:140: error: request for member ‘size’ in ‘OPstream_outstandingRequests_’, which is of non-class type ‘int’
OPwrite.C:141: error: request for member ‘begin’ in ‘OPstream_outstandingRequests_’, which is ofnon-class type ‘int’
OPwrite.C:142: error: request for member ‘begin’ in ‘status’, which is of non-class type ‘int’
OPwrite.C:143: error: ‘MPI_Waitall’ was not declared in this scope
OPwrite.C:152: error: request for member ‘clear’ in ‘OPstream_outstandingRequests_’, which is ofnon-class type ‘int’
OPwrite.C: In static member function ‘static bool Foam::OPstream::finishedRequest(Foam::label)’:
OPwrite.C:159: error: request for member ‘size’ in ‘OPstream_outstandingRequests_’, which is of non-class type ‘int’
OPwrite.C:164: error: request for member ‘size’ in ‘OPstream_outstandingRequests_’, which is of non-class type ‘int’
OPwrite.C:172: error: ‘MPI_Status’ was not declared in this scope
OPwrite.C:172: error: expected `;' before ‘status’
OPwrite.C:174: error: invalid types ‘int[const Foam::label]’ for array subscript
OPwrite.C:174: error: ‘status’ was not declared in this scope
OPwrite.C:174: error: ‘MPI_Test’ was not declared in this scope
IPread.C:40: error: ‘MPI_Request’ was not declared in this scope
IPread.C:40: error: template argument 1 is invalid
IPread.C:40: error: invalid type in declaration before ‘;’ token
IPread.C: In constructor ‘Foam::IPstream::IPstream(Foam::Pstream::commsType s, int, Foam::label, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)’:
IPread.C:62: error: ‘MPI_Status’ was not declared in this scope
IPread.C:62: error: expected `;' before ‘status’
IPread.C:68: error: ‘MPI_COMM_WORLD’ was not declared in this scope
IPread.C:68: error: ‘status’ was not declared in this scope
IPread.C:68: error: ‘MPI_Probe’ was not declared in this scope
IPread.C:69: error: ‘MPI_BYTE’ was not declared in this scope
IPread.C:69: error: ‘MPI_Get_count’ was not declared in this scope
IPread.C: In static member function ‘static Foam::label Foam::IPstream::read(Foam::Pstream::commsTypes, int, char*, std::streamsize)’:
IPread.C:100: error: ‘MPI_Status’ was not declared in this scope
IPread.C:100: error: expected `;' before ‘status’
IPread.C:108: error: ‘MPI_PACKED’ was not declared in this scope
IPread.C:111: error: ‘MPI_COMM_WORLD’ was not declared in this scope
IPread.C:112: error: ‘status’ was not declared in this scope
IPread.C:113: error: ‘MPI_Recv’ was not declared in this scope
IPread.C:130: error: ‘status’ was not declared in this scope
IPread.C:130: error: ‘MPI_BYTE’ was not declared in this scope
IPread.C:130: error: ‘MPI_Get_count’ was not declared in this scope
IPread.C:148: error: ‘MPI_Request’ was not declared in this scope
IPread.C:148: error: expected `;' before ‘request’
IPread.C:156: error: ‘MPI_PACKED’ was not declared in this scope
IPread.C:159: error: ‘MPI_COMM_WORLD’ was not declared in this scope
IPread.C:160: error: ‘request’ was not declared in this scope
IPread.C:161: error: ‘MPI_Irecv’ was not declared in this scope
IPread.C:174: error: request for member ‘append’ in ‘IPstream_outstandingRequests_’, which is ofnon-class type ‘int’
IPread.C:174: error: ‘request’ was not declared in this scope
IPread.C: In static member function ‘static void Foam::IPstream::waitRequests()’:
IPread.C:194: error: request for member ‘size’ in ‘IPstream_outstandingRequests_’, which is of non-class type ‘int’
IPread.C:196: error: ‘MPI_Status’ was not declared in this scope
IPread.C:196: error: template argument 1 is invalid
IPread.C:196: error: invalid type in declaration before ‘(’ token
IPread.C:196: error: request for member ‘size’ in ‘IPstream_outstandingRequests_’, which is of non-class type ‘int’
IPread.C:202: error: request for member ‘size’ in ‘IPstream_outstandingRequests_’, which is of non-class type ‘int’
IPread.C:203: error: request for member ‘begin’ in ‘IPstream_outstandingRequests_’, which is of non-class type ‘int’
IPread.C:204: error: request for member ‘begin’ in ‘status’, which is of non-class type ‘int’
IPread.C:205: error: ‘MPI_Waitall’ was not declared in this scope
IPread.C:214: error: request for member ‘clear’ in ‘IPstream_outstandingRequests_’, which is of non-class type ‘int’
IPread.C: In static member function ‘static bool Foam::IPstream::finishedRequest(Foam::label)’:
IPread.C:221: error: request for member ‘size’ in ‘IPstream_outstandingRequests_’, which is of non-class type ‘int’
IPread.C:226: error: request for member ‘size’ in ‘IPstream_outstandingRequests_’, which is of non-class type ‘int’
IPread.C:234: error: ‘MPI_Status’ was not declared in this scope
IPread.C:234: error: expected `;' before ‘status’
IPread.C:236: error: invalid types ‘int[const Foam::label]’ for array subscript
IPread.C:236: error: ‘status’ was not declared in this scope
IPread.C:236: error: ‘MPI_Test’ was not declared in this scope
make: *** [Make/linuxGccDPOptOPENMPI/OPwrite.o] Fehler 1
make: *** Warte auf noch nicht beendete Prozesse...
make: *** [Make/linuxGccDPOptOPENMPI/IPread.o] Fehler 1
/bin/sh: flex: command not found
mv: Aufruf von stat für „lex.yy.cc“ nicht möglich: Datei oder Verzeichnis nicht gefunden
g++: Make/linuxGccDPOpt/readSTLASCII.C: Datei oder Verzeichnis nicht gefunden
g++: no input files
make: *** [Make/linuxGccDPOpt/readSTLASCII.o] Fehler 1
/usr/lib/gcc/i586-suse-linux/4.3/../../../../i586-suse-linux/bin/ld: cannot find -ltriSurface
collect2: ld returned 1 exit status
make: *** [/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libmeshTools.so] Fehler 1
Any other ideas?
Thanks for any help!
Old   April 22, 2009, 11:24
chapman is on a distinguished road
You have to install "flex". It can be obtained here: http://flex.sourceforge.net/
Depending on your distribution there might be an easier way to get "flex". Which distribution do you use?
chapman is offline   Reply With Quote
Old   April 22, 2009, 11:28
Hy Yu
Hi CHapman,
actually i have already installed "flex". I have SuSe 11.0.
what should I do now?
thanks in advance.
Old   April 22, 2009, 11:32
Please post the results of the following commands just to make sure that flex/flex++ can be found.
which flex
which flex++
Old   April 22, 2009, 11:36
Hy Yu
It seems that some dynamical libraries or links couldn't been found by compilation.
e.g.
cannot find -ldynamicMesh
cannot find -lbasicThermophysicalModels
cannot find -lfiniteVolume
could not open file metis.h for source file metisDecomp/metisDecomp.C
metisDecomp/metisDecomp.C:37:22: error: metis.h: Datei oder Verzeichnis nicht gefunden
any ideas?
Old   April 22, 2009, 11:38
Hy Yu
which flex
which flex++
/usr/bin/flex
and
/usr/bin/flex++
Old   April 22, 2009, 11:43
Ok, flex/flex++ seems to be installed.
Try to compile only "triSurface" in the src-directory by doing
src
wmake libso triSurface
and post the error code here.
There are some known issues concerning flex and the file "readSTLASCII.C". Maybe this is the problem.
Old   April 22, 2009, 11:57
Hy Yu
src
Hi Chapman,
it seems that "triSurface" has been already compiled.
When i enter the command
i have the message:
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libtriSurface.so' is up to date
Is it OK?
Old   April 22, 2009, 12:02
Then try to do the same with the other missing parts named above
wmake libso lxxx
Old   April 23, 2009, 04:47
Hy Yu
Hi Chapman
I have tried to compile for every part under "src".
For "autoMesh" i have:
/usr/bin/ld: cannot find -ldecompositionMethods
make: *** [/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libautoMesh.so] Fehler 1
Then I came into "decompositionAgglomeration", there are 3 parts. I have compiled for every part. I have the following:
for "parMetisDecomp"
usr/bin/ld: cannot find -lmetis-parmetis
make: *** [/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/openmpi-1.2.6/libparMetisDecompositionMethod.so] Fehler 1
for "MGridGenGamgAgglomeration"
/usr/bin/ld: cannot find -lMGridGen
make: *** [/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libMGridGenGAMGAgglomeration.so] Fehler 1
for "decompositionMethods"
/usr/bin/ld: cannot find -lmetis
make: *** [/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libdecompositionMethods.so] Fehler 1
the other errors has happened by compilation "Pstream"
in "Pstream"
wmake libso dummy
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/dummy/libPstream.so' is up to date
wmake libso gamma
SOURCE=PstreamGlobals.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -DOMPI_SKIP_MPICXX -I/home/hongyi/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linuxGccDPOpt/include -IlnInclude -I. -I/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/PstreamGlobals.o
SOURCE=Pstream.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -DOMPI_SKIP_MPICXX -I/home/hongyi/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linuxGccDPOpt/include -IlnInclude -I. -I/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/Pstream.o
PstreamGlobals.C:33:34: error: linux/gamma/libgamma.h: Datei oder Verzeichnis nicht gefunden
Pstream.C:68:37: error: linux/gamma/libgamma.h: Datei oder Verzeichnis nicht gefunden
PstreamGlobals.C: In function ‘void Foam::PstreamGlobals::gammaWait(Foam::label)’:
PstreamGlobals.C:70: error: ‘gamma_wait’ was not declared in this scope
Pstream.C: In function ‘void Foam::handler()’:
Pstream.C:80: error: ‘gamma_active_port’ was not declared in this scope
Pstream.C:90: error: ‘gamma_msglen’ was not declared in this scope
Pstream.C:107: error: ‘gamma_msglen’ was not declared in this scope
Pstream.C:124: error: ‘gamma_msglen’ was not declared in this scope
Pstream.C:189: error: ‘gamma_post_recv’ was not declared in this scope
Pstream.C: In static member function ‘static bool Foam::Pstream::init(int&, char**&)’:
Pstream.C:231: error: ‘gamma_init’ was not declared in this scope
Pstream.C:233: error: ‘gamma_my_node’ was not declared in this scope
Pstream.C:307: error: ‘gamma_my_par_pid’ was not declared in this scope
Pstream.C:311: error: ‘GO_BACK’ was not declared in this scope
Pstream.C:314: error: ‘gamma_set_active_port’ was not declared in this scope
Pstream.C:320: error: ‘gamma_sync’ was not declared in this scope
Pstream.C:325: error: ‘scheduledTransfer’ is not a member of ‘Foam::Pstream’
Pstream.C: In static member function ‘static void Foam::Pstream::exit(int)’:
Pstream.C:338: error: ‘gamma_exit’ was not declared in this scope
Pstream.C: In static member function ‘static void Foam::Pstream::abort()’:
Pstream.C:347: error: ‘gamma_abort’ was not declared in this scope
Pstream.C: In function ‘void Foam::reduce(Foam::scalar&, const Foam::sumOp<double>&)’:
Pstream.C:382: error: no matching function for call to ‘Foam::IPstream::read(int&, char*, unsigned int)’
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/IPstream.H:119: note: candidates are: static Foam::label Foam::IPstream::read(Foam::Pstream::commsTypes, int, char*, std::streamsize)
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/IPstream.H:128: note: virtual Foam::Istream& Foam::IPstream::read(Foam::token&)
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/IPstream.H:131: note: virtual Foam::Istream& Foam::IPstream::read(char&)
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/IPstream.H:134: note: virtual Foam::Istream& Foam::IPstream::read(Foam::word&)
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/IPstream.H:137: note: virtual Foam::Istream& Foam::IPstream::read(Foam::string&)
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/IPstream.H:140: note: virtual Foam::Istream& Foam::IPstream::read(Foam::label&)
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/IPstream.H:143: note: virtual Foam::Istream& Foam::IPstream::read(Foam::floatScalar&)
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/IPstream.H:146: note: virtual Foam::Istream& Foam::IPstream::read(Foam::doubleScalar&)
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/IPstream.H:149: note: virtual Foam::Istream& Foam::IPstream::read(char*, std::streamsize)
Pstream.C:405: error: invalid conversion from ‘int’ to ‘Foam::Pstream::commsTypes’
Pstream.C:405: error: initializing argument 1 of ‘static bool Foam::OPstream::write(Foam::Pstream::commsTypes, int, const char*, std::streamsize)’
Pstream.C:405: error: invalid conversion from ‘const char*’ to ‘int’
Pstream.C:405: error: initializing argument 2 of ‘static bool Foam::OPstream::write(Foam::Pstream::commsTypes, int, const char*, std::streamsize)’
Pstream.C:405: error: invalid conversion from ‘unsigned int’ to ‘const char*’
Pstream.C:405: error: initializing argument 3 of ‘static bool Foam::OPstream::write(Foam::Pstream::commsTypes, int, const char*, std::streamsize)’
Pstream.C:433: error: invalid conversion from ‘int’ to ‘Foam::Pstream::commsTypes’
Pstream.C:433: error: initializing argument 1 of ‘static bool Foam::OPstream::write(Foam::Pstream::commsTypes, int, const char*, std::streamsize)’
Pstream.C:433: error: invalid conversion from ‘const char*’ to ‘int’
Pstream.C:433: error: initializing argument 2 of ‘static bool Foam::OPstream::write(Foam::Pstream::commsTypes, int, const char*, std::streamsize)’
Pstream.C:433: error: invalid conversion from ‘unsigned int’ to ‘const char*’
Pstream.C:433: error: initializing argument 3 of ‘static bool Foam::OPstream::write(Foam::Pstream::commsTypes, int, const char*, std::streamsize)’
Pstream.C:453: error: no matching function for call to ‘Foam::IPstream::read(int, char*, unsigned int)’
make: *** [Make/linuxGccDPOpt/PstreamGlobals.o] Fehler 1
make: *** [Make/linuxGccDPOpt/Pstream.o] Fehler 1
wmake libso mpi
'/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/openmpi-1.2.6/libPstream.so' is up to date
wmake libso pvm
SOURCE=OPwrite.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -DOMPI_SKIP_MPICXX -I/home/hongyi/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linuxGccDPOpt/include -IlnInclude -I. -I/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/OPwrite.o
SOURCE=IPread.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -DOMPI_SKIP_MPICXX -I/home/hongyi/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linuxGccDPOpt/include -IlnInclude -I. -I/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/IPread.o
IPread.C:34:18: OPwrite.C:34:18: error: pvm3.h: Datei oder Verzeichnis nicht gefunden
OPwrite.C: In destructor ‘virtual Foam::OPstream::~OPstream()’:
OPwrite.C:53: error: ‘PVM_BYTE’ was not declared in this scope
OPwrite.C:54: error: ‘pvm_psend’ was not declared in this scope
OPwrite.C:54: error: ‘PvmOk’ was not declared in this scope
OPwrite.C:59: warning: the address of ‘void abort()’ will always evaluate as ‘true’
IPread.C:49: error: prototype for ‘Foam::IPstream::IPstream(int, Foam::label, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)’ does not match any in class ‘Foam::IPstream’
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/IPstream.H:57: error: candidates are: Foam::IPstream::IPstream(const Foam::IPstream&)
/home/hongyi/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/IPstream.H:90: error: Foam::IPstream::IPstream(Foam::Pstream::commsTypes , int, Foam::label, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)
make: *** [Make/linuxGccDPOpt/OPwrite.o] Fehler 1
make: *** [Make/linuxGccDPOpt/IPread.o] Fehler 1
At last the compilations for other parts are OK.
What should i do?
Old   April 23, 2009, 04:56
I had a simliar error yesterday (cannot find -ldecompositionMethods)
It was quite strange since it was solved by running src/decompositionAgglomeration/Allwmake. After doing that "lmetis" and all the other parts were found.
Old   April 23, 2009, 07:47
Hy Yu
Hi Chapman,
what should I do now? I have tried to do everything i can.
By the way is there a big difference between OF in 32bit-Linux and 64bit-Linux?
Old   April 23, 2009, 10:49
Originally Posted by ttdtud View Post
Hi Chapman,
Sorry for not having further hints. As said above running Allwmake solved my problem, bit I don't know why I had to compile this file manually.
Old   April 24, 2009, 02:23
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi
"missing -lparmetis" is because you have not compiled the ThirdParty software. If you compile that while having sourced 1.5-dev, then you should be able to resolve those errors.
Good luck
Niels
ngj is offline   Reply With Quote
Old   April 24, 2009, 02:58
Hy Yu
Originally Posted by ngj View Post
Hi
Good luck
Niels
Hi Niels,
actually i have downloaded Thirdparty from officical OpenFOAM website and unpacked them. I think that Thirdparty donot need to be compiled. Am I right?
PS. I download OF-1.5-dev from svn repository.
My Install steps are:
1. get OF-1,5-dev using "svn co http://openfoam-extend.svn.sourceforge.net/svnroot/openfoam-extend/trunk/Core/OpenFOAM-1.5-dev/" to download OF-1.5-dev"
2. Create dictionary "OpenFOAM" in the home ~/OpenFOAM
3. Move OpenFOAM-1.5.dev into "~/OpenFOAM"
4. Download "ThidParty.General.tgtgz and ThirdParty.linuxGcc.gtgz" from OpenFOAM homepage, unpack them in ~/OpenFOAM
5. add line ". $HOME/OpenFOAM/OpenFOAM-1.5-dev/etc/bashrc" in ~/.bahsrc and source it.
6. go to dictionary "~/OpenFOAM/OpenFOAM-1.5-dev/src" excute ./Allwmake then get the error messages.
which is false and what should I do?
Thanks in advance for any helps!
Old   April 24, 2009, 03:38
jaswi is on a distinguished road
Hi
My friend the steps you are following are for installation but what you are doing is compilation. As far as I remember , the compilation requires that all the statements in the script Allwmake are executed. Compilation of the Third Party software preceeds the ompilation of the /src directory.
No the instruction for installation are not false. Please compile the third party stuff and try again , it shall work.
Kind Regards
Jaswi
jaswi is offline   Reply With Quote
Old   April 24, 2009, 04:12
Mandar
mixer is on a distinguished road
Hi Jaswi,
I have downloaded the OF1.5-dev and Third-Party from http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/release/
1. but, this did not contain the /etc folder within OpenFOAM-1.5-dev. So, I could not find the cshrc file to be sourced. Can anyone tell me what to do?
2.The thirdParty i downloaded has 3 folders: lam-7.1.4, libccmio-2.6.1, wmakeFiles. Should i just added it to a ThirdParty folder that i already have from OpenFoam-1.5. how does one compile it. I could not find any wmake anywhere in this.
I could run the ./Allwmake in OpenFOAM-1.5-dev/src without error.
Am i downloading the wrong installation files.
thanks for help.
mixer is offline   Reply With Quote
Old   April 24, 2009, 04:26
Hi Mixer
Please download the dev version from the SVN. The command and the link is :
svn co http://openfoam-extend.svn.sourcefor...nFOAM-1.5-dev/
This gives you just the code.
For the Third Party stuff, I always take the stuff from the OpenFOAM website . The commands for the 64 bit distro are :
wget http://downloads.sourceforge.net/foa...se_mirror=mesh
Sometimes you need to remove the use_mirror=mesh if the download doesn't start.
Hope that helps
Kind Regards
Jaswi
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Installation problems indy OpenFOAM Installation 7 April 3, 2009 09:40
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Installation problems shellbell1999 OpenFOAM Installation 9 April 6, 2006 13:29
1 fetal error in OpenFOAM12 installation andycong OpenFOAM Installation 3 February 26, 2006 03:09
