Did anyone manage to compile LAM?
Old   May 28, 2009, 09:15
Default Did anyone manage to compile LAM?
Marco Müller
marico is on a distinguished road
first of all, I do not want to use LAM but it seems that for ENTIRE compilation of 1.5-dev it is necessary?!
Otherwise it is always complaining about missing libPstream.so... (which exists for open-mpi...)
So:
1. is there a way to bypass the parallel **** since I do not need it that time? I read something of "dummy"...
2. How to compile LAM if it cries:
checking for type bool... no
checking for true/false... no
configure: WARNING: *** Your C++ compiler does not support the bool data type.
configure: WARNING: *** LAM requires a C++ compiler with support for the bool
configure: WARNING: *** data type.
configure: error: cannot continue
Thanks for your help!!
Marco
marico is offline   Reply With Quote
Old   May 28, 2009, 12:06
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Marco,
I am not sure if it helps, but I got similar errors about a missing libPstream.so, after I compiled OF-1.5-dev.
http://www.cfd-online.com/Forums/ope...tml#post215986
So I put ' unset WM_MPLIB ' in my '.bashrc' before it sources OpenFOAM.
And then when I source it, I don't get the error anymore.
I am not sure why I get this error, but this is a superficial solution.
Hope this help,
Philip
bigphil is offline   Reply With Quote
Old   May 29, 2009, 02:09
Marco Müller
Hey Philip,
that worked for my problem.
Big thanks to C.S.-Lewisland
Marco
Old   May 29, 2009, 02:26
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
The old setting for WM_MPLIB must be coming from somewhere (ie, an older OpenFOAM version). If it is not part of your present environment, you might be inheriting it from the X11 session.
olesen is offline   Reply With Quote
Old   May 29, 2009, 07:26
bigphil's Avatar
Philip Cardiff
I had previously compiled OpenFOAM-1.2 on my laptop, which must be from where it came.
Every time a new terminal is opened, it will be set to lam unless I unset it and resource the bash (or just unset in the bash before OpenFOAM).
There must be some way to unset it for good, but for now it does the job.
Philip
Old   May 29, 2009, 09:55
Marco Müller
OK, I had just compiled 1.4.1-dev, so I know why... thanks again!
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
DUNS compile with VC++, VF or gcc/g77 in PC Ali Irvi Main CFD Forum 17 August 6, 2014 09:19
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
LAM trouble with tru64 matthias OpenFOAM Installation 7 December 6, 2005 13:18
compile the UDF Li Jingping FLUENT 2 April 14, 2003 21:18
