Kubuntu 8.10: paraFoam differences between 32 and 64 bit. Can you help me? |
June 28, 2009, 08:26 |
Rep Power: 16 |
I've two computer both with Kubuntu 8.10. One has a 64bit OS, theother 32bit. On the 64bit machine paraFoam works without any problem, while on the 32 bit machine it works only if I use foamToVTK. qmake --version is: QMake version 2.01a Using Qt version 4.4.3 in /usr/lib on both machines. What can I do to have paraFoam working on the 32 bit machine? I've installed on the 32bit only to see if I've problem with openFoam if I upgrade to kubuntu 9.04, but I wonder if the difference between the two version can cause misleading results. Xwang |
Display Modes | |
