Error Extracting Packed Files
I've downloaded both the OpenFOAM-1.6.General.gtgz file, the third party and the relevant 64-bit one's too.
I've run a md5sum on the file from the terminal and the hashes seem correct. When I right click in the File Browser and select extract here, I get an error " An error occured while extracting files" I'm running Ubuntu 9.04 - 64. Any ideas what to do ? I successfully downloaded , unpacked and have run the latest paraview using this technique. |
sorted it , you use the tar -xzvf <filename> command
I found this on the Ubuntu webpage for installing OpenFoam http://https://help.ubuntu.com/community/OpenFOAM this is also on the openfoam webpage installation instructions... |
