Problem on Installing OpenFOAM 1.6 on Fedora 11
I installed the OpenFOAM-1.6, and set the environment variables in the way in the file README. However, after I restart my computer, I found there was nothing in desktop of my computer, and I can not open GUI to view files. When I opened the terminal, I found there was one warning in terminal that was following:
"age: grep [OPTION]... PATTERN [FILE]... Try `grep --help' for more information. kde4-config: /root/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux/lib/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/libkdecore.so.5)". So, I just reset environment variables in order to make my computer normal. What is the problem with what I mention above? How to solve it? Thanks! |
Hi lzgwhy,
I remember I had a similar problem with F11. First I'd install the libstdc++ that seems to be the problem: Code:
su -c 'yum install libstdc++.so.6' Code:
su -c 'yum install gtweakui' Hope this helps a bit :) Regards, Gijs http://users.tkk.fi/%7Egwierink/Scre...I_Nautilus.png |
