August 17, 2009, 15:37 |
Linker errors when building ThirdParty-1.6
Niklas Winkler
Rep Power: 17 |
./Allwmake gives this error when trying to build hoard in Thirdparty
+ wmake libso hoard /scratch/nwinkler/ProgramFiles/OF-1.6/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/../../../../lib64/libstdc++.so: file not recognized: File format not recognized collect2: ld returned 1 exit status make: *** [/scratch/nwinkler/ProgramFiles/OF-1.6/OpenFOAM-1.6/lib/linux64GccDPOpt/libhoard.so] Error 1 several other targets fail with the same error, i.e. libstdc++.so is not recognized. it is a symlink to libstdc++.so.6.0.10 , which is 64 bit >file gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/../../../../lib64/libstdc++.so.6.0.10 gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/../../../../lib64/libstdc++.so.6.0.10: ELF 64-bit LSB shared object, AMD x86-64, version 1 (SYSV), not stripped and so is the machine >uname -a Linux tour 2.6.18-6-amd64 #1 SMP Tue May 5 08:01:28 UTC 2009 x86_64 GNU/Linux And I try to build the 64 bit version: >echo $WM_ARCH_OPTION 64 Any suggestions how to make it build? Regards /NW |
August 18, 2009, 08:28 |
Rishi .
Rep Power: 17 |
I had similar problem with libstdc++. The problem was solved by first compiling gcc in thirdparty with path for gmp and mpfr, using my system compiler. Then I could compile OF1.6 and did not have libstdc++ error. It could be the same problem... |
August 18, 2009, 12:05 |
Niklas Winkler
Rep Power: 17 |
Thanks Rishi,
I did as in the following thread and it works for Thirdparty! http://www.linuxquestions.org/questions/linux-from-scratch-13/i-have-an-error-building-gcc-requires-gmp-4.1-and-mpfr-2.3.0.-690426/ But, when trying to compile src/ with ./Allwmake I get the following errors, Note: ignore spurious warnings about missing mpicxx.h headers + WM_OPTIONS=linux64GccDPOptOPENMPI + wmake libso mpi /scratch/nwinkler/ProgramFiles/OF-1.6/ThirdParty-1.6/openmpi-1.3.3/platforms/linux64GccDPOpt/lib/libmpi.so: file not recognized: File format not recognized collect2: ld returned 1 exit status make: *** [/scratch/nwinkler/ProgramFiles/OF-1.6/OpenFOAM-1.6/lib/linux64GccDPOpt/openmpi-1.3.3/libPstream.so] Error 1 + wmake libso parMetisDecomp /usr/bin/ld: cannot find -lmetis-parmetis collect2: ld returned 1 exit status make: *** [/scratch/nwinkler/ProgramFiles/OF-1.6/OpenFOAM-1.6/lib/linux64GccDPOpt/openmpi-1.3.3/libparMetisDecompositionMethod.so] Error 1 When looking for libPstream.so it is located under ./OpenFOAM-1.6/lib/linux64GccDPOpt/dummy/libPstream.so and not where it is looking for it and the file libparMetisDecompositionMethod.so does not exist. Any suggestions? Regards /NW |
February 18, 2010, 11:18 |
Nick Gardiner
Rep Power: 17 |
I had this problem. If you have libmetis-parmetis.so in /home/****/OpenFOAM/OpenFOAM-*****/lib/linux64GccDPOpt/openmpi-1.3.3 then I found that copying all the files in there and pasting them up a level in /home/****/OpenFOAM/OpenFOAM-*****/lib/linux64GccDPOpt seemed to fix it Hope it helps |
February 18, 2010, 11:19 |
Nick Gardiner
Rep Power: 17 |
...and then recompiling... !
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
