Linker errors when building ThirdParty-1.6
Old   August 17, 2009, 15:37
Default Linker errors when building ThirdParty-1.6
Niklas Winkler
nikwin is on a distinguished road
./Allwmake gives this error when trying to build hoard in Thirdparty
+ wmake libso hoard
/scratch/nwinkler/ProgramFiles/OF-1.6/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/../../../../lib64/libstdc++.so: file not recognized: File format not recognized
collect2: ld returned 1 exit status
make: *** [/scratch/nwinkler/ProgramFiles/OF-1.6/OpenFOAM-1.6/lib/linux64GccDPOpt/libhoard.so] Error 1
several other targets fail with the same error, i.e. libstdc++.so is not recognized.
it is a symlink to libstdc++.so.6.0.10 , which is 64 bit
>file gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/../../../../lib64/libstdc++.so.6.0.10
gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/../../../../lib64/libstdc++.so.6.0.10: ELF 64-bit LSB shared object, AMD x86-64, version 1 (SYSV), not stripped
and so is the machine
>uname -a
Linux tour 2.6.18-6-amd64 #1 SMP Tue May 5 08:01:28 UTC 2009 x86_64 GNU/Linux
And I try to build the 64 bit version:
>echo $WM_ARCH_OPTION
64
Any suggestions how to make it build?
Regards
/NW
nikwin is offline   Reply With Quote
Old   August 18, 2009, 08:28
Rishi .
hellorishi is on a distinguished road
I had similar problem with libstdc++.
The problem was solved by first compiling gcc in thirdparty with path for gmp and mpfr, using my system compiler.
Then I could compile OF1.6 and did not have libstdc++ error.
It could be the same problem...
hellorishi is offline   Reply With Quote
Old   August 18, 2009, 12:05
Niklas Winkler
Thanks Rishi,
I did as in the following thread and it works for Thirdparty!
http://www.linuxquestions.org/questions/linux-from-scratch-13/i-have-an-error-building-gcc-requires-gmp-4.1-and-mpfr-2.3.0.-690426/
But, when trying to compile src/ with ./Allwmake I get the following errors,
Note: ignore spurious warnings about missing mpicxx.h headers
+ WM_OPTIONS=linux64GccDPOptOPENMPI
+ wmake libso mpi
/scratch/nwinkler/ProgramFiles/OF-1.6/ThirdParty-1.6/openmpi-1.3.3/platforms/linux64GccDPOpt/lib/libmpi.so: file not recognized: File format not recognized
make: *** [/scratch/nwinkler/ProgramFiles/OF-1.6/OpenFOAM-1.6/lib/linux64GccDPOpt/openmpi-1.3.3/libPstream.so] Error 1
+ wmake libso parMetisDecomp
/usr/bin/ld: cannot find -lmetis-parmetis
make: *** [/scratch/nwinkler/ProgramFiles/OF-1.6/OpenFOAM-1.6/lib/linux64GccDPOpt/openmpi-1.3.3/libparMetisDecompositionMethod.so] Error 1
When looking for libPstream.so it is located under ./OpenFOAM-1.6/lib/linux64GccDPOpt/dummy/libPstream.so
and not where it is looking for it and the file libparMetisDecompositionMethod.so does not exist.
Any suggestions?
Regards
/NW
Old   February 18, 2010, 11:18
Nick Gardiner
NickG is on a distinguished road
I had this problem. If you have libmetis-parmetis.so in /home/****/OpenFOAM/OpenFOAM-*****/lib/linux64GccDPOpt/openmpi-1.3.3 then I found that copying all the files in there and pasting them up a level in /home/****/OpenFOAM/OpenFOAM-*****/lib/linux64GccDPOpt seemed to fix it
Hope it helps
NickG is offline   Reply With Quote
Old   February 18, 2010, 11:19
Nick Gardiner
...and then recompiling... !
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
