Successful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 9.04
Old   August 15, 2009, 17:41
Thumbs up Successful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 9.04
Alan Russell
AlanR is on a distinguished road
After many attempts over the past few weeks, I managed to successfully install OpenFOAM-1.6 and Paraview 3.6.1. I have managed to learn a fair amount about linux along the way. Here's what worked for me: maybe it will save some time for someone else...
First, the OpenFOAM installation instructions in the README file work consistently. The only problem I had on a clean installation of Ubuntu 9.04 (32 bit) was with permissions. This fixed it:
http://http://www.cfd-online.com/Forums/openfoam-installation/67198-openfoam-1-6-permissions-ubuntu-9-04-a.htm Post 2
I have not had problems getting the foamInstallationTest to check out, or running blockmesh and icoFoam on the lid-driven cavity flow tutorial.
ParaView was more of a challenge. After many attempts and reading a lot of posts, I found the installParaView script by Jure.
http://www.cfd-online.com/Forums/ope...ntu-9-04-a.htm Post 58
Before you go off and run the script, I had the problem described in Post 61. I fixed the problem by following Post 66 and recompiling Paraview following the README file instructions (below). Compiling Paraview takes a long time - on the order of 5 hours for the old desktop I'm currently using, so be sure to add the path in Post 66, and make sure you have the correct version of qmake, cmake and gcc before you start. To check for each, us the command qmake --version, cmake --version and gcc --version., and to check the path, echo $PATH.
Compiling Paraview 3.6.1 and the PV3FoamReader module
  • cd $WM_THIRD_PARTY_DIR
  • rm -rf paraview-3.6.1/platforms
  • makeParaView
  • cd $FOAM_UTILITIES/postProcessing/graphics/PV3FoamReader
  • ./Allwclean
  • ./Allwmake
Good luck. Thanks to those who helped me, and see you all on other posts. When I get a new 64 bit system, I will probably be back to the Installation forum.
AlanR
AlanR is offline   Reply With Quote
Old   September 7, 2009, 02:28
Jason G.
JasonG is on a distinguished road
  • makeParaView
  • ./Allwclean
  • ./Allwmake
AlanR
Hi Alan,
I am new to linux and have been attempting for the last few weeks to complete the OpenFOAM-1.6 installation on Ubuntu 9.04. I first attempted to follow the README file as mentioned, and then tried various installation guides I found on other sites, but with no luck.
I have downloaded the "___.gtgz" files, and used the "tar" command to extract them. But, then I believe I am incorrectly completing steps 2 and 4. I would greatly appreciate if you could offer any additional comments on getting OpenFOAM installed.
Thanks.
JasonG is offline   Reply With Quote
Old   September 8, 2009, 13:52
Gijsbert Wierink
gwierink is on a distinguished road
Hi Jason,
Where do you exactly get stuck? Do you get error messages and if so, what do they say?
Cheers,
Gijs
gwierink is offline   Reply With Quote
Old   September 8, 2009, 17:19
Jason G.
Originally Posted by gwierink View Post
Hi Jason,
Cheers,
Gijs
After some searching online, I came across this guide:
http://energy.tf.itb.ac.id/index.php...904?format=pdf
On step "9" I try to update the environment variables using the listed command. After doing this I get the following message in my terminal.
"Warning in /home/jason/OpenFOAM/OpenFOAM-1.6/etc/settings.sh:
Cannot find /home/jason/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux installation.
Please install this compiler version or if you wish to use the system compiler,
change the 'compilerInstall' setting to 'System' in this file
I was unsure how to install that compiler version, so I edited the "settings.sh" file so that line 98 was set to 'System'. I thought this worked as I didn't receive any more errors. But, when I attempt step "14" to test a tutorial file, I receive this error:
bash: blockMesh: command not found
I feel I am overlooking something easy.
Thanks!
Old   September 9, 2009, 01:42
Alan Russell
Jason,
Do you have a 32 bit or 64 bit processor? My instructions are for a 32 bit. I haven't attempted installing OpenFOAM 64 bit yet. I think there was a problem with the ThirdParty files. Gcc 4.3.3 is one of the programs that gets installed in the ThirdParty directory. You might want to delete and reinstall the ThirdParty General and binaries.
If you are using a 64 bit machine, there are posts with specific instructions. They are somewhat different than the 32 bit.
If you are using a 32 bit, I suggest you go back to the installation script files by Jure. You can either run them, or just read through them and do the steps yourself. There is a script for installing the OpenFOAM files and a second one for Paraview.
Good luck,
Alan
Old   September 9, 2009, 02:25
Gijsbert Wierink
Hi Jason,
Yes, it might be that settings.sh cannot find /home/jason/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux, because it is actually /home/jason/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64 or /home/jason/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux-64 .
Rgds,
Gijs
Old   September 9, 2009, 02:31
MadsR's Avatar
Mads Reck
MadsR is on a distinguished road
Hey.
If it is any help to you, I've compiled my way of installing OpenFOAM on Ubuntu 9.04 into a script (link here) which seems to work. Maybe it can help/inspire you in solving your problem (?)
Cheers,
Mads
Online free airfoil-mesher for OpenFOAM here
MadsR is offline   Reply With Quote
Old   September 9, 2009, 11:35
Jason G.
Jason,
Good luck,
Alan
Yes, I am using a 64-bit machine. I have been attempting to run it through a Sun VirtualBox just to get the basics of the software before doing a full Linux install on my pc.
Old   September 9, 2009, 11:37
Jason G.
Originally Posted by MadsR View Post
Hey.
Cheers,
Mads
Thanks, I am going to give this a shot to see if it works. Is this also only applicable to a 32-bit machine?
Old   September 9, 2009, 13:03
Jason G.
It seems I am actually running the 32-bit version of Ubuntu. I made a mistake in the file I installed on the virtualbox. I have been trying to run through the posted script, after it didn't load correctly I started manually copy-pasting each line into the terminal. I am getting the following message:
jason@jason-laptop:~$ git clone git://repo.or.cz/OpenFOAM-1.6.x.git
Initialized empty Git repository in /home/jason/OpenFOAM-1.6.x/.git/
repo.or.cz[0: 62.24.64.27]: errno=Connection timed out
fatal: unable to connect a socket (Connection timed out)
I am guessing this is attempting to connect to a site that is no longer still active.
Old   September 14, 2009, 13:21
Jason G.
I finally got OpenFOAM successfully installed, but I am afraid to admit what my issue was . Thanks for the help everyone!
Old   September 15, 2009, 04:27
Gijsbert Wierink
So, just for the record, what was the issue?
Old   September 15, 2009, 04:36
MadsR's Avatar
Mads Reck
Oops, I am a bit late here. Answer to the above question about 32/64 bit. Yes the script was only for 32 bit. I made a new one for 64 bit which I haven't been able to test, though.
32 bit install script
64 bit install script
/Mads
Old   September 15, 2009, 08:22
Jason G.
I thought I downloaded and installed the 64-bit version of Ubuntu on my emulator, so I proceeded to attempt the 64-bit installation of OpenFOAM. In reality I actually installed the 32-bit version of Ubuntu... apparently 64-bit software is not compatible with a 32-bit OS .
Old   September 15, 2009, 11:43
hamdi
hamcer is on a distinguished road
I use ubuntu 8.10, 32 bit in my laptop
can this script installing OF-1.6
Thanks.
hamcer is offline   Reply With Quote
Old   September 16, 2009, 03:19
MadsR's Avatar
Mads Reck
Hamcer,
have you tried my script on Ubuntu 8.10?
/Mads
Old   September 16, 2009, 07:14
hamdi
hello Mads,
yes it workes fine,
but i have an another question , i can't use the python shell in paraview, it said : not shell python available, have u an idea?
Thanks
Old   September 16, 2009, 08:30
MadsR's Avatar
Mads Reck
Hi Hamdi.
No, I am not sure about that one.
A long-shot-solution, if you haven't installed python yet (check with the command: which python) is to install python (duh! :-) ):
sudo apt-get install python
but if it is some kind of binding between paraview and python that doesn't work, I don't know the solution.
/Mads
Old   September 16, 2009, 13:44
Assistant Moderator
Bernhard Gschaider
Originally Posted by hamcer View Post
hello Mads,
yes it workes fine,
Thanks
You're talking about the Paraview-binary that is provided in the ThirdParty-tarball? That one hasn't got python enabled. You've got to run the build-script that is also in the tarball with -python (and probably change the location of the python-library that is in the script to the location appropriate for your machine)
Bernhard
Old   September 17, 2009, 03:44
hamdi
Thank you Bernhard for this repply,
I can use the python shell in paraview given by ubuntu synaptyc, but i loose paraFoam which load the openFoam tutorials (examples).
In the paraview given with openFoam i keep paraFoam, but i can't use python shell in it,
if you have the solution , tel me in details please since I'm not an expert in linux.
thank you again.
Nacer.
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
OpenFOAM 1.6 package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 36 September 2, 2009 12:46
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 17:55
[OpenFOAM] Paraview 3.4, ppa.launchpad.net and Ubuntu francois ParaView 1 May 29, 2009 09:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
