-   OpenFOAM Installation (http://www.cfd-online.com/Forums/openfoam-installation/)
-   -   foamInstallationTest Environment not configured (http://www.cfd-online.com/Forums/openfoam-installation/68613-foaminstallationtest-environment-not-configured.html)
mahzironrazak September 25, 2009 10:51
Hi all
I am trying to install OpenFOAM on my Opensuse 10.3 32 bit. The problem is that when i run the foamInstallationtest, it always says environment variable not configured. I dont know why. I did everything according to the installation procedure.
1) Extract everything in the $Home/OpenFOAM/OpenFOAM-1.5/ directory
2) Edit the bashrc file by adding . $Home/OpenFOAM/OpenFOAM-1.5/etc/bashrc at
the end of the file using Kate
3) source the bashrc by typing . $HOME/.bashrc in the terminal (close and open the
terminal)
4) Run the foamInstallationTest
This i got fatal error because environment variable not configured.
I read all the posts but still cannot figure out why the variable wont configure. I tested on 3 different pcs running suse10.3 and 11 and still no go. I put the dot and space before the $HOME/OpenFOAM... I also tried different version of Openfoam (1.6 and 1.4) still get the same result.
Help Pleaseeeeeeeeeeeeeeee
mahziron
scottneh September 25, 2009 19:37
I just resolved this issue.
In the terminal execute:
nano ~/.bashrc
this depends on the editor you use, mine is nano.
then in the editor enter:
export FOAM_INST_DIR=path/to/OpenFOAM
foamDotFile=$FOAM_INST_DIR/OpenFOAM-1.6/etc/bashrc
[ -f $foamDotFile ] && . $foamDotFile
Make sure you replace "/path/to" with the correct path to your OpenFOAM directory. Save and close the file
then execute:
source ~/.bashrc
that got my installation working.
akidess September 26, 2009 12:55
Scott, that is pretty much equivalent to what he is already doing. However, Mahziron, are you using OpenFOAM 1.5 or 1.6? I'm assuming you are entering a wrong path to the OpenFOAM bashrc. A problem might be that you have to extract the archives in $HOME/OpenFOAM/ and NOT $HOME/OpenFOAM/OpenFOAM.1.X/.
You could use the OpenFOAM cookbook script (http://www.cfd-online.com/Forums/ope...-cookbook.html) if you are ok with it redownloading the code.
mahzironrazak September 29, 2009 12:53
thanks scott & akidess
I am using 1.6 version. Anyway, i changed to Ubuntu and managed to install it using the cookbook script link provided by akidess. It took a few hours of compiling though 5 to be exact using my old notebook.
