[OpenFOAM.com] wmake error: file 'Make/linux64Gcc44DPOpt/objectFiles' could not be created |
November 20, 2009, 08:02 |
Laurence R. McGlashan
Rep Power: 23 |
Hello everyone,
I cloned the OF-1.6 Git repository and downloaded the Third Party stuff. When I run Allwmake (using gcc-4.4.2 on 64bit Fedora 12) on the 1.6.x directory I get the following errors to do with wmake: Code:
Note: ignore spurious warnings about missing mpicxx.h headers + WM_OPTIONS=linux64Gcc44DPOptOPENMPI + wmake libso mpi '/home/lrm29/OpenFOAM/OpenFOAM-1.6.x/lib/linux64Gcc44DPOpt/openmpi-1.3.3/libPstream.so' is up to date. + wmake libo OSspecific/POSIX '/home/lrm29/OpenFOAM/OpenFOAM-1.6.x/lib/linux64Gcc44DPOpt/libOSspecific.o' is up to date. + wmake libso OpenFOAM linux64Gcc44DPOpt/options:6: *** missing separator. Stop. wmake error: file 'Make/linux64Gcc44DPOpt/objectFiles' could not be created + wmake libso lagrangian/basic SOURCE=indexedParticle/indexedParticleCloud.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/lrm29/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/home/lrm29/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc44DPOpt/indexedParticleCloud.o '/home/lrm29/OpenFOAM/OpenFOAM-1.6.x/lib/linux64Gcc44DPOpt/liblagrangian.so' is up to date. + wmake libso triSurface linux64Gcc44DPOpt/options:6: *** missing separator. Stop. wmake error: file 'Make/linux64Gcc44DPOpt/objectFiles' could not be created Code:
EXE_INC = \ -I$(WM_THIRD_PARTY_DIR)/zlib-1.2.3 LIB_LIBS = \ $(FOAM_LIBBIN)/libOSspecific.o \ -L$(FOAM_LIBBIN)/dummy -lPstream \ -lz Code:
# 1 "options" # 1 "<built-in>" # 1 "<command-line>" # 1 "options" EXE_INC = -I$(WM_THIRD_PARTY_DIR)/zlib-1.2.3 LIB_LIBS = $(FOAM_LIBBIN)/libOSspecific.o -L$(FOAM_LIBBIN)/dummy -lPstream -lz Thanks.
Laurence R. McGlashan :: Website |
November 23, 2009, 06:22 |
Rep Power: 23 |
Update: There is something weird going on with the separators (you might say 'duh', looking at the error messages) that wmake generates in the options file. If I manually correct the options file created in Make/linux64GccDPOpt/, and then run wmake, it compiles fine.
November 27, 2009, 10:58 |
Rep Power: 23 |
SOLVED
It was something to do with 'cpp'. The system 'cpp' with GCC 4.4.2 on Fedora 12 screws up the separators. Fix: Edit wmake/rules/linux64Gcc/general so that CPP = ThirdParty-1.6/gcc-4.3.3/platforms/bin/cpp instead of /lib/cpp.
January 5, 2010, 12:34 |
Odd problem
#4 | |
Mikko Auvinen
I'm facing exactly the same problem on my Fedora 12: make complains about missing separators with every single linux64GccDPOpt/options file. It seems as if the files have been corrupted in some way -- the TAB characters have gone missing or something. The only way I can make things work is by manipulating the files by hand. I tried your Fix, but I cannot get things to work. Could you please elaborate a little on what you did after you edited the rules file in wmake? I'm trying to compile 1.6 and 1.5-dev on my new machine and I have the same problem with both. Gratefully, - mikko |
January 7, 2010, 05:53 |
Solved indeed
#6 | |
Mikko Auvinen
Just to clarify the issue for potential readers, this problem arose with me irrespective of the compiler choice (compilerInstall=System/OpenFOAM) in settings.sh; wmake tries to utilize the system cpp by default. Good work Laurence! |
January 13, 2010, 18:18 |
OpenFOAM-1.5-dev: Make/linux64GccDPOpt/objectFiles' could not be created
Eero Kokkonen
Hello!
I am getting the same error with OpenFOAM-1.5-dev (I need the GGI) on Fedora 12 (64-bit) and Ubuntu 9.10 (32-bit) as mentioned here. This is the basic form that I have tried: First got these: flex binutils binutils-dev cmake gcc-c++ qt4 1) Get the OpenFOAM-1.5-dev and Thirdparty files for 1.5-version: svn co https://openfoam-extend.svn.sourcefo...enFOAM-1.5-dev OpenFOAM-1.5-dev http://sourceforge.net/projects/foam....gtgz/download http://sourceforge.net/projects/foam....gtgz/download tar xzf ThirdParty.General.gtgz tar xzf ThirdParty.linuxGcc.gtgz 2) changed: OpenFOAM-1.5-dev/etc/settings.sh #compilerInstall=OpenFOAM compilerInstall=System to: compilerInstall=OpenFOAM #compilerInstall=System 3) Added $HOME/.bashrc the following line: source $HOME/OpenFOAM/OpenFOAM-1.5-dev/etc/bashrc and sourced (or opened new terminal) 4) Have done ./Allwmake >& log_Allwmake The log can be found here: http://www.students.tut.fi/~kokkonee/OpenFOAM/log_Allwmake In addition I have tried i) FIX up for Ubuntu 9.10 cd ~/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/lib mv libstdc++.so.6 libstdc++.so.6.orig ln -s /usr/lib/libstdc++.so.6.0.13 libstdc++.so.6 mv libgcc_s.so.1 libgcc_s.so.1.orig ln -s /lib/libgcc_s.so.1 ii) and with Fedora 12 http://www.cfd-online.com/Forums/ope...uccessful.html If someone could please help me with this, I am clearly missing something and I and confused from all the things I have read and tried... BR. Eero Kokkonen eero.kokkonen(at)tut.fi |
January 14, 2010, 05:12 |
Mikko Auvinen
Eero,
Referring to the Fedora 12 problem, you're looking at a fix to the "missing separator" issue on this thread. I was able compile both 1.5-dev and 1.6 on F12 after I followed Laurence's recipe on changing the cpp used by wmake. ... Just remember to run wclean after you make the change. - mikko |
January 14, 2010, 05:22 |
Rep Power: 23 |
Although I would now use the fix of adding the 'P' option to the cpp command discussed in the following thread:
http://www.cfd-online.com/Forums/ope...dora-12-a.html
January 14, 2010, 05:50 |
#11 |
Mikko Auvinen
Yes, that's a much nicer fix.Thanks again.
- mikko |
January 17, 2010, 08:28 |
still problems...
#12 |
Eero Kokkonen
Hi!
I have tried the -P option suggested in this thread, but it is not working for me (fedora 12, 64-bit). I started from the beginning (deleted all files) and did the following: 1) Get the OpenFOAM-1.5-dev and Thirdparty files for 1.5-version: svn co https://openfoam-extend.svn.sourcefo...enFOAM-1.5-dev OpenFOAM-1.5-dev http://sourceforge.net/projects/foam....gtgz/download http://sourceforge.net/projects/foam....gtgz/download tar xzf ThirdParty.General.gtgz tar xzf ThirdParty.linuxGcc.gtgz 2) changed: OpenFOAM-1.5-dev/etc/settings.sh #compilerInstall=OpenFOAM compilerInstall=System to: compilerInstall=OpenFOAM #compilerInstall=System 3) Added $HOME/.bashrc the following line: source $HOME/OpenFOAM/OpenFOAM-1.5-dev/etc/bashrc and sourced (or opened new terminal) 4) Compiled the Qt-4.3.5 version and added the following lines to the ~/OpenFOAM/OpenFOAM-1.5/etc/bashrc at the very end # set QT related variables QT=~/OpenFOAM/ThirdParty/Qt-4.3.5 export PATH=$QT/bin:$PATH export LD_LIBRARY_PATH=$QT/lib:$LD_LIBRARY_PATH Have you guys done this with your Fedora distributions? I read that people have got everything working with this (http://www.cfd-online.com/Forums/ope...am-ubuntu.html). I also tried without this, not working... 5) I modified the file: OpenFOAM-1.5-dev/wmake/rules/linux64Gcc/general CPP = /lib/cpp $(GFLAGS) -P LD = ld -A64 PROJECT_LIBS = -l$(WM_PROJECT) -liberty -ldl include $(GENERAL_RULES)/standard include $(RULES)/X include $(RULES)/c include $(RULES)/c++ include $(GENERAL_RULES)/cint Isn't this the correct file in my case (though I also tried the OpenFOAM-1.5-dev/wmake/rules/linuxGcc/general -file)? 6) Did ./Allwmake >& log_Allwmake Still got these wmake errors: wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created make[1]: *** [setFields] Error 1 linux64GccDPOpt/options:6: *** missing separator. Stop. wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created make[1]: *** [mapFields] Error 1 make[1]: Target `application' not remade because of errors. make: *** [preProcessing] Error 2 make: Target `application' not remade because of errors. + '[' '' = doc ']' I have abandoned trying with Ubuntu 9.10 and managed to compile OpenFOAM-1.5-dev on Fedora 10 but still have issues with paraFOAM (reader for the file cavity.OpenFOAM cannot be found while testing the tutorials) Have I done something wrong or missing some package, obviously something's not right? Any ideas? By the way, the 'wclean'-command produces: wclean error: 'Make' directory does not exist And have you modified the (extra?) '-' in 'ParaView3.3-cvs' in any way and if you have, what have you done exactly? I am referring to http://www.cfd-online.com/Forums/ope...foam15dev.html -Eero |
January 18, 2010, 05:40 |
#13 |
Rep Power: 23 |
Things here I can maybe help with:
2) I actually used the compiler that came with Fedora 12. 4) Paraview can be difficult to set up. Can you run 'glxgears'? All my problems were related to that not working. 5) Yes, that's the correct file. 6) wclean only works if there is a make directory. If you're trying to compile the whole thing then you need to do a wcleanAll. You need to do that before running Allwmake again. I haven't actually compiled the -dev version, I may try later.
March 11, 2010, 13:29 |
#14 | |
Mihir
You said you could manually edit the Make/linux64GccDPOpt/options file. here is my options file Code:
# 1 "options" # 1 "<built-in>" # 1 "<command-line>" # 1 "options" EXE_INC = -I$(LIB_SRC)/finiteVolume/lnInclude EXE_LIBS = -lfiniteVolume |
March 12, 2010, 06:26 |
#15 |
Rep Power: 23 |
I strongly suggest that you add the -P option to cpp in your wmake rules, or get your system administrator to do so, otherwise you'll have to manually edit every time you use wmake!
It was either the '\' missing from the end of lines, or a tab/carriage return missing at the end of lines.
September 25, 2010, 18:45 |
#16 |
Daniel WEI (老魏)
Rep Power: 21 |
"-P" is a good solution!
-P: Inhibit generation of linemarkers in the output from the preprocessor. This might be useful when running the preprocessor on something that is not C code, and will be sent to a program which might be confused by the linemarkers.
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
June 14, 2016, 12:56 |
#18 |
elham usefi
Rep Power: 9 |
Hi guys!
i had D same problem Code:
*** missing separator. Stop. wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/elham/OpenFOAM/elham-2.4.0/applications/solvers/2 |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 10:21 |
compiling firefoam | Farshad_Noravesh | OpenFOAM | 27 | December 24, 2012 05:21 |
[swak4Foam] swak4foam can not be installed | hugo17 | OpenFOAM Community Contributions | 1 | September 11, 2012 06:17 |
OpenFoam 1.6-ext - error ./Allwmake in /src | preibie | OpenFOAM Installation | 14 | June 14, 2011 06:57 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
