Problems in compiling paraview in Suse 10.3 platform |
April 22, 2009, 22:46 |
J. Cai
Rep Power: 17 |
When execute "buildParaView3.3-cvs", there are some problems as follows.
----------------------------------------------------------------------------------------------------------------------------------------- cai@linux-jobm:~/OpenFOAM/ThirdParty> buildParaView3.3-cvs Building ParaView3.3-cvs MPI support : OFF Python support : OFF MESA support : OFF Source : /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs Target : /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc -- Check for working C compiler: /home/cai/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -- Check for working C compiler: /home/cai/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc -- works -- Check size of void* -- Check size of void* - done -- Check for working CXX compiler: /home/cai/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/c++ -- Check for working CXX compiler: /home/cai/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/c++ -- works -- Looking for Q_WS_X11 -- Looking for Q_WS_X11 - found -- Looking for Q_WS_MAC -- Looking for Q_WS_MAC - not found. -- Looking for Q_WS_WIN -- Looking for Q_WS_WIN - not found. -- Found Qt-Version 4.3.5 -- Looking for C++ include iosfwd -- Looking for C++ include iosfwd - found -- Looking for C++ include iostream.h -- Looking for C++ include iostream.h - not found -- Performing Test Support for 64 bit file systems -- Performing Test Support for 64 bit file systems - Success -- Check size of int -- Check size of int - done -- Check size of long -- Check size of long - done -- Check size of char -- Check size of char - done -- Check size of short -- Check size of short - done -- Check size of float -- Check size of float - done -- Check size of double -- Check size of double - done -- Looking for include files CMAKE_HAVE_LIMITS_H -- Looking for include files CMAKE_HAVE_LIMITS_H - not found. -- Looking for include files CMAKE_HAVE_UNISTD_H -- Looking for include files CMAKE_HAVE_UNISTD_H - found -- Looking for include files CMAKE_HAVE_PTHREAD_H -- Looking for include files CMAKE_HAVE_PTHREAD_H - found -- Looking for include files CMAKE_HAVE_SYS_PRCTL_H -- Looking for include files CMAKE_HAVE_SYS_PRCTL_H - not found. -- Check if the system is big endian -- Check if the system is big endian - little endian -- Looking for pthread_create in pthreads -- Looking for pthread_create in pthreads - not found -- Looking for pthread_create in pthread -- Looking for pthread_create in pthread - found -- Looking for C++ include iostream -- Looking for C++ include iostream - found -- Check for STD namespace -- Check for STD namespace - found -- Check for ANSI scope -- Check for ANSI scope - found -- Check for sstream -- Check for sstream - found -- Check size of long long -- Check size of long long - done -- Check size of __int64 -- Check size of __int64 - failed -- Checking support for C++ type bool -- Checking support for C++ type bool -- yes -- Checking signedness of char -- Checking signedness of char -- signed -- Looking for getsockname in socket -- Looking for getsockname in socket - not found -- Checking for getsockname with socklen_t -- Checking for getsockname with socklen_t -- no -- Looking for SO_REUSEADDR -- Looking for SO_REUSEADDR - not found. -- Checking support for full template specialization syntax -- Checking support for full template specialization syntax -- yes -- Checking support for C++ explicit template instantiation -- Checking support for C++ explicit template instantiation -- yes -- Checking ANSI streams end-of-file bug level -- Checking ANSI streams end-of-file bug level - 0 -- Checking if ostream supports long long -- Checking if ostream supports long long -- yes -- Checking if istream supports long long -- Checking if istream supports long long -- yes -- Found OSMesa: /usr/lib/libOSMesa.so -- Checking for Large File Support -- Checking for Large File Support - yes -- Checking whether STL classes are in std namespace -- Checking whether STL classes are in std namespace - yes -- Checking whether ANSI stream headers are available -- Checking whether ANSI stream headers are available - yes -- Checking whether ANSI streams are in std namespace -- Checking whether ANSI streams are in std namespace - yes -- Checking whether ANSI string stream is available -- Checking whether ANSI string stream is available - yes -- Checking whether header cstddef is available -- Checking whether header cstddef is available - yes -- Checking whether stl string has operator!= for char* -- Checking whether stl string has operator!= for char* - yes -- Checking whether stl has iterator_traits -- Checking whether stl has iterator_traits - yes -- Checking whether stl has standard template allocator -- Checking whether stl has standard template allocator - yes -- Checking for rebind member of stl allocator -- Checking for rebind member of stl allocator - yes -- Checking for non-standard argument to stl allocator<>::max_size -- Checking for non-standard argument to stl allocator<>::max_size - no -- Checking whether stl containers support allocator objects. -- Checking whether stl containers support allocator objects. - yes -- Checking whether "<>" is needed for template friends -- Checking whether "<>" is needed for template friends - yes -- Checking for member template support -- Checking for member template support - yes -- Checking for standard template specialization syntax -- Checking for standard template specialization syntax - yes -- Checking whether argument dependent lookup is supported -- Checking whether argument dependent lookup is supported - yes -- Checking whether struct stat has st_mtim member -- Checking whether struct stat has st_mtim member - yes -- Checking whether C compiler has ptrdiff_t in stddef.h -- Checking whether C compiler has ptrdiff_t in stddef.h - yes -- Checking whether C compiler has ssize_t in unistd.h -- Checking whether C compiler has ssize_t in unistd.h - yes -- Looking for include files HAVE_ASSERT_H -- Looking for include files HAVE_ASSERT_H - found -- Looking for include files HAVE_DLFCN_H -- Looking for include files HAVE_DLFCN_H - found -- Looking for include files HAVE_FCNTL_H -- Looking for include files HAVE_FCNTL_H - found -- Looking for include files HAVE_INTTYPES_H -- Looking for include files HAVE_INTTYPES_H - found -- Looking for include files HAVE_LIMITS_H -- Looking for include files HAVE_LIMITS_H - not found. -- Looking for include files HAVE_MALLOC_H -- Looking for include files HAVE_MALLOC_H - found -- Looking for include files HAVE_MEMORY_H -- Looking for include files HAVE_MEMORY_H - found -- Looking for include files HAVE_STDINT_H -- Looking for include files HAVE_STDINT_H - found -- Looking for include files HAVE_STDLIB_H -- Looking for include files HAVE_STDLIB_H - found -- Looking for include files HAVE_STRING_H -- Looking for include files HAVE_STRING_H - found -- Looking for include files HAVE_STRINGS_H -- Looking for include files HAVE_STRINGS_H - found -- Looking for include files HAVE_SYS_STAT_H -- Looking for include files HAVE_SYS_STAT_H - found -- Looking for include files HAVE_SYS_TIME_H -- Looking for include files HAVE_SYS_TIME_H - found -- Looking for include files HAVE_SYS_TYPES_H -- Looking for include files HAVE_SYS_TYPES_H - found -- Looking for include files HAVE_UNISTD_H -- Looking for include files HAVE_UNISTD_H - found -- Looking for include files HAVE_WINDOWS_H -- Looking for include files HAVE_WINDOWS_H - not found. -- Looking for include files HAVE_IEEEFP_H -- Looking for include files HAVE_IEEEFP_H - not found. -- Looking for floor -- Looking for floor - not found -- Looking for getopt -- Looking for getopt - found -- Looking for isascii -- Looking for isascii - found -- Looking for memmove -- Looking for memmove - found -- Looking for memset -- Looking for memset - found -- Looking for mmap -- Looking for mmap - found -- Looking for pow -- Looking for pow - not found -- Looking for sqrt -- Looking for sqrt - not found -- Looking for strcasecmp -- Looking for strcasecmp - found -- Looking for strchr -- Looking for strchr - found -- Looking for strrchr -- Looking for strrchr - found -- Looking for strstr -- Looking for strstr - found -- Looking for strtol -- Looking for strtol - found -- Looking for areroul -- Looking for areroul - not found -- Check size of int -- Check size of int - done -- Check size of long -- Check size of long - done -- Looking for dlopen in dl; -- Looking for dlopen in dl; - found -- Looking for shl_load in dld;dl -- Looking for shl_load in dld;dl - not found -- Looking for append_history in history;dl -- Looking for append_history in history;dl - found -- Looking for readline in readline;dl;history -- Looking for readline in readline;dl;history - found -- Looking for dlopen in dl;history;readline;-lpthread;dl;m -- Looking for dlopen in dl;history;readline;-lpthread;dl;m - found -- Looking for include files HAVE_STDIO_H -- Looking for include files HAVE_STDIO_H - found -- Looking for include files HAVE_STDDEF_H -- Looking for include files HAVE_STDDEF_H - found -- Looking for include files HAVE_NETDB_H -- Looking for include files HAVE_NETDB_H - not found. -- Looking for include files HAVE_SYS_SOCKET_H -- Looking for include files HAVE_SYS_SOCKET_H - not found. -- Looking for include files HAVE_NETINET_IN_H -- Looking for include files HAVE_NETINET_IN_H - not found. -- Looking for include files HAVE_SYS_SELECT_H -- Looking for include files HAVE_SYS_SELECT_H - found -- Looking for include files HAVE_TIME_H -- Looking for include files HAVE_TIME_H - found -- Looking for include files HAVE_SIGNAL_H -- Looking for include files HAVE_SIGNAL_H - not found. -- Looking for include files HAVE_ERRNO_H -- Looking for include files HAVE_ERRNO_H - not found. -- Looking for include files HAVE_ANSIDECL_H -- Looking for include files HAVE_ANSIDECL_H - not found. -- Looking for include files HAVE_ARPA_INET_H -- Looking for include files HAVE_ARPA_INET_H - not found. -- Looking for include files HAVE_ARPA_NAMESER_H -- Looking for include files HAVE_ARPA_NAMESER_H - not found. -- Looking for include files HAVE_CTYPE_H -- Looking for include files HAVE_CTYPE_H - found -- Looking for include files HAVE_DIRENT_H -- Looking for include files HAVE_DIRENT_H - not found. -- Looking for include files HAVE_DL_H -- Looking for include files HAVE_DL_H - not found. -- Looking for include files HAVE_FLOAT_H -- Looking for include files HAVE_FLOAT_H - found -- Looking for include files HAVE_FP_CLASS_H -- Looking for include files HAVE_FP_CLASS_H - not found. -- Looking for include files HAVE_MATH_H -- Looking for include files HAVE_MATH_H - found -- Looking for include files HAVE_NAN_H -- Looking for include files HAVE_NAN_H - not found. -- Looking for include files HAVE_NDIR_H -- Looking for include files HAVE_NDIR_H - not found. -- Looking for include files HAVE_PTHREAD_H -- Looking for include files HAVE_PTHREAD_H - found -- Looking for include files HAVE_RESOLV_H -- Looking for include files HAVE_RESOLV_H - not found. -- Looking for include files HAVE_STDARG_H -- Looking for include files HAVE_STDARG_H - found -- Looking for include files HAVE_SYS_MMAN_H -- Looking for include files HAVE_SYS_MMAN_H - found -- Looking for include files HAVE_SYS_TIMEB_H -- Looking for include files HAVE_SYS_TIMEB_H - found -- Looking for finite -- Looking for finite - found -- Looking for fpclass -- Looking for fpclass - not found. -- Looking for fp_class -- Looking for fp_class - not found. -- Looking for fprintf -- Looking for fprintf - found -- Looking for ftime -- Looking for ftime - found -- Looking for gettimeofday -- Looking for gettimeofday - found -- Looking for localtime -- Looking for localtime - found -- Looking for printf -- Looking for printf - found -- Looking for sscanf -- Looking for sscanf - found -- Looking for sprintf -- Looking for sprintf - found -- Looking for snprintf -- Looking for snprintf - found -- Looking for signal -- Looking for signal - not found. -- Looking for strdup -- Looking for strdup - found -- Looking for strndup -- Looking for strndup - found -- Looking for strerror -- Looking for strerror - found -- Looking for strftime -- Looking for strftime - found -- Looking for stat -- Looking for stat - found -- Looking for _stat -- Looking for _stat - not found. -- Looking for vfprintf -- Looking for vfprintf - found -- Looking for vsnprintf -- Looking for vsnprintf - found -- Looking for vsprintf -- Looking for vsprintf - found -- Checking for getaddrinfo. -- Checking for getaddrinfo. - no -- Checking for socklen_t -- Checking for socklen_t - no -- Checking for DIR in sys/dir.h -- Checking for DIR in sys/dir.h - no -- Checking for DIR in sys/ndir.h -- Checking for DIR in sys/ndir.h - no -- Checking for va_copy -- Checking for va_copy - yes -- Checking for __va_copy -- Checking for __va_copy - yes -- Checking for ipv6 support. -- Checking for ipv6 support. - no -- Looking for include files STDC_HEADERS -- Looking for include files STDC_HEADERS - found -- Looking for include files HAVE_ALLOCA_H -- Looking for include files HAVE_ALLOCA_H - found -- Looking for alloca -- Looking for alloca - found -- Check size of size_t -- Check size of size_t - done -- Check size of ssize_t -- Check size of ssize_t - done -- Check size of ptrdiff_t -- Check size of ptrdiff_t - done -- Check size of off_t -- Check size of off_t - done -- Check size of double -- Check size of double - done -- Check size of float -- Check size of float - done -- Check size of short -- Check size of short - done -- Check size of uchar -- Check size of uchar - failed -- Performing NetCDF Test HAVE_ST_BLKSIZE -- Performing NetCDF Test HAVE_ST_BLKSIZE - Success -- Performing NetCDF Test HAVE_FTRUNCATE -- Performing NetCDF Test HAVE_FTRUNCATE - Success -- Looking for malloc.h -- Looking for malloc.h – found -- Check if system supports 64 bit streams -- Check if system supports 64 bit streams - yes -- Found Qt-Version 4.3.5 -- Found Qt-Version 4.3.5 -- Application: default ParaView Client enabled -- Application: Custom Server enabled -- Application: DobranoViz enabled -- Plugin: Prism enabled -- Found Qt-Version 4.3.5 -- Configuring done -- Generating done -- Build files have been written to: /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc Scanning dependencies of target vtksys [ 0%] Building C object VTK/Utilities/kwsys/CMakeFiles/vtksys.dir/ProcessUNIX.o In file included from /usr/include/signal.h:333, from /usr/include/sys/wait.h:31, from /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:56: /usr/include/bits/sigcontext.h:28:29: error: asm/sigcontext.h: No such file or directory In file included from /usr/include/errno.h:36, from /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:60: /usr/include/bits/errno.h:25:26: error: linux/errno.h: No such file or directory In file included from /usr/include/bits/posix1_lim.h:153, from /usr/include/dirent.h:232, from /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:63: /usr/include/bits/local_lim.h:36:26: error: linux/limits.h: No such file or directory /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘vtksysProcess_Execute’: /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:730: error: ‘EINTR’ undeclared (first use in this function) /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:730: error: (Each undeclared identifier is reported only once /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:730: error: for each function it appears in.) /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessWaitForPipe’: /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1036: error: ‘EINTR’ undeclared (first use in this function) /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘vtksysProcess_Kill’: /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1347: error: ‘EINTR’ undeclared (first use in this function) /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessCleanup’: /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1465: error: ‘EINTR’ undeclared (first use in this function) /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessCleanupDescriptor’: /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1512: error: ‘EINTR’ undeclared (first use in this function) /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessClosePipes’: /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1540: error: ‘EINTR’ undeclared (first use in this function) /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessCreate’: /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1733: error: ‘EINTR’ undeclared (first use in this function) /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessDestroy’: /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1779: error: ‘EINTR’ undeclared (first use in this function) /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessFork’: /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:2278: error: ‘EINTR’ undeclared (first use in this function) /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessesAdd’: /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:2555: error: ‘EINTR’ undeclared (first use in this function) /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessesRemove’: /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:2592: error: ‘EINTR’ undeclared (first use in this function) make[2]: *** [VTK/Utilities/kwsys/CMakeFiles/vtksys.dir/ProcessUNIX.o] Error 1 make[1]: *** [VTK/Utilities/kwsys/CMakeFiles/vtksys.dir/all] Error 2 make: *** [all] Error 2 done cai@linux-jobm:~/OpenFOAM/ThirdParty> ------------------------------------------------------------------------------------------------------------------------------------------ any comments are appreciated. |
April 26, 2009, 22:28 |
done
J. Cai
Rep Power: 17 |
This is because some of the system softwares have been installed. Just add them, and it will be done.
December 1, 2009, 07:18 |
OF-1.6 on Opensuse 10.3
Srikara Mahishi
Rep Power: 17 |
Hi Everybody,
I am trying to install openfoam 1.6 on my suse 10.3, 64 bit platform. I found out that the cmake was not there in the thirdParty-1.6 folder. I downloaded cmake 2.6.4 and extracted it in my thirdParty directory. After that I did the following from a terminal in my thirdParty directory:
PHP Code:
December 1, 2009, 07:21 |
Srikara Mahishi
Rep Power: 17 |
PHP Code:
So could anybody please let me know what I am doing wrong here?? Thank you in advance, Srikara |
Problems compiling UDFs under SuSE 10.2 | George | FLUENT | 1 | February 21, 2007 08:36 |
Problems on Compiling UDF in FLUENT | Strawberi-KeatKeat | FLUENT | 1 | October 4, 2006 01:50 |
[OpenFOAM] ParaView problem under SUSE 10_64 | hsieh | ParaView | 3 | March 27, 2006 01:12 |
Compiling UDF on SUSE 8.0 | L-P | FLUENT | 0 | September 23, 2003 07:43 |
Problems installing CFX on Sun Unix Platform | Haley | CFX | 2 | November 9, 2001 09:52 |
